dpmiller
Everything posted by dpmiller
What's the case for not getting an ASHP?
dpmiller replied to kentar's topic in Air Source Heat Pumps (ASHP)
ignoring defrosts, with good control and a big coil (or PHE) the heat pump can act almost like a combi. But again, gotta define your flow requirements first... -
I like the first one best, just shift the wall slightly to shrink the utility. And do something with the back hall- does it really not have an internal door? Inlaw's bungalow is very similar to this. Loft is floored and the stair opening trimmed out and just PB'd over
Decommissioning an old brick septic tank - DIY or not?
dpmiller replied to jumbletons's topic in Waste & Sewerage
no, not at all. NI's water infrastructure might be crumbling, but us private plant owners get a free on-demand pumpout. https://www.niwater.com/need-our-help/arrange-septic-tank-emptying -
too much hassle to do it the legal way I guess. Do you guys not get one free pump out each year from the water board? -
and then do what with it exactly? -
Converting Section of Front Garden to additional driveway/ parking.
dpmiller replied to Charlotte22's topic in Driveways
does it really need a fence even? Hedge out, bit of surfacing, done. -
How best to cable for Washer and Dryer ?
dpmiller replied to Spinny's topic in Electrics - Kitchen & Bathroom
WMs generally have a bit of overhang on the rear of their "worktop", the actually chassis is a bit shallower... -
Multipipe Maxima FM 16-port manifold (..and 13, 14, & 15)
dpmiller replied to mikeysoft's topic in Underfloor Heating
yep. An hour of boost programmed into the immersion diverter means the ASHP can fill it's boots topping the slab up without pause. -
Clearance for a standalone washing machine
dpmiller replied to Question's topic in Kitchen & Household Appliances
yep. one big bath towel... -
you generally put two hoses into the plenum of one inlet/outlet if the duct run is long
defo sounds like refrigerant lines heading into the house...
Can't connect the SWA cable. Practical help please.
dpmiller replied to saveasteading's topic in Power Circuits
is that T&E? I'd be replacing that... -
maybe just buy one and then overclad the front to your preference? I dealt with C&S in Tullamore and they were very good, they make up their own panels with a shiplap style
same difference really
the perimeter of the cassette has a wrap of membrane pre-fitted before being craned in. It sits on the lower flap of membrane and then the upstairs wall panels sit on the upper. These flaps of membrane are then ready to be taped to the VCLs. Externally, the upper wall sheathing is draped down over it all and stapled to the lower sheath. In our case it was heavy gauge polythene, you can see it hanging down in this image. All the upstairs studs had a similar strip of poly over the top of them for the ceiling VCL to attach to.
to lap round the floor cassettes, at least that's how ours were done
looks like the door won't open much past 90deg so do you *really* need to move the hinge point?
McKinstrys are in a big way of going for Biomass, prety sure they'll take all and any timber
Planning self build, Northern Ireland
dpmiller replied to Kevan Marshall's topic in Introduce Yourself
Always remember guys that "UK" rules are often really only GB... @Kevan Marshall whereabouts are you, and have you done any heat loss calculations yet? We've a great tool ( Jeremy's) on the site that many have used to get a grip on energy requirements -
unless it came with a certificate, this is false- for any equipment.
have you space to batten that side wall out an inch or two, and shift the tray over a bit? Does the selected tray's waste have multiple outlet points?
things are different in the US...
Sweet spot when buying a digger
dpmiller replied to Post and beam's topic in General Self Build & DIY Discussion
Digger and dumper combo for me- 3CXs are great but not so much if the ground is soft or you need into a tight corner
