dpmiller
    4
Everything posted by dpmiller
  1. there are many complexities around linking a boiler stove into another scheme- will you have MVHR, will you be cooking on gas or electric/ do you want an extractor fan, and how big a hot tank have you room for? Even if you're only thinking about it, you better look at these things in advance. You may need e.g. a mains water supply going to stove for overheat protection etc etc
  2. We used Shiedel's Ignis Protect to deal with heat protection and airtightness
  3. is this just at the bottom, draped into the gutter?
  4. does the adaptor not unscrew to leave a 1/2"?
  5. MLCP fittings seal on the inside of the pipe don't they? I'd be tempted to fashion something up to put a crimp on the external sleeve- a U-bolt tightened down on it a couple of times maybe?
  6. ^must be simple if shaky-hand man can do it.
  7. £6 is 10 litres of oil these days, which would run the average oil boiler for about 4 hours?
  8. is "aircrete" actually noted tho? Ordinary blocks can come in 3.6N too...
  9. https://apc-gb.com/wp-content/uploads/2018/07/BS5252-Ral-Cross-Reference.pdf 7021?
  10. Defrost gets a whole section to itself within the engineer's menu. I found it was a bit aggressive for our location so have shortened the duration and extended the minimum time between defrosts. Plus the ambient sensor was a bit too close to the evaporator which didn't help...
  11. Don't think I've seen this posted before- it's a more full and descriptive guide to the settings on the Carel https://sprsun.nl/wp-content/uploads/2022/07/Function-description-of-DC-inverter-heat-pump.docx.pdf
  12. They're a local supplier, but the kit will be Garador or the likes. Can't assist on pricing as it was included in the cost of the shed. The two guys were here for a couple of hours. There's not much to the install, you could happily do it yourself. A lot depends on the squareness of the opening tho...
  13. The one in Nods photos is the same as ours, supplied for our shed by Garage Door Systems https://garagedoorsystems.co.uk/products/insulated-roller-doors/ foam filled slats, brush seals at the sides etc
  14. All our PB was Siniat, and I *think* it came through MacBlair (can't remember 100%, it was supplied under our TF contract...)
  15. Flexis are recommended regardless, but yes either a formed bend or a radiussed bend fitting instead of those elbows. Personally I'd try to minimise the number of those pressed fittings used where possible as their ID can be surprisingly small...
  16. Don't go near CEF or any of the other big boys, seek out a small indy wholesaler- or just go to Screwfix...
  17. sort that knot of restrictive elbows at the back of the outdoor unit and your issues will disappear, I reckon. No calculator needed.
  18. you'll need to help us a wee bit here- pushfit and solvent are different sizes, but some compression fittings can span both, not really a "brand" thing. What exact sink trap do you have there?
  19. the PWM connection is correctly made? It may not go into the mode if it's not seeing the signal...
  20. I'll bet on "none" and an easy grand profit.
  21. how could the insert come out if the nut was tight on the olive?
