Dave Jones
Everything posted by Dave Jones
put an elbow on it then run it through the wall. external soil pipes ......
drop one of these in https://www.bpcventilation.com/bsk-zephyr-single-room-heat-recovery-unit
Wind from ASHP on the neighbor's door - barrier?
Dave Jones replied to Garald's topic in Air Source Heat Pumps (ASHP)
mount it higher up on the wall. -
its surprising just how much is needed to drain a single slab, porcelain especially the textured ones love to hang on to water. You would be better of slotting it with a grinder to drain it either side.
Galvanised MVHR Ducting
Dave Jones replied to tuftythesquirrel's topic in Mechanical Ventilation with Heat Recovery (MVHR)
as your going for the industrial look anyway id just use a large metal factory type plenum and make feature of it. -
neither, megastick.
estimators.com dont play around with massive costs, do it properly.
heres a tip for materials. You need to find a local building firm, the type that has 3 or 4 blokes on the books. Have a drive round the area, they build single houses, decent size extensions that sort of thing. Approach them and explain you are self building and are being bent over for materials. Ask if you can use their rates at jewsons/trav etc and you will pay them cash of half the saving. Get a price from the merchant for the usual 20 items timber, boards, cement, insulation etc and see what they paying. work out what you need and give them an up front couple hundred quid and couple cases beer. You will be buying some good faith, they may even answer the phone and recommend trades to you.
as long as you have a proper VCL under the kingspan and sealed down onto the internal wall it will be fine.
ive got the milwaukee cordless stamper, very nice and light.
Basic building regs question...
Dave Jones replied to Beanyboy2802's topic in New House & Self Build Design
not allways, if you have windows in that elevation for example you can get away with it. They look terrible so avoid. -
How to detail PIR at the wall cavity / wall plate in this situation?
Dave Jones replied to Oxbow16's topic in Heat Insulation
looks like a cold roof. dont block the airflow by insulating tight to the underside of the felt. -
MVHR is Largely Bogus
Dave Jones replied to DavidHughes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
kind of my point duh. -
running cost isn't relevant. What's the running cost of a £20k kitchen compared to a £40k kitchen ? -
timber frames are utterly pointless unless you plan to have the whole build finished in 12 weeks. Zero point paying over the odds to get watertight in a week if it then takes another 9 months to finish before you move in.
As long as the truss supplier can make the hips as well. The problem is the height above plate being soo high that you would need 800 deep timber to hand cut it! I do like them for the reason you mention, makes insulating and ventilating over wall plate a lot easier.
- 1 reply
Internal doors for a flat , do they have to be fire doors?
Dave Jones replied to vcps2021's topic in Doors & Door Frames
have a gander, refuge rooms, protected areas etc. flats need a lot. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/1128493/Fire_Safety_in_Purpose_Built_Blocks_of_Flats_Guide-update.pdf -
How to support a (block and beam) beam at one end
Dave Jones replied to Thorfun's topic in Floor Structures
stud/timber. -
Best place to buy Heras fencing
Dave Jones replied to Meabh's topic in General Self Build & DIY Discussion
ebay, side of road, etc its also dirt cheap to rent from the hire places. They do a deal for long term. -
Enough screed to support weight of car
Dave Jones replied to Post and beam's topic in Garages & Workshops
yes will be fine as long its not a tank! -
Wardrobe carcasses: Alternative suppliers to Ikea?
Dave Jones replied to Adsibob's topic in General Joinery
cutwrights can make you a flatpack to any design you make. It does need you to do the measuring/design part though. -
yep architects are clueless, you could have saved money and got a much better insulation value by using 300mm of EPS instead.
isnt your water usage plan already covered by your planning application ? You will need to perform a SUDS test to see if the ground is suitable for a soakaway and how big it needs to be.
Screed thickness with UFH, over PIR. How thick?
Dave Jones replied to saveasteading's topic in General Flooring
never use liquid screed, always dry.
