dpmiller
Everything posted by dpmiller
Whistling through expensive Norrsken front door - Driving me crazy
dpmiller replied to boxrick's topic in Doors & Door Frames
check the seals extremely carefully, that kind of peak hints at a small opening in my experience -
and it's windy out there too...
"tread lightly on the earth"
I do a bit with Haier -80 lab freezers and they're very good indeed.
ASHP low pressure help pls
dpmiller replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
with a duff expansion vessel, even 80c could be enough to blow something. -
Oddly enough my experience with safety valves- autoclave sterilisers as well as other pressure vessels and boilers- is that the insurance engineer absolutely *must* see them lifted at every statutory inspection and will often remove and pump test them as well to verify the opening pressure. It's not unusual to find a valve stuck badly enough that more than the chamber's safe test pressure is required to break it free which is more than a small worry. Yes occasionally one will weep after this, but replacement is the cost of doing business... I routinely lift the valve of any unit I'm working on to confirm it's *not* stuck... -
Do safety/ multi groups not normally have a gauge on? If none is fitted might it be worth the OP getting a gauge and screwing it onto the PRV? -
150mm Composite deck screed alternative
dpmiller replied to bmj1's topic in General Structural Issues
Lewis deck? -
X3 Immersion heaters on a single radial
dpmiller replied to RedSpottedSev's topic in Consumer Units, RCDs, MCBOs
depends is it 16A real and continuous, or chinese... -
Befab, Hamilton Contracts, Fees, as a first try
- 1 reply
Floor slab insulation. Test my logic please?
dpmiller replied to saveasteading's topic in Barn Conversions
/board. A few years ago mind... -
when we were ordering ours, white EPS was £11.57 for a 50mm, vs £13.70 for graphite -
floating or sunk?
pennies, as I recall -
graphite EPS takes it to 0.031 or so -
whilst/ as all the stats and cutouts look after the safety side of things, I'd personally be thinking more about the possibility of (say) a stuck contactor going unnnoticed and the immersion taking over tank heating duties unknown. I certainly wouldn't presume that an SSR was totally trustworthy... /but then I come from a place where accidentally leaving the Willis on was punishable by death
Husqvarna stone saw popping and flames out of muffler?
dpmiller replied to flanagaj's topic in Tools & Equipment
is the oil/fuel ratio correct? What colour is the sparkplug? -
Another vote for a layer of EPS. Graphite if you can, it's even more gooder. -
how long is this 32mm run?
ASHP output will rise as the buffer heats, the system attempts to keep a constant DeltaT
Electrical meter box location
dpmiller replied to Kevan Marshall's topic in Networks, AV, Security & Automation
I don't have any answers, but do bear in mind that NIE can be a bit different to all the GB providers so... -
Does aerobarrier negate need for airtightness detailing?
dpmiller replied to SBMS's topic in Ventilation
doing it after boarding surely risks a "plasterboard tent" scenario?
