markharro
Everything posted by markharro
I’m confused about ubiquiti
markharro replied to Adsibob's topic in Networks, AV, Security & Automation
Don't you just use a standard ethernet cable? I too am thinking of one of these Dream Routers (UDR). I have Plusnet broadband and am shortly upgrading to their full fibre to the house product. They have to instal an "ONT" box in your house for this. My question is - can I connect the UDR direct to the ONT or is it ONT > Plusnet router (Hub2) > UDR? If the latter do I have to make any changes to the plusnet router eg turn off its wifi? Anything else? Is this all easy to do? thanks PS do standard ethernet CAT6 and 6A cables work with PoE or do you need a special cable for that? -
Ubiquiti home networking - initial impressions
Don't get me wrong - I regard brexit as the apocalypse too.....just not expressing myself clearly. -
Hi @willbish this looks like a good compact rack solution. Can I ask what products these are and where you purchased? Is that a switch that you have connected the purple CAT cables into by punching the wires in? Do you then connect one wire into the front panel from the router to get internet through to all the purple cables? Is the switch providing power over ethernet? -
Do you know that Unifi offer their own video doorbell - indeed two versions! The pro version appears cable of both power and data over ethernet - https://eu.store.ui.com/collections/unifi-protect-cameras/products/g4-doorbell-pro Looks like a very good piece of kit if you can get hold of it as you can record the video locally without paying Ring/google etc £x per month On a separate topic has anyone ordered from the Unify EU store? What are the typical delivery charges and do you get hit by any of the crazy brexit import duties? thanks -
Correct heat pump sizing for passivhaus
markharro replied to markharro's topic in Air Source Heat Pumps (ASHP)
Its meant to be both and its to be certified as well so this is puzzling me!! -
Hi Ian the initial figures are from the architect and therefore PHPP. I am afraid I cant answer your second question. The ASHP installer is offering either a 250 or 300 litre tank - I am inclined to go for 300l Yes we hope to instal PV. We have 3phase so if the budget will stretch I am thinking about a maxed out 11kW instal of PV with divert to the tank and at some point a battery. I am not sure how much financial sense this all makes but I am encouraged by Octopus' recent announcement of a new tariff that pays 15p per kw for export. We also have an EV if that is relevant and will be fitting UF heating on the ground floor. -
It will be 1 and 1/2 storey and 230m2 internal floor area if that helps. -
I need to agree this with the installer in the next month or so. We are building a 4 bed passive house. the current predicted performance is - Heating demand kWh/(m²a) 19 Heating load W/m² 10 Vaillant offer 3.5 and 5kw pumps. Looking for views on which option to go with? thanks.
Practical experience of ceiling acoustic performance sought
markharro replied to dnb's topic in Plastering & Rendering
Thanks - looks like the White Book is a good resource for soundproofing etc. For what its worth on at least a couple of passivhaus projects I have been to see resilient bars were used for the GF ceilings for soundproofing. Seems to be an easy and hopefully cheap option. On a separate point when our house is built later this year we will need the best solution to soundproof the "TV room" that will be an offshoot from our main living space. The issue is that we will have a wide sliding pocket door between the two spaces - 1.5m from memory when closed. I think its too wide to use a generic door panel but in any event I want the best acoustic option. Can anyone suggest a good option for what we could use? -
Basic point I know but what is the "White Book"? Building Regs or something else? -
Zehnder Q350 + ComfoPost CW12
markharro replied to BartW's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Interesting to read this given that I was planning the same kit as the OP. I had asked Paul to requote adding the Comfopost from memory at the height of last summer I think. My hazy recollection of the logic was to give some cooling ability during the hottest weather. This would then add to running the Vaillant ASHP we plan to get on reverse. Having read this thread I am also wondering if it is worth the extra cost and hassle!? -
We had a 2 year battle as well with the first application turned down on pathetic, vague and sketchy grounds. I had no budget for a planning consultant but second time around and via a subtle "complaint" and some psychology we prevailed. But a whole load of stress and time I won't get back. I'm convinced that without the professional skills I have in my day job I would still be at it. I shouldn't have needed to deploy those however.
Lining a wall with plywood: how thick should the ply be?
markharro replied to ToughButterCup's topic in General Joinery
Hi @Mr Punter - I dont suppose you know where Scottish regs are on this? thanks -
I'm trying to understand our 3phase eventual cabling setup. Right now 3phase is on site in a box by the boundary. We have a newly installed smart meter put in as well. When this 3phase supply was installed our outbuildings were connected up to the box and now have power. When our new house is built later this year we plan to take power for the house and associated equipment ie 22kW EV charger and ASHP from the box via a conduit into the new utility room. What I am trying to understand is how this is done with 3phase? eg will I be using one of the phases right now to power the outbuildings? Does this mean that I only have 2 phases left for the main house and everything else? If so, does this mean 2 cables will be brought into the house? How best to plan the wiring in very general overview? Would a 22kW EV charger normally be dedicated a whole single phase? Will any decent electrician know how best to split the 3 phases between the various demands? For info we are building a passivehaus. As well as the EV charger and ASHP there will be the standard MVHR. If budget allows we also would like to fit solar PV and potentially storage. thanks
Hi @AdamSee can I check which length of track you were using for the cross cut? I think Makita do 1400mm and 1500mm lengths? Were you using the 1400mm? Keen to know as I need to buy some track soon. Thanks
Anyone have any opinion on this - https://www.amazon.co.uk/dp/B08XZPHKTS/ref=twister_B08ZX24XHL?_encoding=UTF8&psc=1 ooks like by far the cheapest with M class filtration!
Hi and sorry to hear about this. A verbal contract should be binding in a situation like this I would have thought. With verbal contracts the problem is establishing what was agreed. In the first instance it would be useful if you could press them in writing to say if they do at least accept that they did reach an oral agreement with you and, if so, in what terms.
hi @peterw do you have this kit? How do you find it? I have a Makita 18V circular saw and thinking it may be a good way to avoid the cost of a plunge saw?
Hi @divorcingjack how did you get on sealing the floor? We are thinking of the same when we come to lay our slab but to use the Proseal W just after the powerfloat is done. Did you end up using this product? If so how did it go?
Hi @Visti how did you floor go? Any issues? How was it done?
Hi @Dudda we are planning to have our 150mm insulated passive slab as our finished floor surface in our new passive house. There will be UFH pipes laid 50mm below the surface. The company laying the slab will power float it to finish but have cautioned that they cant guarantee the finish. They have also raised the issue of cracking and recommended "expansion joints" but said that they wouldn't install these. From some reading I think I would probably need these crack or contraction joints you mention but my concern would be hitting a UFH pipe. Our slab will be on 2 levels and a total of about 150m2. Is cracking inevitable without joints? How bad could it be? Can cracks be filled if they occur? thanks
Hi we are planning to have a power floated slab as our finished floor surface. I was thinking of applying Sikafloor ProSeal W - https://www.rawlinspaints.com/home/floor-paints/floor-sealers/1542-sikafloor-proseal-w.html?gclid=CjwKCAiAmuKbBhA2EiwAxQnt72lVa5Y-KR9dS83fdH9pL4WPUkN7B6KcZVjnsokdhLAhIF5tM2oVfxoCrF4QAvD_BwE - after the powerfloat. How does the Sika product compare to this Watco sealer? thanks
Actually, I think I may just have found exactly what I need - https://www.tlc-direct.co.uk/Products/SF8909AT.html?source=adwords&ad_position=&ad_id=&placement=&kw=&network=x&matchtype=&ad_type=pla&product_id=SF8909AT&product_partition_id=&campaign=shopping_excluded&version=finalurl_v3&gclid=Cj0KCQiAsdKbBhDHARIsANJ6-jdkcwWJPpdPbp34vpSIt5vrNwm1uBoRWfpm-70j4HK5Bj9iTgLu_NMaAmNMEALw_wcB Would this work?
