dpmiller
    4
Everything posted by dpmiller
  1. 50mm increments, plus a 270mm. It's all in the Blum catalogue if you look?
  2. there's a choice of standard sizes
  3. I'd pull the table out 6" or so, the wall is going to take a battering otherwise
  4. fan motor breaking down when it's hot?
  5. If you're really worried about the joint facing the "wrong" way you could always convert with https://www.ebay.co.uk/itm/116518332919
  6. why don't you just put the radon membrane lower down, straight across the whole area before the cavity begins? Then you can deal with damp above it at your leisure...
  7. isn't the export limit more about overvoltage in the local grid, in which case it could be a near-instantaneous issue...
  8. a plumber did that?
  9. where are the family's shoes stored?
  10. it's certainly something atmospheric.Are the ends on the flexis plated brass? Looks like copper corrosion there.
  11. bleach corrodes stainless. Any chance someone was a bit over-liberal with the airborne chlorine?
  12. yep roses and a couple of distribution boxes too!
  13. I used Klik sockets rather than 5A plugs
  14. yep, young'un here was asking for a better photo to work from...
  15. someone here might even be able to do it.
  16. 3d print a tool to sit over the head like a socket?
  17. yep, the first SDS I got when I started trading was a Kress from the B&D service centre. Still a cracking piece of kit...
  18. why not before? There's topsoil to strip anyway...
  19. are there only two lives going into that box?
