Alan Ambrose
Everything posted by Alan Ambrose
D4 glue.. is this a structural glue? Be careful folks!
Alan Ambrose replied to Gus Potter's topic in Timber Frame
A couple of years ago, as a teenager 😗, I used to help my dad build wooden boats. Cascamite and (if memory serves) urea formaldehyde were the glues for anything serious - which most stuff was. -
https://www.ebay.co.uk/itm/235644027667 £9 for 25 (36p each) and SS
>>> the flue has failed Oh yeah, I remember. Guy tried this at my mothers flat which had been newly converted from an office building about 10 years ago. The conversion was pretty good, with an EPC B rating. All the flues were run internally which was fine at the time and to regs of the conversion. He was getting bolshy with a frail 88 year old. The deal is that the regs have changed (as said above) and you're now meant to be able to inspect flues from outside. Most regs are not retrospective. Told him to leave immediately and stop bothering her (I paraphrase). I would get a second opinion at least and/or get your own CO meter.
Well galvanised flat head torx (T20?) wood screws? This kind of thing? https://www.google.com/search?q=flat+head+torx+wood+screw+galvanised
Ah, I've figured it out . I did this kind of thing (straight bits of wood held on with bungees, measure above and below the pipe and average the numbers). Then same from side-to-side. So, 373mm od side-to-side and 336mm od vertically - so, tada, the pipe is a bit squashed and averaged again the overall diameter is ~354mm i.e. standard size OD for 300mm twinwall. It was the obviously bigger diameter seen from above that was putting me off. Now all I have to do is fit the damn thing. BTW there are at least two suppliers of flexible rubber couplings & adaptors ... flexseal and VIPseal. You can pretty much attach any diameter to any somewhat-in-the-same-ballpark diameter. e.g.: https://www.vipseal.co.uk/product/vsc-standard-couplings-2 https://www.fernco.co.uk/assets/Data-Sheets-Folder/Flexseal-Standard-Couplings.pdf
Horizontal hairline cracks in 45x190 joists.
Alan Ambrose replied to Jawbkk's topic in General Construction Issues
>>> Is that almost as good as point loading Strictly speaking you would have to wear ballet flats, be in an en pointe position with one foot and the other raised from the floor - maybe in an arabesque position. First impression is that you are worrying about nothing (sorry to be blunt). Unless there’s a fairly obvious structural crack along the entire length of a beam or a big notch out, you’ll be fine. By all means examine and test by bouncing, observing, estimating deflection etc. Wood is a natural substance and subject to splits, shakes, cracks, warping, twists, knots etc. That’s expected and allowed for. There will be safety factors of at least 2 or 3 or more - and it will all be designed to standard dead and live loads. From memory, live load allowance is 1.5kN/m^2 i.e. ~150kg/m^2. If you really want to go into it, there will be a spec somewhere (maybe a british standard) for what is an acceptable level of cracks, twisting, notches etc in rafters. But in general - that’s just what wood does. And a good builder will have ensured that no sub-standard materials are used in structural positions. -
A good article on crack width & waterproof concrete...
Alan Ambrose replied to Alan Ambrose's topic in Basements
>>> a gold star The buildhub olympics, yeah... -
@saveasteading Thanks, that is interesting. The info I've been given is that it's largely down to the quantity of steel. Nobody said anything about the density of the mesh - although small mesh sounds logical. The bentonite filled sheeting sounds like Sika BentoShield or similar? Did that all work well? -
>>> Do I get a sweety? Certainly for effort . Well yes, given the data you were given, you're right. PHPP, for my windows, says Z is between 62% and 82% with an average of 71%. Not sure where the discrepancy is - I guess I was giving averages over a bunch of windows, so that's it.
Larger "Spark Gap" means fewer heat pumps
Alan Ambrose replied to LnP's topic in Environmental Building Politics
Seems reasonable (to me at least) that the long term direction of oil & gas is up, and the long term direction of renewables (i.e. electricity) is down. So, sooner or later the gap will narrow. -
I've seen it specified before for areas that would get some occasional traffic. Its probably good for the purpose if it's laid well. You can get a feeling for the load bearing capacity between types simply by looking at the weight of the grid per m^2. I wonder though whether continuous usage by a car (and therefore sun & rain shading) and 'poisonous' drips of oil etc. onto the grass would make it not great for heavy use.
https://www.si-eng.org/post/a-journey-of-designing-self-healing-concrete#:~:text=The allowable crack width for,are harder to self heal. Suggests, for the typical self-build single storey basement (say, roughly 4m deep & 0.25m walls - i.e. 'pressure gradient~=16'), the optimistic value is 0.2mm based on the old BS8007 and the new C766 and the pessimistic value is 0.15mm from EC2-3.
OK here's a few numbers - from my window schedule in PHPP nominally using Rationel Auraplus & Velux. S/W/E windows using Rationel Sun SKN176; N wndows using Rationel Auraplus 4/20/4/20/4; Veluxes using Velux Heat Protection Glazing 69: Average Uframe=1.132, Uglazing=0.522, Uwindow=0.712, Uinstalled=0.822 If I change all the glass for better stuff with 90% of the U-value (e.g. 0.5 glass becomes 0.45 glass etc), the numbers become: Average Uframe=1.132, Uglazing=0.470, Uwindow=0.675, Uinstalled=0.785 So, sounds like the Uwindow/Uglazing factor (the discrete derivative? ) might be around (0.712-0.675)/(0.5-0.45) i.e. 74%. Hope that helps . I guess you can also sometimes get this from the window frame supplier's various double/triple glazed offerings - if you believe their numbers... You can play these type of games fairly easily by mangling PHPP if you choose to.
Not really It's an existing ditch that runs behind 3 properties in the countryside which we want to link up to. This was turned into a piped culvert about 10 years ago. I think this kind of 300mm twinwall pipe is the first thing that farmers/countryfolk think of when they consider culverts & ditches & rainwater. BTW in my twinwall travels I discovered this chart (below). The pipe is reputed to have an 1:80 gradient suggesting 1.8m/s & 150l/s. So, yeah, theoretically enough for 75 SuDS compliant houses if it was laid correctly and if the other houses used attenuation (they don't and one neighbour says it wasn't).
Anyone? I'm thinking, even though it was apparently installed less than 10 years ago, that the ~275mm id / 380mm od must be some old imperial size or old design. As far as I can see, the 300mm twinwall versions by Naylor, Polypipe, JFC, Wavin and Cherry (and probably Brett Martin) are all fairly compatible ... and not the same size as the pipe that is installed.
How to install external POE Camera?
Alan Ambrose replied to Andeh's topic in Networks, AV, Security & Automation
Maybe put in a small IP box, carefully spray paint that and the camera to match your eaves or whatever. -
>>> can't select a sd=7.5m VCL BTW you can creste your own materials in ubakus.
Opinions please on this quote for substructure & drains.
Alan Ambrose replied to Tony L's topic in Foundations
Hi, @Tony L - is it possible to report back how this went, with any knowledge / tips that you gained? We may well have a similar situation. -
Building Dispute with contractor
Alan Ambrose replied to James Frome's topic in Costing & Estimating
>>> depends how mickey mouse the whole setup is from the start. Client - well meaning but properly naive and just hoping the gov will pick up any overrun. Gov funder - has a bunch of lawyers, contracts and procedures, is properly slow, and also fairly naive about the ability of the people they give the money to to actually execute the job well. Contractor: work a bit slapdash, spun the client a tale about not being able to know whether they were on budget/timescale until a few weeks before the original completion date. Contractor's QS now going for the jugular to the tune of £0.5-0.75m. It is government money after all and the bosses really want some new Range Rovers. -
Hmmm a bit of game that DNOs play, some more hardball than others. Yes, of course they'll remove their equipment / no, they cannot say how long before they get to it / yes, they'll be happy to give you a quote to move it in a shorter timescale. It is their business, and yes they're pretty good at this game. How long are the cables / what kind / how many poles? Before I bought it, my plot had some cables moved from overflying to underground and one new pole put in. Original overhead route was ~43m, new underground route was ~31m, one extra pole, cost £16.2K. This was UKPN.
