Everything posted by Simplysimon
everyone thought they were rhetorical questions.
Jerry-rig an MVHR unit - how?
Simplysimon replied to Dreadnaught's topic in Mechanical Ventilation with Heat Recovery (MVHR)
i beams with smartply glued and fixed to the face with every joint glued? then a good foam (illbruck fm330) and seal everywhere (illbruck sp925) just in case? -
depends upon where you live
just add water to keep the dust down......
so not as installed and a bodge
get him to notch the face of the insulation so it runs continuously
please enlighten me
Internal blockwork: spec feedback
Simplysimon replied to bmj1's topic in Bricklaying, Blockwork & Mortar
yup, unless you want to go back to using cut nails -
looks like wet rot but need more/better photos and detail as to where the stairs are to help you
looks good, should have gone with hooks though, nice and easy to replace any. bend hook, slide slate out slide new slate in on a slate ripper to catch the top of the batten, bend hook back, job done. try that with double nailed slates.
Ridge Tile for Cross gable roof section
Simplysimon replied to jack1962's topic in Roofing, Tiling & Slating
'fraid not, angle grinder, 7mm drill and a long screw at the end cut to shape with some foam and/or stainless mesh to stop anything getting in at the cut. -
angle grinder and cut to shape -
yup, it does look good, almost like new, however, the roof on the left looks 'more settled in it's surroundings'
i would use a chop saw but would never advise someone else to do so 😉
Air Fryer Recommendations
Simplysimon replied to Ferdinand's topic in Kitchen & Household Appliances
got a ninja 🥷 but for 4 was a bit small, still got it as wedon't get rid of anything! then got one rom lidl which is bigger and has a rotisserie option foes lovely chips and cooks a 1.2kg chicken in 40mins. well worth getting one, a lot cheaper to run. -
New series of Grand Designs 31st August 2022
Simplysimon replied to Thorfun's topic in Property TV Programmes
some of us don't broadcast our mistakes, but it's good people have the spheres {yellow?) to do so -
looks good cleaned, however, with the moss covering i think roofs blend into the landscape a bit more especially in the country, home for bugs and food for birds but obviously gutters need cleaning.
for slate? just used a slate knife
says the person self building a dungeon with house above. strewth.
these?
fit a roof window in close proximity, will let you onto roof to do repairs at the same time
