Everything posted by markc
Help with my calculations, please. How deep should the foundation be ?
markc replied to ToughButterCup's topic in Foundations
I don’t have anything to do with groundwork’s or geotechnical but Just looking at this and my first thought is that the calculation would be for the minimum depth below the lowest point to prevent a slide or shear down the slope. that aside, min foundation depth is generally to get below a level that will be affected by movement from shrink, heave or frost etc. -
Very difficult to put a time on an unknown but let’s say we are looking at fitting a new hardwood door, as a SB’er you are going to be picky and scrutiny everything so we need to allow 3-4 hours. now let’s say you buy a similar door used, how well was it fitted previously? Do hinge pockets need packing or filling? Is it square? - possibly needs trimming on all sides to square it up, is it the right way? R/L opening? Allow a day faffing and fitting. basically, if you get a good door for free you should be ok to save a few £, but I would never pay for a used door unless it was an extra large one or something special
Cloakroom cistern frame + pipe hiding
markc replied to johnhenstock83's topic in Bathrooms, Ensuites & Wetrooms
Are you using a cistern frame? Or just hiding a separate cistern? If using a frame, that takes all the load of the cistern and pan so all you need then is panels to make the box, aqua panel (or similar) or plywood means no need for framing as other than to fix to wall and floor -
Nothing wrong with fitting a used door, but it needs a lot more thought and faffing than fitting a new one. If I still did jobs like this I would want double for fitting a used door (Unless it came still in its frame and had been removed in one piece)
It will be ok with or without tape, long before choc boxes they were done like you have and before connector strip were available it was done (and still is in a lot of industrial places) by twisting or tying the cores together and then wrapping with tape. We used to make even 33Kv (33,000v) splices and Tee’s by twisting and taping.
First thought was that H and C were the wrong way but if you have tried swapping them over it has to be a pressure related problem … insufficient for that particular mixer design maybe
With a truss you can span pretty much anything, but the truss/joist depth increases significantly as spans increase, trying to keep them shallow just introduces bounce … or more bounce. having re read the OP, 17m walls are fine but the floor will require some design input regarding lateral bracing.
660mm wide isn’t a problem and games consoles etc are quite low, distributed loads. 8mm toughened will be more than sufficient (take a look at the shelves supplied for cabinets etc.).
Capping a chimney which finishes in the loft
markc replied to tvrulesme's topic in General Self Build & DIY Discussion
If it finished at loft floor cap it off with a big slab of insulation and a weight to hold it down- 5 replies
- capping
- chimney stack
Leave the ends in the connector or if you want to lose it, cut cores to different length and then wrap with insulation tape (cutting to different lengths prevents any chance of stray “hairs” shorting across
Why are armoured cable colours different from twin and earth?
markc replied to joe90's topic in Electrics - Other
@joe90 what colours do you have? -
If you are not limited by ridge and internal height then that looks like a good option,
Is Solvent weld pipe into pushfit boss adaptor OK?
markc replied to MortarThePoint's topic in General Plumbing
Morning, as it’s boxed in I’m taking it as inside so I wouldn’t worry about it, outside where pipes expand and contract you do see movement and older buildings often have no chambers or inspection points so Down pipes can back up and that’s when you need the seals to work. In your case you are just looking for it to stop odours rather than backed up water and Sh1t -
Danger with pushing an oversized pipe into a sealing ring/boss/gland is potential leaks due to fully compressing the convolutions and potential splits and tears. The seals are designed to allow some movement and allow the pipe to ‘float’ around the centreline. solvent is best kept to similar materials, adhesive for bonding different materials -
Looks great! Well done sir
Effectively you are just using a garage so no building regs and not really a change of use so get on with it
Demolish bungalow and build new bungalow!
markc replied to Dave Anderson's topic in Introduce Yourself
Contracts can be as simple or complicated as you want, you detail what you want something to be/look like, type, quality style of finishes etc. when you want it doing and cost. The other party then agrees or disagrees and gives amendments then you both agree to something in the middle. we have customers with 100 page contracts for a £150k machine and other customers who will happily order 3 or 4 of them on a verbal/phone call or email. -
If you can go straight down behind plasterboard, remove kick board and reach under to make a hole, drop cables down then under kitchen units and back up to new socket location .. hopefully nothing in way behind PB
Hi, that doesn’t look like a new house. There is obviously a problem that needs addressing but difficult to even guess at a cause without more info, age, roof outside, what’s behind the stuff etc.
Correct
I would say the water is coming in under the wall due to the outside ground level. If it’s on the neighbours side and you can’t dig and install a drain then you are looking at tanking or drainage membrane on your walls and floor to take the water away.
8x40mm green wall plug - what size screw?
markc replied to johnhenstock83's topic in General Self Build & DIY Discussion
40mm screws won’t be long enough, you want 40mm min into the plug (I usually work on going through 10mm so 50mm in the plug plus depth of plasterboard etc (assuming plug is fully in the block behind) plus bracket thickness -
New Member .... need advice about upvc door fiitting
markc replied to proeto's topic in Introduce Yourself
No need for packing full length of frame, only needed at the fixing points and full length pack makes foaming difficult and air tightness almost impossible.
