Roof build up insulation ideas.
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
I have seen this type of membrane, did you like it ? did it seem to do what it said it would. @Mr Punter -
The specifications for the sheet roofing is that it must be fitted to a flat solid surface, minimum 18mm thick for fixing purchases, no battens as you would distort the sheets being completly flat with just the standing seam used as a joint, without a full flat fixing surface I think you would notice every ripple and wobble as it dipped and humped over the battens. -
evening. The other day I posted this up and had some good responses, ( thank you everyone) however most of the answers where regarding the actual fitment of the metal roofing and whether I should fit a counter batten and air gap or not. What i would be interested in is people’s opinions on the insulation side of things, is it enough? would you go for method A B C. a couple of things please don’t suggest cutting lots of kingspan to fit snugly between those I joists as I may climb through the computer screen and strangle you. any thoughts mr @JSHarris Apart from that I am open to any suggestions. Cheers russ.
Do you know you have bats? is it just an assumption because you have an old building we had an old timber building, and before our ecology numpty turned up all signs of the little black things had been tidied up.
Whoever it is make sure you don’t fit it like that picture
This could well be the case but Why would you take the chance
if doing any grinding near that door YOU MUST fully mask the glass and frame any sparks can etch into the face of the glass you can buy 8x4 sheets of very thin floor protection plastic
Reservoir Levels rapid Changes
Russell griffiths replied to Ferdinand's topic in General Self Build & DIY Discussion
The problem is we have no concept in this country on how to conserve water go and live in Australia for a year and you will look at things a bit differently HOSE PIPE BAN. you shouldn’t be using it to water your bloody garden in the first place put every house on a meter and I bet people change.- 45 replies
- reservoir levels
- cumbria
(and 2 more)
Bugger me I’ve never seen one of them. ??
So as the title says i have seen a product on you tube for fixing fence posts, that is an expanded foam type stuff that got poured around a post anybody seen it or know where to get it. I have a couple of loose gate gate posts that are moving due to the clay cracking around them and a series of 75mm wide cracks around them that would be perfect if I could pour something down them.
As far as I am aware the yellow mdpe pipe is only for up to the meter, not internally.
Are you not confusing courses with a wall, just because it looks like a wall doesn’t mean it has any bricks that picture you put up of the part built house with the triangle windows has not got any brickwork around the windows you will probably find it has the timber frame(structural) then a dummy frame or just packed out timbers to bring the outer face in line with the lower portion. Does potton not supply these details to you ??
I think you will find all those lintel you have looked at rely on having a good amount of brickwork above to aid in the structural integrity just like an arch. If you have very little brickwork above, you will need to think along another line.
If it’s all timber and rendered can you not use a glue lam beam and build all the exterior render boards onto that. With the portion between the windows in timber and clad in render board.
We used a retired architect who works on an hourly rate £25 per hour when we approached a couple of local architects practices they where looking for £25/30 grand for a full design and over see type of package. ??
After having a good look on the tracpipe website, it states that for all LPG installations any pipe entering a building must be above floor level can you shed any light on this @Nickfromwales is LPG heavier than natural gas or something so they don’t want it in a floor void. If this is the case it looks like I will have to run it surface mounted across the garage like @Alexphd1 suggested. Bloody hell life shouldn’t be this hard.
If you say rusty steel can’t you use that as a cover over something more structural so stone, brick concrete with rusty mesh in front.
Have you thought of gabion baskets with a brown coloured stone i have seen plenty of those crib walls and life expectancy would worry me any treated timber at the moment seem to have very poor protection
I had seen that earlier, but thanks for finding it. ?
I’m only interested in the bit inside the house no town gas here so gas cylinders for the cooker
I could but why would I ? could I run it in copper over head ? can it be left exposed? I have looked at the straightest route and that is straight under the floor and up behind the cooker.
Not really, unless I want 2 cylinders sitting in the kitchen. Trac pipe? What else can I use supply will be from 47kg propane cylinders mounted outside the garage, pipe needs to run under solid garage floor and then under block n beam house floor will measure distances later out side will join to 2 cylinders via a change over valve inside will feed a 5 ring gas hob only. What are the other options as Trac pipe is dear as poison.
Opinions please trac pipe under a block n beam floor. In a duct or concrete covered to protect it whilst building works continue or trac pipe pipe under solid concrete garage floor ducted or not. Cheers russ.
