Dave Jones
    11
Everything posted by Dave Jones
  1. we have cooling with fancoils. dont go too mad and overcomplicate it. IF your insulation and air tightness is good, running the ASHP running at dew point +1c (15-18) 24 x 7 through the underfloor and fancoils at virtually no cost keeps the house perfect. Extreme cooling is only needed for short blasts where heat has been allowed to build up which is a design failure.
  2. we have the separate neff downdraught in recirculation mode. MVHR plenum (has its own filter as well) is a few M away from the island as well. Works very well but not cheap.
  3. back to the first step. Post up your heat loss calcs they have done and advise your house build type, level of insulation etc.
  4. i would ditch the stone cill as it will chip and stain anyway. get a stub cill from the door company then you can run a slim slot ACO tight to it and slab tight as well. You end up with a small 10mm drainage groove which looks much better aesthetically.
  5. nothing has come down that much, lots are going back up - insulation for example. Inflation.
  6. another fantasist. Build cost using real trades and merchants are from £2k m2 for cheapest of cheap builds to £3k for legoland type finish. Obviously making parts of the build free will give you a false picture unless your work has no value.
  7. they are re-inventing the wheel. We use a bog standard cylinder with an external plate heat exchanger. Heats 300L tank to 50c in less than 30 mins. Can also daisy chain more cheap cylinders as required for capacity.
  8. point is you don’t need fall with a pumped chamber , they have a head rating. Also they come with a non return valve.
  9. dont bodge it with macerators. pumped chamber is way to go.
  10. the noise is a direct result of the pump having to work too hard. Get the house ready first. cart before the horse.
  11. think of it as trying to only heat the top left corner of a radiator. The rest leeches form it and therefore requires more energy killing efficiency. Same with a slab. not rocket science.
  12. i have an air nailer for fencing as coils of stainless steel nails are less than half the price of paslode. Run it off a dewalt battery compressor.
  13. warranty provider will want it built NHBC compliant which means trays. If you have in writing from recticel that its ok not to use them and they will fully warranty your structure for damp then fair enough.
  14. The dreaded cranked ceiling. No insulation there and sure enough mould grows. those cranks should have trickle vents , would 100% fix the issue
  15. That’s fine but you are wasting efficiency for no gain.
  16. as long as it has the minimum fall of 13mm per M, has no big (more than 30 degree) bends so it can be rodded. Crack on.
  17. if you have had a BCO inspection then the permission has commenced end of conversation. If enforcement are soo thick as to challenge you on that, advise you will be appealing their enforcement (its free) and asking for full costs award. Unfortunately the public sector attracts utter failures unemployable in the private sector, knock them down a peg or too when you come across a really special one.
  18. shed build unmortagageble unless very carefully looked after. Never worth it in our climate and market. In USA where land is cheap and they get blown over every coupl years make sence to cheaply shed build.
  19. thats old gas boiler UFH design. You want 100mm spacing and every inch of the slab piped. No missing out baths, under cabinets etc. No zones either.
  20. physically remove all the stats, any zone controls, timers etc. Get back to just the heat pump controller and set it to weather comp.
  21. nothing stopping you making the usual repairs to the structure that coincidentally make it fully structurally sound at the same time adding some lean-to's increasing its footprint. All prior to planning, who's to say when any of that has been done 1 month or 10 years ago ?
  22. the electric one is ok for occasional DIY use but are waayyy to heavy for daily use. Paslode all day long.
  23. you don't have to actually build the extension to get the planning benefit, the council knows your PD rights. Go for what you actually want first. Get a planning specialist (not an architect) to do the application as they will make it appeal ready should it be needed. Appeals are free and give you 2 bites of the cake. Fallback is your current PD rights so nothing at all to lose.
  24. Our council make it a planning decision condition to fit them.
  25. we have 220m2 slab, this is new build so no historical data!
