dpmiller
Everything posted by dpmiller
the only water "source" that should be connected should be the mains supply at the blue valve end of the Toby. The connections in and out of the Toby are likely to be in blue MDPE, and the fittings on each end of the toby- deep underground- are generally 3/4"bsp IIRC
Mains water comes in at the tap end, the supply to the property connects at the other end, and whether a meter is fitted is irrelevant. Understand also there is a checkvalve inside to stop backflow. If you're unsure about the connection status you could try undoing the meter cap and opening the valve, to check for an early shower...
Play to win, Jimbo ?
- 367 replies
- ireland
- timber frame
@ProDave I dunno, but on this one the glass sits down onto the housing @Onoff 10x6m give or take. ?
- 367 replies
- ireland
- timber frame
Has all this time passed since I updated last? Wow. The plasterers were back, and we have now only the two small bedrooms and the entrance hallway left to do. Utility is habitable Ensuite near complete bar some tiles round the window, The other two bathrooms are useable but not quite as complete Cooker hood in, and subsequently a couple of units thrown into the kitchen too, just temporary mind. The hood was a mare to install, it's a heavy old bus and not being able to lift by the glass made it "awkward". Impressive airflow from it however so I'm chuffed on the whole. I'm hoping to test it at Christmas as we would like to have the festive meal down here. But that may or not happen as I'm at the whim of hauliers (yay brexit!) getting my range cooker over here in a timely fashion and in one piece... And yesterday got the slab poured for the forthcoming shed. Now, energy numbers stuff. Sure I've has the ASHP in since Feb or so but it's only in the past six weeks or so that it's been working for it's money. UFH is currently a big single zone with the control stat in the entrance hall at the mo, the rads in the two big bedrooms upstairs together with the towel rails, have their own control. Heating flow is 32C, DHW tank is 48C, and the tank sensor is about 3/5 down the 270l tank According to Jeremy's heat loss calculator monthly heat energy requirement is somewhere between 1250 and 1700kWh depending on the ambient temp. Total metered electric consumption for the past 30days is 600kWh Daily consumption by the ASHP according to the meter I've put on the supply is between 17 and 25kWh, the average appears to be about 22kWh which matches pretty well. So I'm pretty happy with that. COP looks acceptable, but I might be able to improve matters slightly still by altering the flow at the UFH mixer as the delta across the ASHP tends to be a wee bit higher than I want and I can happily slow down the floor response a bit.
- 367 replies
- ireland
- timber frame
same temp to all three floors?
Belfast sink - joining old waste to new 40mm trap and pipe
dpmiller replied to Oxbow16's topic in General Plumbing
if the rubber seal in that fitting sits in a recess, it may not seal to your dodgy looking waste. -
the grille at the back I'm pretty sure is only chromed, mine went a bit brown but when rubbed off it settled down. The corner, it might be worth giving it a rub with scotchbrite just in case the wrong wheel was used when buffing it?
any chance the top bars are fake, with no flow through? also, have you bled *both* sides at the top?
Real men braze their gas pipelines...
Wrapping a SIPs Garden Room 1.2w roll or 2.7w ?
dpmiller replied to Tooled up's topic in Structural Insulated Panels (SIPs)
how tall are the walls? -
F*ckWit neighbours strike again
dpmiller replied to Pocster's topic in General Self Build & DIY Discussion
if their line was suddenly faulty and needed replaced???? -
not that any developer would care, but how much extra insulation thickness do you need to counteract the cold air under the suspended floor?
I've seen those Wylex RCDs do odd things before.
Optimizing LG Therma V Controller settings
dpmiller replied to Hogboon's topic in Air Source Heat Pumps (ASHP)
night mode is likely to mean reduced output rather then any less efficiency. -
How handy are you with a multimeter? Unplugging (say) the fans and the compressor and re-trying could be a start but lookiing at that trip, I might start there.
It's more about the DeltaT tho isn't it? -
Sewage treatment plant - air blower electricity costs
dpmiller replied to David Essex's topic in Waste & Sewerage
ours does an aerate-settle-pump out cycle, the air pump is off quite a bit of the time -
On mine (which is built on a standard Carel platform as used in retail fridges etc) the fan, compressor, expansion valves etc are all under constant control, and the characteristics of the compressor and gas are programmed into it. I've no doubt there's some map in it that you could alter to improve things at the frost-point (or maybe it already does it, dunno) -
complex to implement as you're already at the whim of the inverter with all it's sensors and lookup tables. -
No they absolutely do frost up enough (in our microclimate for sure) and the difference between a light frosting and solid blocking ice is less than ten minutes of operation. -
On mine, the fan speed ramps up noticeably as frosting occurs- from 85% in "normal" full power operation to 100% when it's blocked up. But the defrost actually happens on a time and temperature basis. Based on @J1mbo's calculations re 24h operation I think I'll play at reducing what setback I've currently got programmed...
