Everything posted by PeterW
Yes can be done - check this list https://www.altecnic.co.uk/domestic/solar/vessel/156/
no - the case law is clear ... no potable water supply, no rateable hereditament... Final demand or not, they can ignore a letter but if you go to court and say “I sent this xyz, here is the statute reference and here is the case law” then they don’t have a leg to stand on as this is civil law ...
Neither the acts of parliament or the case law has been amended in the past 5 years so it is still valid as a defence unless you know otherwise ..?
So they legally can’t do this - and there is case law to stop them. @Jeremy Harris can advise the exact bit, but it relates to a property not meeting the requirement of being a rateable hereditament if it has no potable water supply. Connect the water last to the house and it cannot be rated until that is done and Council Tax cannot be charged.
OpenReach and flyover rights.
PeterW replied to epsilonGreedy's topic in General Self Build & DIY Discussion
not that I am aware of ..?? I’ve only ever paid the new connection fee of £50. -
Not sure why the neighbour is grumpy as the most he will pay for the connection is £50... -
My last roofer had the apprentice empty and clean the van on my site ...... the apprentice dumped £150 of scrap lead in my skip that promptly made its way out when they left ..!
Sounds a bit odd ... you either need a lot of joists, or they have been priced wrong. Is he certifying the joists then as they will need to be stamped either C16 or C24 for strength / span purposes.
You can get a 40A RCBO in any of the boards but from memory, a conversation with @Jeremy Harris advised against that due to the constant current draw over a significant period of time.
New Kitchen/Living extension. Brick & block or brick and timber?
PeterW replied to Triggaaar's topic in Brick & Block
Yep - anywhere you would use adhesive -
I’ve used the Contactum ones from TLC-Direct 20 Way
This stuff DryFix -
It’s a standard PVC welded membrane so needs proper detailing. I would expect a lot of the cost will be in stuff such as the pre-made corners etc. I don’t think that’s a bad quote for a roof anyway - assuming you’re putting down a ply base beforehand ..?? What is the insulation spec and detailing ..?? And how are you forming the falls ..?
Because I don’t like the idea of the shear strength of the foam being the only thing holding board and foam on, and the PIR backed plasterboard is 25% more expensive than the two products combined. That’s a lot to pay for gaining a little easier fixing. If you go that route then I’d consider the foam bonding rather than dot and dab - it stops the big gaps up the backs of the boards. -
Full VAT payable then as it’s only VAT exempt if they supply and fit. That would be a big chunk of capital to be waiting on reclaiming.
@john0wingnut how do you get the power wall to be the source for the out of E7 hours heating ..?
..... in 2026.... Why rush these things ...
Cable: for Connecting a transformer to an LED strip
PeterW replied to ToughButterCup's topic in Lighting
@AnonymousBosch 2 core cable here Grippa connectors here I get all my stuff from them, buy the profiles and the strip - even the trade stuff is very good. -
You can buy the correct cable and the connectors for this and it makes connections a doddle. -
Extracting hobs..... seen this?
PeterW replied to EverHopefull's topic in Kitchen & Household Appliances
Most of the IKEA appliances are manufactured by Whirlpool or Electrolux, induction hobs share a lot of components with the basic branded models. -
Don’t buy the knock offs from Toolstation - definitely not as good. I buy all mine from CPC now anyway as they come in singles. Buy what you need and over £8 is free delivery
Or cost ...! HG is probably 150-200% the price of Crosswater and is probably a bit better quality however not that much ..! on the other end of the scale, I’ve just fitted a load of Twyford brassware and very surprised at the quality on that at the price point. Remains to be seen how it lasts but initial thoughts were it was very good quality.
Agree with @Roundtuit - you can also use glass fibre “sausages” that push into the gap too as a fire break and insulation combined. Think @TerryE used something similar.
