Methane gas
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
We are the site of an old gravel extraction quarry after the gravel was extracted the area was back filled with the soil originally stripped off, the thoughts are if any vegetable matter or anything else was buried at the time it may rot down and give off methane. I am wondering if it would be easier to just install a gas membrane instead of a standard dpm rather than have a survey done to tell me that I should probably install a gas proof membrane. -
So a letter from BCO has flagged up the need for gas preventative measures so talking to bco I thought we where going to talk about a radon barrier nope it’s methane they are concerned about, has anybody installed one or has anybody had a contamination survey carried out looking for methane cheers from peed of in Cirencester.
Timber to timber Joist hangers
Russell griffiths replied to ToughButterCup's topic in Floor Structures
Going back to your other topic of how to fit your posi joists if you go for top hung you won’t need any hangers. Add the cost of all of the hangers up, it could dictate a different way of fitting them. -
If it’s a reinforced slab stick a row of chairs along the join to pin it down
Once there’s 20 tonne of concrete on top I’m pretty sure it won’t be a problem never used to tape them, just a good lap.
Let me throw a different slant on it you say you are too old for a mortgage you say you would like to retire so why build a two storey house? I would think a nice large bungalow with wet room with wide doors, and then maybe guests bedroom in the loft area. How long are you planning on staying.
Fixing POSIs to a wall plate (rim joist)
Off topic slightly but still relevant if you say your wall is a bit wibbly wobbly, I would do as much as I can to level it out before fitting your rim joist temporarily fit your rim joist, scribe all around it, remove rim joist, grind hack chip wall until rim joist sits nice and flush, a thin skim of render in the low spots, re fit rim joist this will ensure better fitting of posi joists and you should be able to get them all the same length dont forget to air seal behind rim joist. -
Not sure who is doing your slab or how you are going to buy your reo but I have just had 3 tonne of cut and bent steel all prefabricated from a company called total building supplies, I was shocked how cheap it was and had to question if they had missed something out as it was £2000 cheaper than a quote I had already had .
What is the function of a cavity tray at ground DPC?
Russell griffiths replied to epsilonGreedy's topic in Foundations
https://goo.gl/images/yG8wE4 in my opinion it should look like this. -
I will try to give my view but it’s a bit tricky as all our build ups are different old school method. Two damp courses level with each other. No insulation in the cavity at below floor level. Cavity core filled to two courses below dpc. Moisture droplets form and drop off wall ties as it’s meant to. It falls down the cavity and lands in this two course void and then wicks to either the inside or outside but cannot climb above dpc. Winner winner chicken dinner. New school thinking. Fill the void below floor level in the cavity with a solid insulation to stop a cold bridge at floor level. Moisture drops down cavity and hits top of insulation, bounces onto inner skin of blockwork, KABOOOOM. Damp shows on inner wall at skirting level. So filling the cavity with a ridgid insulation has just created another issue. Remedy. Create a tray damp course. if you have found pictures of a level tray dpc ITS FOOKING WRONG. my personal opinion of course -
Can I add a non educated but common sense thought to this. My feelings are that adding thickness to the concrete does hardly anything without the correct reinforcement your drawing shows extra extra thickness of concrete but no additional reinforcement in that area, if you maintain the 250mm thickness all over but add extra reo in the ring beam area I’m convinced that would improve things over just thickening the concrete. I have been installing my ringbeam over piles this week and all the high load areas have 8x16mm bars and the low load ares only have 6 x16mm bars I questioned this and was told it was the beams that were carrying the floor load as well as the wall load that have the additional steel.
https://goo.gl/images/pZ4Fwn a bit like this. You don’t have to have a tray, but if you want to insulate below the inner floor level to stop any cold bridges then you will need to demonstrate a way of preventing moisture passing to the inner structure. -
Why does the tray promote mortar damp bridges? my feelings are it’s there to stop them, the inner leaf is normally higher than the outer, so any moisture build up in the cavity is directed to the outer leaf and towards any weep holes -
Soil contamination survey.
Russell griffiths replied to Russell griffiths's topic in Building Regulations
I think they know we are on fill as it’s an old quarry site i have stripped a good metre off it and I’m not dead yet if a radon barrier will keep them quiet I would rather do that as it will only be a couple of hundred quid. -
So bco have sent through their thoughts on our building regs submission one item they picked up on was (Provide suitable gas protection measures due to landfill ) so my thoughts would be to replace the standard damp proof membrane with a radon type barrier, would this satisfy them or can they insist we have a survey carried out to determine if there is any gas in the soil. What is the likelihood of any nasty gasses being present in soil that had been put in place in 1947. Cheers russ.
I need to order some footing blocks, what types?
Not in my book it’s not whats the £1.10 labour is that per block, if that’s the case I’m going to dust of my trowel ive got 660 blocks in my footings and will be expecting it to take under a day with 2 of us. -
I used to pay 40p in 1995. 87p plus vat now -
Do I need to plaster my new build
Russell griffiths replied to Triassic's topic in Plastering & Rendering
Im afraid I disagree, I think it depends on the quality of your tapers and their finish you can get a level 3 finish which is fairly standard or a level five finish that will make your skimmed wall look positively rough i have had perfect skimmed walls that still require lots of fine surface filler and sanding. -
Have you priced them up ??? i can get 7 kn concretes for 85p plus vat those trench blocks are eye wateringly expensive. -
Embedding threaded bar in concrete.....
Russell griffiths replied to ToughButterCup's topic in General Construction Issues
Nooooo you haven’t have you my godly image of you being ultra accurate have all been wiped away in an instant gutted.- 5 replies
- concrete
- chemical anchor
I did a lot of brickwork in the early 90s aerated blocks were the big thing I have seen whole houses built with them, but 20 years later we noticed lots of failures hairline cracking everywhere, i just don’t like them, go and buy one and take it home chuck it about for a bit, then decide if you want your house sitting on it for 100 years. I think the thing with beam and block is a higher loading on the footing wall as opposed to a slab on ground type floor. The blocks i have brought are the ones @Declan52 pointed out from Stowell Concrete. They are on site and I like what I see, but the price was a bit sharp. -
What are you fixing down that you want this amount of accuracy as an example if it’s a wall plate put them in with a fair degree of accuracy but not to @Onoff standards, if some are a little on the skew slide a piece of pipe over them and give them a gentle tweek, after tweeking if the thread is say 12mm drill a 16mm hole in your top plate and fix down with a 50 mm square washer. Bada bing. Beer time.- 5 replies
- concrete
- chemical anchor
My personal opinion of course. I wouldn’t use a thermalite trench block if you gave them to me for free!! i have just had my trench blocks delivered standard weight concrete 7kn i personally have brought a special block designed for footings that is 300mm wide so you don’t have a 440 block wasted by being laid on the flat, dearer than a standard block, but I think they make a nicer job. Can you not lay one flat and one stood upright to make up your width. -
Tell us more about this ordering from Italy @nod
