Dave Jones
Everything posted by Dave Jones
Vaulted roof insulation condensation risk?
Dave Jones replied to LinearPancakes's topic in Heat Insulation
Inflation is killing my build
Dave Jones replied to farm boy's topic in General Self Build & DIY Discussion
timber prices coming down. overspend suggests your initial budget wasn't realistic. -
not in the pictures, unless its a hobbit.
massive soffets, look at the size of those trusses. 75mm would have been plenty.
if the two plots are the same planning permission starting one starts both.
break out the concrete, couple of clay to plastic collars, fit a Y and a new chamber. A mornings work tops.
the way that is detailed will fail building regs, the roof insulation needs to be brought down over the internal wall insulation to make a continues barrier. your wall plate is now a massive cold bridge. I wouldn't have bothered with PIR and instead stuffed as much rockwool into the eaves (after fitting the eaves ventilation trays). You will get a better U value for much less money and its easier to do. Warm roofs have their place where the room has to be habitable but are expensive and labour intensive to get right with correct vapour barriers etc.
and looks crap on a pitched roof. Not acceptable for a lot of builds in conservation areas.
that U value fails building regs need more insulation. -
edpm is not hard to do but there is a skill to do it so it looks good (no creases, wrinkles, pigs ear corners done properly etc). Unless you want to use the roof as a balcony dont bother with a top deck and use glass fibre faced insulation which you can bond directly onto (it will take foot traffic to install). Also rubber is bloody heavy and you will need another pair of hands. An alternative edpm solution that is much easier to install on your own is resitrix. It comes in rolls and goes down exactly the same way but is easier to handle and depending on the roof size/shape you get much less waste. The main moneysaving job we all can do as long as you can do math and are reasonably fit is is the groundworks/drainage/footings. A man in a digger is peanuts to hire and he will have a laser. He also probably has a couple mates who would come for the day to help concrete.
Steel post structure dilemma
Dave Jones replied to Streetfield's topic in General Construction Issues
get a grinder and cut it out, looks totally pointless. -
https://www.screwfix.com/p/mcalpine-push-fit-drain-blanking-cap-black-110mm/4331v Weird they dont fit for you, push a short length of 110 pipe into the socket then stop that.
Warranty or PCC for a new Self Build?
Dave Jones replied to JAS-Build's topic in New House & Structural Warranties
architect cert more expensive, 10 year more hassle. -
from my experience of both over many self builds, I now never bother with either. When it comes to sell and if no warranty is a deal breaker for the buyer i take out an indemnity policy. Last one was £750 -
ahh its a outline only plot. You could still comment but the council would likely enforce against you.
putting the insulation under the conc was a mistake. you should have put it on top of it and made it 300mm EPS but you are where you are. get the pipes stapled to the conc somehow (trays ?) and screed over.
Dig a single wall in have it inspected. or roll the dice on a planning refusal once it expires, £4k will seem a pittance then.
Are these costs realistic for a 500m2 house
Dave Jones replied to miike's topic in General Self Build & DIY Discussion
25% is too low to be realistic. -
megastick. make sure the timber your fitting in the web is a tight (hammer it in tight) fit and plenty of megastick.
very intersting, we are in the process of planning our own mvhr and your post has answered many questions. We are looking at the Zehnder Q350, UV and hepa filtration with Comfopost CW6 air chiller for ASHP cold feed in the summer. Did you look at alternatives before choosing the titon unit ? Any pro's cons ?
Low energy retrofit - Architect cost
Dave Jones replied to anonymous's topic in Surveyors & Architects
Bit worrying they don't even know the correct term for passivhaus retro-fit, its Enerphit and has a complete spec and phpp sheet. Ask them to show you a completed one they have already done and visit a property they have converted.
