Simplysimon
Everything posted by Simplysimon
  1. so what do these 'kit' companies actually do then?
  2. if it's going to cost £24 a day to heat an insulated room, then i would suggest a log burner is the only way they are going to achieve the 80deg temp they seem to want.
  3. part of your problem is that you don't know whether it was the missing cowl and loose pointing which was causing the damp. it's possible that it was, though an absence of damp further up the wall would suggest it may not have been. as @markc said get builder out to check. the other option is to dig out below dpc to see if there is high moisture level below which could potentially show a failed DPC.
  4. got to disagree with that, all of that is someone who want's everyone to come in and go 'wow'. if the finish isn't great it still won't be high end, just a house someone wanted to impress others with. as @Jilly says, style and taste with also care in the detailing.
  5. anything over 500mm?
  6. lobbing it over the 1100mm handrail? child with small head should not have been below
  7. along the bottom of the balusters to stop anything falling. if balusters are 95mm apart then no need for kickboard. you will need some method to stop bottom of balusters moving though
  8. whos design? why no fascia and why the birdsmouth on the inside of the wallplate?
  9. any space on a stair which includes handrails, and therefore this, must not allow the passage of a 100mm sphere
  10. first house we bought, putting an extention up, dug up concrete at the back of the house and found one of these still in fairly good nick, hardly any rust but the handle is not the best
  11. and how is that fixed?
  12. yup, most things cook in about half the time stated on instructions, cooks a 1.2 kg chicken in 40mins
  13. and for the technophobes, lidl have water levels for £4.99
  14. don't need to go looking for the para cord then........
  15. when life give you pigeons, make a pie
  16. a level gutter, depending on length and depth, will run before it overflows. if you can't see it from the grouind it's fine.
  17. ahh, H&S at it's best! what about a stair co for wire and fixings? tbh they may just get it from chandlery and re-sell
  18. being really pedantic, they are, just smaller triangles. don't worry about being pedantic there are far worse on here 😂
  19. why would you think they woudn't? new build or refit? if a new build would need the 838mm for access
  20. don't know about that as in pic 4 it looks as though the the birds mouth on the rafters is still at the wallplate
  21. that was my take, however, i can drive in comfort for 5-600 miles without a break and arrive just as refreshed
  22. and how does that differ to an ICE?
  23. marketplace
