Dave Jones
Everything posted by Dave Jones
doesnt effect plastic. only organic matter.
a mornings work dig out a channel behind the wall, blackjack it, dpm then backfill with pea gravel.
First floor UFH on Beam and Block - Insulation issue.
Dave Jones replied to MMcGill's topic in Underfloor Heating
the goal should be build the house right so the only heating required is the ground floor slab. if the heat losses mean you need more than the thermal envelope isnt good enough. Can see why the regs are written to cover the legoland builds which make up the majority of new build and are crap as we all know. -
Can the BCO require a job to be done by a given date?
Dave Jones replied to ToughButterCup's topic in Building Regulations
only had to kick a BCO off site once and that was to prevent him being done injury by a brickie who he was trying to tell his work was wrong (it wasn't). brickie 55 bco 21 They are theory merchants only, very rare you get an experienced one i find. -
second vote for this. it melts anything.
yes they can ONLY if its a defect found on the final inspection. -
make the hallway narrower and the lounge larger.
yes this is a little barmy but 30mm of EPS will help with sound transmission I guess, just need to allow for the FFL on intermediate floors now as well... or put the pipes in without insulation and just dont connect them at manifold. sign off then re-connect. -
Streetfield Flat Roof Warranty
Dave Jones replied to Streetfield's topic in New House & Structural Warranties
what make of VCL are they using ? -
dont pay his bill. Ask him to be a bit more professional and send a typed copy. too many of these clowns taking the pi$$ for no reason.
heat rises etc. -
id be more interested on the design of the warm roof, what VCL and where etc. If its a parapet wall how the capping will be detailed. EDPM every time over GRP for me. -
another vote for pozi's. correctly glued deck doesnt squeek and they bounce less than beams. -
is the land owner upstream or downstream of the tank ? If downstream surely you can just connect to the existing pipe without any need for permission from them ?
you dont need insulation on the intermediate floors. Get the shell airtight instead and you be laughing. -
nope. you dont want to trap moisture in the house unless you have something to remove it. a cold roof removes it.
100mm spacing max for low flow temp. put the loops everywhere, excluding chunks of the slab just reduces the overall efficiency by making the surrounding loops work herder.
The costs between the two are not small. But i agree warm is better but has more potential for problems if not done correctly which a cold roof doesn't.
