Agree with everyone Give that a wide berth. ???
Posi joists on internal walls
Russell griffiths replied to willbish's topic in General Construction Issues
Look up FOX blocks on YouTube, they seam to have more vids than anybody else. You can do it a few ways you put your pole plate,ledger board, rim joist, call it what you like, in position, screwed to the wall with temporary fixings, mark out your joist layout, work out where your fixing bolts go and drill holes in pole plate, remove pole plate and cut a large hole in your icf in the location of the bolts, fit a membrane of some description to the back of the timber, put timber back up with bolts projecting into the holes you cut, when you pour your concrete it will flow into the holes you cut and surround the bolts, it will end up with concrete pads projecting out to the back of the timber adding the support you wouldn’t get from the insulation layer. I will be doing mine in a months time, I will try and remember to take a few pics. -
You would need to insure your concrete pour was accurate to within 3-5 mm over the length of the wall, or your joists would all be out of level, you would then need to cut every block you put on next to accommodate the joist in the way. I really don’t see what benefit this method would have over the standard fixing method of a pole plate bolted to the wall and joist hangers. The canadians and the yanks have been doing it like this for years, can’t see any reason to change it. -
Stick build scaremongering or legitimate concerns?
Russell griffiths replied to Ben100's topic in Timber Frame
Larry Hunn, proper old school framer, I think if you stick to the correct framing process but add in some new cad design and some new better fasteners then timberframe can be a very good method. -
Fixing joists to the wallplate
Russell griffiths replied to ToughButterCup's topic in General Construction Issues
Screws aren’t a no no, you just have to use a screw specific to the hanger. Look at the manufacturers spec. @recoveringacademic don’t try and reinvent the wheel mark the plate up with a hanger and a set square, and as nick said a piece of timber to act as a shelf, then just drop all the joists in after you could have fitted all the hangers while the pole plate was on the deck, but now it’s up just do as above. You will find it easier to swing the hammer without a joist in the way. -
Second hand solar panels
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
How about I contact him and ask for a bulk purchase price. -
I will see if I can put a link up, but I’m a bit of a Luddite when it comes to the computer. -
Evening. A lad near me is selling hundreds of second hand solar panels off a solar farm,the surface of the panels are all scratched and marked, he said they are all working at about 80% capacity. Now im not thinking of the house, but can anybody think of uses around the garden, 3-4 of them on the shed 1 to trickle charge the electric fence 1 to run a pond pump come on you boffins are they of any use.
Planning permission or permitted development?
Russell griffiths replied to Tom's topic in Planning Permission
I can see your point, if they messed up their contract and it’s full of holes then go for it however I will add this if you purchased knowing there was an uplift clause then you new full well the costs involved, you have then found a loophole because of some shoddy paperwork, is that really fair, what if the boot was on the other foot, what if you had put up the question : my purchaser doesn’t want to pay me my uplift money: What does your conscience tell you, do you believe in karma ? -
You also don’t need to screw into the floor to erect your stud walls, just glue your bottom plate down with no nails.
My thoughts on this would be that, if I was the vendor and I thought you had done this on purpose to avoid paying any uplift, I would hunt you down with the most ferocious solicitor I could find, I would make it a quest until you pay or I dropped dead. Would it be a case of your solicitor is bigger than their solicitor. Are you prepared for a fight. What you thinking. -
Looks excellent, I’m just at about 2.7m in my icf build, I really don’t know if I’m over doing it with the temporary bracing on corners and windows, I’ve been cutting and screwing for days now, probably watched to many videos where it all goes wrong.
I sent my details to marmox and they we’re happy. I wouldn’t use ply under a slider for two reasons 1 it could get wet and rot 2 it will compress i think somebody on here already did this and found they have a dip in their bottom track
NUDURA rebar steel cost
Russell griffiths replied to Ben100's topic in Insulated Concrete Formwork (ICF)
Nudura £22,000 steel cost, £1,500 i have lots of large openings and a number of large concrete beams holding up the roof steel cost is minimal compared to the block and concrete. 55 cubic metres of concrete in mine. Find a good structural engineer that knows icf and you will save a few quid. -
Wood burning stove and flue install
Russell griffiths replied to ProDave's topic in Stoves, Fires & Fireplaces
Are you happy with that so close to those kitchen units, my wood burner would have that decor panel screaming out for help after a couple of nights, also the underside of the worktop i don’t know if yours is more insulated than mine, but anything within 600mm soon becomes to hot to touch. -
Front Door Inspiration
Russell griffiths replied to canalsiderenovation's topic in Doors & Door Frames
Four grand for a front door, where do they get these prices. -
Hi block n beam company do the design, just send them a floor layout, I picked my company by location as I new delivery would be a large cost, I used rackam house floors. 160m cost about £2000 without blocks, lightweight blocks 70p each.
Very nice, what is the cladding next to the front door. Russ.
Sorry couldn’t resist it. ??? looking good mate. ??
Is there a reason mosaic number 2 doesn’t match the rest. Report post
Ours went in a month ago and was very straightforward Things I liked. Pipe placement was easy and allowed me to move a pipe I wasn’t happy with, has given me a working platform that doesn’t contain any underfloor heating that could get damaged as I have a hundred fixings to go in the floor to hold up my bracing for the icf walls. Things I don’t like. large cold void under the floor, increased height of finished floor.
In Ian’s post @Nickfromwales he says they are for fixing his first floor.
- 17 replies
- 17 replies
Are you sure these are strong enough to take the load of a floor i think I would be checking a few things. My first choice would be a sleeve anchor or old fashioned raw bolt. I have just put 200 of those concrete screws in my place and found it was a hit n miss affair if they took well, I would not want to use them in a critical location.
- 17 replies
