Hi @Tin Soldier I use a website called HOUZZE for ideas. Be careful it can get expensive looking at fancy things.
Hi I have been doing a bit of reading regarding escape windows can anybody tell me why it says they must have a min height from floor of 800mm surely the lower the cill the easier it is to get out. Is this in line with not having a kid fall out of them??? would fire escape hinges comply if the cill height was lower than 800mm cheers russ.
Oh good lord that concrete house was harsh, I’m very open to new design and ways to live but that just looked like toooo much concrete, the bedroom shocked me as it looked like a lift shaft I once worked in.
Thanks everyone.
In the pic you can see timber cladding with a visible open join, what sort of backing do you think maybe behind this or do you think it would be open im open to any ideas in my area I’m worried that an open joint would be the hiding place for 30,000 spiders and other creepy crawlies would prefer fully sealed up with an air gap top and bottom with insect mesh on them. Cheers russ.
Putting a new spin on it...
Russell griffiths replied to NSS's topic in Landscaping, Decking & Patios
I have seen something similar that used large rubber casters, like shopping trolley wheels I have seen them used either rubber side down or rubber up. With a channel track to keep the wheels in position. -
a modern plastic chamber looks like this, so as @Mr Punter said pipes can enter at 90 to the main drain run, you can also add an angle joint on the entry and exit pipes to vary the inlet route. the ic in the pic is a 320mm a 450mm looks a little different as they can have a lower exit pipe. Have a look for some images and it will give you a feel for the parts available.
Front Door Inspiration
Russell griffiths replied to canalsiderenovation's topic in Doors & Door Frames
Have a look on a website called HOUZZ. -
Ventilated plastic battens
Russell griffiths replied to Russell griffiths's topic in Building Materials
I don’t think so as they would be behind cladding protected by insect screening top and bottom -
hi I have watched a couple of vids recently where a plastic batten with holes in it has been used behind cladding, it provides a good air flow and obviously doesn’t rot like a timber batten could anybody used or know where I would look at buying them. Cheers russ.
Why not hire one for a day or two and get all the cuts done.
From a sheet metal company, zinc coated, folded to your design imagine you had a metal roof and needed a flashing bent to a certain size shape you could probably get a fibreglass one also that is made to look like lead, just like they use on the fibreglass roofs. What is your flat roof covering.
- 11 replies
- rav
- abutment ventilation
If that is timber cladding in your pic then why use lead, you could get a flashing pre folded and dress it into a cut in your durosol wall and batten and clad down to it.
- 11 replies
- rav
What hulking great gap are you talking about, who’s icf have you used. @Big Neil
MVHR Smells
Russell griffiths replied to AdamSee's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Regarding your roof vents have you thought of painting them, I had a job and could not match the old tile look, so a good rough up with sandpaper and some plastic primer and I painted them to match the old tiles, from the ground you couldn’t even pick out the vents. -
Can you not get a broken large compressor and use the tank as a storage vessel im not up on the system but I know on an American garage forum I used to use it was common to have a larger storage unit with a smaller compressor topping it up.
Getting the benefit of 'standard size' windows
Russell griffiths replied to Tony K's topic in Windows & Glazing
Couple of things, that b and q window will be utter crap,go and have a look. As for standard sizeing i completly get where get where you are coming from, backwards Britain strikes again our last house we built in Australia, I went to see a window company and was handed a brochure, many styles to choose from size wise hundreds to choose from as long as you stuck to the set metric sizes. Width. 300 600 900 1200 1500 1800 2100 height. 300 600 900 1200 can you see where this is going, brilliantly simple, the brochure had all the rough openings in it to show your frame builder and when your house is finished you go and buy blinds, well bugger me, they are available to fit the same metric sizes so you go and buy off the peg blinds no dork coming around to measure up for your bespoke £10,000 blinds as i said backwards Britain something so obvious, pay you deposit and 3 weeks later your windows arrive -
As you made your concrete on site I think the best thing to do would be to try it. If you are using an expansion type anchor and are unsure of the concrete integrity, why not drill your holes i the wall plate and fit it , but don’t install all the anchors yet just a couple so you can carry on working, then as it cures a bit more get the others in Wednesday, Thursday, you could also use chem set, and just get them all in, no expansion with chemical fixings.
We have just piled so did a fair bit of research on the subject, we found a good few of the mini piling companies are developing methods of spanning from pile to pile, with either concrete beams or steel sections. However these are all suspended systems, not ground bearing so will not help you lower your build height it may be you will need to go back to planning and discuss ridge height, because of the build system necessary to accommodate the tree. I cannot see you getting a thinner slab as they should be insisting on some sort of root protection,shrinkage, heave product under the slab to accommodate any movement check out ROGER BULLIVANT PILING some interesting solutions to ground problems.
I have a very nice expensive makita and it is useless with my 110mm core bit the clutch cuts in far too often, instead I have a £45 mini breaker with sds chuck from somewhere like Aldi that I use all the time, I just go steady and make sure my finger is ready to let go. ??
Durisol: that's it - the last pour.
Russell griffiths replied to ToughButterCup's topic in Insulated Concrete Formwork (ICF)
Well done, bloody good job for an ol timer -
Lead finishing - roof
Russell griffiths replied to Redoctober's topic in General Self Build & DIY Discussion
They also look like soakers to me as well, so another piece of lead needed cut into the face of the stone and dressed down over the soakers, groove in wall should be 150mm up from roof finish to allow for rain bounce. Should you not have a cavity tray in that location and weep holes?? -
Disabled access
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
Thanks all will talk to bco. -
This always seems to be a hot topic, but I haven’t seen this bit mentioned if we have a ramp up and a flat area for turning and manoeuvres at the top of the ramp, does the flat area have to have a lip at the edge to prevent a wheel rolling off the side, or do all sides have to have the correct slope to them, also at what height of the ground would the flat area require a hand rail fall prevention type set up. Cheers, confused as normal.
We are in the process of trying to work out external finished ground height, and I’m getting confused by old school methods and common sense verses what we do nowadays, the situation is that due to a flood risk assessment our house will sit quite high above original ground level, so a lot of backfill to bring the ground level up. My old school thoughts are that any external ground level should be at 150mm below damp course level, so that would incur having a 150mm step down, which I feel is too big a step and an uncomfortable height, I would like to decrease this step down to 120mm as this is more comfortable. How will bc view this 125mm height instead of150mm. Is it not viewed in the same light as it was in the past with all these level thresholds how does this work with my disabled access as well, I will end up with a large flat turning area outside the door, level with the interior floor level. Just for referance our our house is Icf walls, so no formal dpc to speak of really I am not concerned about building up the external ground height, I just want to ensure I don’t have grief of the bco. Cheers russ.
