Russell griffiths
    65
  1. I have just done something very similar, I mixed a mixer full of strong 3:1 sharp sand and cement, I then mixed a bag full of self levelling compound in a big bucket with a whisk , I then added the two together it did what I wanted perfectly, why not have a play with a few different mixes to see how it works for you. £10 for a bag is worth a couple of try’s
  2. I had to re do my kitchen roof over the Christmas holidays a couple of years ago, so definitely not a good time what I did was to go and buy a big blowtorch, the sort roofers use to stick down the torch on membranes it was the type of torch that has a big fluffy type of flame not a skinny brazing type flame. I got on the roof first thing in the morning with a leaf blower and gave it a really hard blow, and then heated the entire surface until it was steaming, I wanted every drop of moisture out, cup of tea and then warm it all up again until the osb was really nice and warm, allow it to cool while you cut your matting to size and your ready to go. Mine came out superb, it was a bit of a bodge job as it’s on a house I want to knock down so didn’t bother with fanciful details. one thing I will strongly recommend if you have a drip edge into a gutter, then router this edge into your osb as it creates a lip that water sits behind, most of the instructions I have seen say water will flow over this lip as it’s only 1.5mm high. Which it does when in full flow it’s the little showers that sit behind it.
  3. What makes you think a sips roof will be air tight, look up all the problems they have had in the states with them, lots of rotten sips roofs what span are you talking about ? I have tried to get prices for a sips roof and they couldn’t do the spans without adding extra solid timber into the web to stiffen them up, leading to massive cold bridges.
  4. Crack on mate, you seem to have made your mind up. Who’s putting wood in their window reveals ? Certainly not me.
  5. Of topic, the timber battens are coloured so bc can check they are the correct grade from the floor. The standard tanalised ones aren’t to spec any more
  6. We all have to make our own path in life, so really you need to do some good research and make your own mind up. Im using nudura, would I use it again, yes. Things to look into. How easy is it to use ? when it’s up what else do you need to do to it, is it air tight? Do you need to parge coat it? when it’s up how good is it ? Is it flat ? what is your chosen finish ? how will you fix to it ? blah blah blah write a big list of things you want your wall to do and choose a product that fits the bill.
  7. Tile nailing is dependant on tile make and wind rating in your area, I have tiled a roof before with not one nail in it anywhere so check manufacturers guidelines. Over lap on membrane, he should be sticking to what manufacturers recommend. Tile gauge will be dependent, if it is a detached house he should measure the entire roof and work out the gauge evenly, making sure he has the correct head lap if it’s a semi detached, he may have to follow next door to maintain a good marry up with there tiles, unless he has put in a vertical valley if he won’t put in the ventilation tray what else has he missed, how about the anti ponding tray on top of the facia? either way your paying so make sure you check and get it put right
  8. Looking at you sketch, I think you need to include your finished floor, will your floor structure not continue into the door reveal area? As it looks are you not creating a straight joint in front of the door, depending on floor finish this could lead to cracking in the finished floor. I have spent a good good few hours thinking of this detail, mine is icf block and I’m going to install marmox blocks in the inner core and have the floor screed continue into the door reveal to prevent any straight joints.
  9. Have a look on Charlie luxtons new build, he used a fibreglass angle to sit his doors on as they had a smaller thermal bridge than a chunk of steel. Or you could look at marmox blocks, which are insulated blocks but with high compression due to some inner epoxy type dowels
  10. Hi, can you tell us what the big aluminium stanchion thing was.
  11. My architect stated air vents under the doors, I explained to bc that this couldn’t be done because of level access, but I had increased the number of vents on the two opposing sides to get a good cross ventilation, he was happy with this and it has not been mentioned since.
  12. First pour was only 450mm high. It seems the vents that collapsed where the telescopic sections, as one piece slots inside another you get an overlap, it was this overlap that allowed concrete slurry to push up from the bottom and enter the hollow tube, if i wa doing it again I would get some thin xps sheet and clad the vents to seal them up and add extra strength. This is what I was up to today.
  13. After we had done all of ours I did wonder if we had done nothing if I would have gone through but with a big pile of conditions.
  14. At the moment I am having quotes for my roof 220mm I joists the prices are on average double the cost of a standard 225x50 structural grade timber. But its not just the cost of the timber to look into if you stick build it in normal timber you may use something that could be anything from 140mm to 180mm any bigger and your getting silly, so you need to look at how much insulation you can get in between the joists. Not enough. So now you need to look at insulation across the face of the studs either inside or outside, so more work and more cost. a lot to think about not just the cost of the joists. Im not clever enough to start talking about u values and all that junk, I just like knocking it all together, I will let somebody else tell you how to get it up to spec with regards insulation.
  15. Well spotted hadn’t thought of that.
  16. Hi @Vijay I thought you were past this point, I did indeed have a very major cock up with our telescopic vents the weight of the concrete and the vibrations collapsed the telescope sections, and I had to cut them all out by hand after the concrete had gone off. If you haven’t done this yet I would look at reinforcement over the vent to give it more strength. Hows it all going mate. Russ.
  17. No idea on cost comparison just too many differences for me to compare i am working on my own most days and felt it was easier to chuck about a block of eps rather than a bloody great 6x2. So far it’s a breeze I think I could possibly get the wife doing it with only a couple of hours training.
  18. If you get a company to design your frame and you work to their spec and put in the correct fasteners where they say then what is the problem. You will I’ll have to work to some sort of standard, you can’t just think I’ll set my studs at 750 centres just because it looks ok, you will need somebody to specify how many studs at openings, and what timber to use as window lintels, you will need to know how you are fixing it to the foundation, what nail spacing to use on your racking boards. If you have the correct information you should in theory theory be able to give the plans to anybody to build. If building control have signed off on the design then all they need to check is its built to spec, you can get a monkey to build it but it must meet the spec. Im currently building in ICF block, ATBH it seams perfect for a competent diy job, it’s flying up and is very user friendly.
  19. I have edited my post to re name the Larsen truss wall panel to be known as a trussed wall panel. @Ed Davies
  20. If you use an engineered timber for the studs there will be very little shrinkage, I have just picked up a couple of samples of i joist for my roof and it looks like a lovely product. I did consider building this house I’m doing in timber and I had two methods in mind, one was I joists. The other was to borrow a mates barn and build up a load of wall truss panels and bring them to site in my trailer and erect them a trailer load at a time Have a look on YouTube there are loads of framing videos, they are all Mostly American but try to find the European ones they are very good as they cover how to get a good level of insulation in to a thinner frame.
  21. Flood risk rainwater mitigation measures. SUDS landscape plan ecology light pollution. All this is obviously site specific, but these are just a few of the hoops we had to jump through.
  22. That’s exactly how I did mine, sacrificial trim around head of window got removed after a year or two and a bit of fettling and re sealing and then replace window trims. Inside and out.
  23. How about building it in sips, and then adding all that detail as fake dress up on the inside, non structural just for show.
  24. My thoughts would be I would avoid a timber frame building at all costs, I guarantee that no matter how well you seal your hygiene layer if you steam clean it regularly you will get water Ingres into your main structure, i would look at a galvanised steel frame, portal building, insulated sheet roof, timber clad on the outside but plastic coated internal wall panels, epoxy floor covering you could have all the pens in flat pack form so you can alter the layout later on if needs be. My wife wanted to open a high spec cattery, so I have already put a bit of thought into this. I would give a timberframe building 10 years before it looks very tired.
