Dave Jones
Everything posted by Dave Jones
Fan Coil Units for use with a (cooling) ASHP
Dave Jones replied to ProDave's topic in Air Source Heat Pumps (ASHP)
these are what we are using https://www.bpcventilation.com/panasonic-fan-coil-unit -
Buffers kill efficiecny so no to that, have a LOT of ufh like 1.5km as its 100mm spaced which they tell me is more than enough so buffer not needed. Just cooling the slab makes a massive difference downstairs, basically any solar accumulation is negated. We have big bifolds which catch the sun all day, the floor would be very warm without it. Here is home assistant app, it pulls the date direct from the aquaera heat pump. The fancoils are not aircon by any means but cost virtually nothing to run as its only spinning a tiny fan through a plate heat exchanger. I left them on 24x7 with 16c flow and the bedrooms were very comfortable. MVHR we commissioning tomorrow, not expecting anything from the heat battery really but anything helps right. More for winter use. -
It's the other way round. We have this exact setup working at the moment with 7 fancoils and UFH coil. We have the ASHP setup (we use Home Assistant to automate everything) to provide cooling 2c above the current dewpoint running 24x7. Dont need it for DHW as eddi and solar more than takes care of that. The fancoils (panansonic) can individually be turned on and off. Thy are just dumb radiuators at the end of the day all your controlling is a fan. Commissioning the Zehnder unit the weekend which has the intake cooling/heating battery also in the ASHP loop so will see how that assists as well. -
No building regs for existing porch for house purchase
Dave Jones replied to SilverShadow's topic in Building Regulations
get an indemnity policy to cover it. cheap as chips -
simple rectangle box, you may need to drop a couple grand on an SE to spec the retaining wall but the build is pretty simple. ie 150mm cavity make sure pozi joists are specced at least 225mm deep so you can get ducting/soil pipes through minimum of 150mm insulation, 75mm screed below DPC get SAP calcs done these will specify insulation and critical elements such as lintels, cold bridging spots etc will have to fireboard the garage as its below your living area. Not sure why there is a cavity wall shown between garage and hall but its wasted space. simple block build really that should go up fast.
Thinnest wall type with best U Value
Dave Jones replied to Pappa's topic in General Construction Issues
and treble the price. -
extensions have less strict regs applying so you can get away with 100mm cav and mineral batts (cheapest). New build you can still use 100mm and celotex but this is a worse and mor expensive build solution than 150mm cav and mineral batts. -
Laying Porcelain Patio or New Fence first
Dave Jones replied to AChristie's topic in Landscaping, Decking & Patios
and keep the fence post conc 100mm below your slab level so they sail over the top. -
You dont actually need construction drawings done by a 'professional'. Depending on your enthusiasm you can just use planning drawings, elevations and floor plans. These are enough to get it QS'd as long as you fill in some blanks. Build type, materials to be used, foundation type etc SE is only needed if your footings are non standard or you need steels. Everything else BCO can do. Put up your plans so we can have a look, no point blowing £18k on useless architects drawings which will be wrong anyway when it comes to build them.
another + for render and timber as outside skin .........
Unlevel Foundation Solutions
Dave Jones replied to nikki's topic in House Extensions & Conservatories
is the floor or the walls out of level ? Have you checked its square ? -
d4 expanding glue, can put a couple screws on the starter row. I never bothered with any more anywhere. Floor is rock solid.
Is a private drain allowed to run through footings?
Dave Jones replied to Dan92's topic in Foundations
is it shared with anyone else ? Guessing it is otherwise you could simply move it. In which case its more than likely adopted and you will need build over permission. -
using a switchbot, 2 actually, 1 upstairs 1 down. https://uk.switch-bot.com/pages/switchbot-meter-plus Made a simple automation to fire the Aquera and move target temp to dewpoint+2
vapour barrier wont help. I have set our to be dew point +2c automatically in home assistant.
exactly what i did with our aquera. Home Assistant gives more control over it than the Panasonic app!
carpet on it!
