markc
    22
Everything posted by markc
  1. I would have turned the cut ends of mesh upwards to give you something to tie uprights into and to keep steel away from sides of trench to maintain a decent concrete cover.
  2. In some cases yes! Looked at an old farm house recently .. it was ugly, poorly built, could see any unique or even attractive features but listed! And the plot would have been fantastic for a knock down and build
  3. Agree with @joe90 on this, a (well set up) table saw can and will be accurate to fractions of a mm. I can’t remember last time I used a jointer (flat bed planer) for straightening and levelling a board, I always use the table saw and rarely sand, or need to sand unless it’s for stain or varnish
  4. Yes that the sort of thing, Ty wrap is a cable tie or push conduit into box through hole and wrap tape around the end then pull back so tape prevent conduit pulling back through hole
  5. You can get “ends” for flexi conduit but they are usually pretty poor and pull out, easier to run the conduit straight into an adaptable box (Ty wrap or tape on inside to stop it pulling back out) and then go through back of that through the wall
  6. +1 on the above, a bit of spawling brickwork won’t hurt anything but to rectify the concrete needs to come out and find out what’s going on under the corner, plus I think the pipe is possibly gas supply
  7. You won’t get the variation with solid oak or solid anything, if cladding it may has well be a cheap soft stair but I can’t see cladding looking right at all. if you want the variation get it made from block oak worktop so you will get a similar look to the floor with smaller blocks.
  8. It will be diamanté phone covers, go faster stripes and they/them pronouns next
  9. Child labour … I like your way of thinking. now get off BH and get some bloody work done
  10. Overkill for the loads you are talking about but a hockey stick would mean you only need a small screw fix into bottom cord while the load is taken on the top face of the bottom cord.
  11. If you want to, and can fix a batten from top to bottom cord then this makes a very good fixing point, again there is no problem screwing into bottom cord but don’t ever notch it or drill a big hole through it. Bottom cord is in tension so removing material reduces its tensile strength.
  12. 30kgs as a frame is nothing weight wise for solid or engineered joists, if you were hanging a 30kg light fitting on one screw then I may be more concerned but your frame will be spanning 2 or more joists so very little localised load. If you can get access ok then screw through the web. If you are worried the bottom cord may come away from the web then don’t be, the glue used is incredibly strong
  13. Helical retaining units (screws) work well
  14. Weird! No idea at all
  15. markc
    Tarmac DIY
    +1
  16. markc
    Tarmac DIY
    Concrete and tarmac are both around 2.4t per cube. At 6 tonnes you are getting roughly 2.5cube of tarmac for £700 and for that you should get around 5-6 cube of concrete depending where you are. concrete would be better layed thicker where tarmac is flexible so less cracking with thinner layers.
  17. markc
    Tarmac DIY
    Got to agree with @Declan52 badly layed tarmac won’t last long and if it’s already cooling then you won’t get it to compact enough to keep water out which freezes and bursts it into pieces. concrete is your friend here, so much easier to work with
  18. As a store room it really comes down to load bearing capacity of the “floor” a sewing machine will create a lot of vibration and be almost impossible to use if the loft floor and structure are too flexible. do you have any pics of the loft as it is? Older property or fairly new build?
  19. No need for screed if UFH is in the slab
  20. Metal is more expensive per foot used but so much easier. If you are using timber, you don’t need to make nice joints so angle and T joiner plates make life easier and so do hedgehog plates (the ones used on roof trusses etc.)
  21. How do you know it hasn’t cost him more and he’s done you a favour getting the work done quicker if the roofer isn’t available for a few weeks or months
  22. Ah yes, wasn’t sure if you were going to have cladding etc. in front of the upstand as that always seems a waste
  23. Melting ice and subsequent rising sea levels would greatly reduce land area, maybe we need to dig deeper into sea farming (floating or sub surface)
  24. The upstand could be pretty much anything, it’s only there to stop the sedum falling off and woven geotextile will allow water to pass and stop soil particles
