Bugger me I’ve never seen one of them. ??
So as the title says i have seen a product on you tube for fixing fence posts, that is an expanded foam type stuff that got poured around a post anybody seen it or know where to get it. I have a couple of loose gate gate posts that are moving due to the clay cracking around them and a series of 75mm wide cracks around them that would be perfect if I could pour something down them.
As far as I am aware the yellow mdpe pipe is only for up to the meter, not internally.
Are you not confusing courses with a wall, just because it looks like a wall doesn’t mean it has any bricks that picture you put up of the part built house with the triangle windows has not got any brickwork around the windows you will probably find it has the timber frame(structural) then a dummy frame or just packed out timbers to bring the outer face in line with the lower portion. Does potton not supply these details to you ??
I think you will find all those lintel you have looked at rely on having a good amount of brickwork above to aid in the structural integrity just like an arch. If you have very little brickwork above, you will need to think along another line.
If it’s all timber and rendered can you not use a glue lam beam and build all the exterior render boards onto that. With the portion between the windows in timber and clad in render board.
We used a retired architect who works on an hourly rate £25 per hour when we approached a couple of local architects practices they where looking for £25/30 grand for a full design and over see type of package. ??
After having a good look on the tracpipe website, it states that for all LPG installations any pipe entering a building must be above floor level can you shed any light on this @Nickfromwales is LPG heavier than natural gas or something so they don’t want it in a floor void. If this is the case it looks like I will have to run it surface mounted across the garage like @Alexphd1 suggested. Bloody hell life shouldn’t be this hard.
If you say rusty steel can’t you use that as a cover over something more structural so stone, brick concrete with rusty mesh in front.
Have you thought of gabion baskets with a brown coloured stone i have seen plenty of those crib walls and life expectancy would worry me any treated timber at the moment seem to have very poor protection
I had seen that earlier, but thanks for finding it. ?
I’m only interested in the bit inside the house no town gas here so gas cylinders for the cooker
I could but why would I ? could I run it in copper over head ? can it be left exposed? I have looked at the straightest route and that is straight under the floor and up behind the cooker.
Not really, unless I want 2 cylinders sitting in the kitchen. Trac pipe? What else can I use supply will be from 47kg propane cylinders mounted outside the garage, pipe needs to run under solid garage floor and then under block n beam house floor will measure distances later out side will join to 2 cylinders via a change over valve inside will feed a 5 ring gas hob only. What are the other options as Trac pipe is dear as poison.
Opinions please trac pipe under a block n beam floor. In a duct or concrete covered to protect it whilst building works continue or trac pipe pipe under solid concrete garage floor ducted or not. Cheers russ.
Methane gas
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
We are the site of an old gravel extraction quarry after the gravel was extracted the area was back filled with the soil originally stripped off, the thoughts are if any vegetable matter or anything else was buried at the time it may rot down and give off methane. I am wondering if it would be easier to just install a gas membrane instead of a standard dpm rather than have a survey done to tell me that I should probably install a gas proof membrane. -
So a letter from BCO has flagged up the need for gas preventative measures so talking to bco I thought we where going to talk about a radon barrier nope it’s methane they are concerned about, has anybody installed one or has anybody had a contamination survey carried out looking for methane cheers from peed of in Cirencester.
Timber to timber Joist hangers
Russell griffiths replied to ToughButterCup's topic in Floor Structures
Going back to your other topic of how to fit your posi joists if you go for top hung you won’t need any hangers. Add the cost of all of the hangers up, it could dictate a different way of fitting them. -
If it’s a reinforced slab stick a row of chairs along the join to pin it down
Once there’s 20 tonne of concrete on top I’m pretty sure it won’t be a problem never used to tape them, just a good lap.
Let me throw a different slant on it you say you are too old for a mortgage you say you would like to retire so why build a two storey house? I would think a nice large bungalow with wet room with wide doors, and then maybe guests bedroom in the loft area. How long are you planning on staying.
Fixing POSIs to a wall plate (rim joist)
Off topic slightly but still relevant if you say your wall is a bit wibbly wobbly, I would do as much as I can to level it out before fitting your rim joist temporarily fit your rim joist, scribe all around it, remove rim joist, grind hack chip wall until rim joist sits nice and flush, a thin skim of render in the low spots, re fit rim joist this will ensure better fitting of posi joists and you should be able to get them all the same length dont forget to air seal behind rim joist.
