A_L
Everything posted by A_L
@ProDave , @SteamyTea I had a Philips microwave that had a slowly rotating metal 'fan' below a microwave transparent floor which distributed the microwaves instead of a turntable
@RobLe,unless there is a heat source in the garage the insulation will do very little. Poor air tightness in the garage and uninsulated walls will strip the heat away. Is there EWI on the house/garage common wall? If there is there will be even less reason to insulate the roof as there will be less heat entering the garage
Bifacial (two sided) panels might be worth investigating, even a North-South fence? https://www.solarpowerworldonline.com/2018/04/what-are-bifacial-solar-modules/ just search for 'bifacial panels' for manufacturers
Yes, plus your view on energy price inflation ?
This will reduce heatloss by about 2-2.5kWh/m2/yr, so the question is, how much will it (cumulatively) cost to put 2-2.5kWh of heat into the heated space?
If you mean the bit of the gable which will become an internal wall then breathability is irrelevant. Insulation on the sandstone wall along the line of the new extension's perimeter would increase the path length for heat using the sandstone wall as a thermal bridge and increase the surface temperature of the sandstone wall in the region of the extension's perimeter, reducing the risk of surface condensation in cold weather
As a one storey building originally built the walls would represent 20-25% of the total heat loss, the ceiling would have been around 30% but even 100mm of insulation would reduce this by 85%. The windows would have been 15% max so new would reduce this by 50-75%. 75mm of PIR/PUR insulation on walls would reduce their heat loss by over 90% Assuming no interstitial condensation in the structure then 'breathability' is unimportant
The U--value of a wall with 100mm of EPS EWI but a clear cavity is about 0.21, with a cavity filled with silver EPS beads is about 0.16. So not an insignificant improvement, particularly if you can get it at a subsidised rate. The EWI will handle the rain /wind and a clear cavity unnecessary. There is also the possibility that the cavity is ventilated and you would lose some of the insulating effect of the EWI
The SAP software uses data from the Products Characteristics Database (PCDB) https://www.ncm-pcdb.org.uk/sap/searchpod.jsp?id=17
The energy use of cookers and appliances is not included in SAP Here is a decent overview, https://ggbec.co.uk/sap-an-overview/
@Cpd, no air gap increases the heat loss by conduction A 25mm air gap without reflective surfaces has a thermal resistance of 0.18m2.K/W, an air gap with a low emissivity surface 0.44m2.K/W. 25mm of PIR has a thermal resistance of 1.09m2.K/W and 25mm of EPS about 0.7m2.K/W. pages 19/20 of attached PDF BR443-October-2019_consult.pdf
@Eric, provide floor dimensions (or exposed perimeter), and floor area and I can calculate U values.
Wrap Around Extension - What Insulation should I use
A_L replied to Ambaz79's topic in Heat Insulation
If you must have 0.15 then take a look at Walltite, and injectable polyurethane foam from BASF. A filled 150mm cavity will be around 0.14 but it will not be cheap. -
@WGL , try the Energy Saving Trust, they maintain lists of suppliers in your area. You might even qualify for a subsidy (0800 444 202). If you are fitting EWI as well then there is no reason not to use blown fibre (e.g. supafil from Knauf)
except that your wall has other elements as well as insulation, you have to add the R-values of these to the insulation R-value and take the reciprocal of the total R-value Yes it is meter.Kelvin, actually that is quite a high value, but O.K. if allowed for. The compressive strength is usually the force required to compress the material by 10%, again this is an unusual value see attached pdf KayMetzler EPS.pdf
Remember to use internal dimensions when calculating the exposed perimeter and floor area.
- 25 replies
- polished concrete
- insulation
You need to search for 'Willis Immersion'
Looks like you have a blown mineral fibre, e.g. https://www.knaufinsulation.co.uk/products/supafil-40 With a thermal conductivity around 0.04W/m.K it is good enough that their is no cost effective replacement or anything you can do to improve it.
Because it would alter the physical properties of the install. Particularly they sell it on air-tightness, removal of the 'skin' that forms could significantly affect this. The thermal resistance would also be affected by this, it may also affect the vapour resistivity although this fairly low anyway, probably not critical.
@JillyFind out from someone who knows, (not me) about the minimum thickness for sand/cement screed with UFH pipework. https://web.archive.org/web/20161103034245/http://screed.it/sandandcement.html
Hello and welcome, That number is most likely the thermal conductivity of the polyurethane not the U-value of the whole panel. The U-value of a 150mm panel is likely to be a little below 0.16W/m2.K
PIR, particularly if it has foil layers is virtually a vapour barrier. I would check the underside of the sheets for condensation, particularly if above toilet/kitchen. Probably O.K. if you have a formal vapour barrier but maybe not if you have a 'breathing' construction, I would check carefully.
Airtightness membrane for Tony Tray.
A_L replied to crispy_wafer's topic in General Self Build & DIY Discussion
Assuming insulation outside the polythene then no. For longevity use heaviest gauge polythene you can get (DPM). -
Hello and welcome, Just to confirm this is an air-to-air ASHP with heat distribution by metal/plastic ducts? In this case covering the ducts with more loft insulation is fine except of course for any future access. You should aim for at least a total of 250mm of the usual fibrous loft insulation.
- 5 replies
- ashp
- insulation
(and 2 more)
