Gluelam connectors
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
Ooh Er that sounds good @bissoejosh my beam is about 17 m long 140 wide depth to be confirmed it will be split into 3 pieces with the two joins sitting on 140x140 posts and both ends into the walls i had imagined a dirty big plate bolting it all together, but a hidden join would be nice also. A drawing would be most appreciated. -
Roof loading
Hi @Mr Punter if you have a quick look at my first post you will see It has all been given to a local timber engineering company and they have done all the calcs and design. The problem is me being me I asked if it could be improved upon, this was deemed to be a strange request and both designers thought I was silly wanting to spend more money than was needed. They both said it met all design requirements and deflection criteria so why would I want it any stronger. Now if this was a floor I would without doubt be insisting that joist spacing be tightened up to 400 instead of 600 centres as I would want a bounce free floor, however being a roof is there any point in over engineering it, I can’t see me ever up there with 20 mates dancing to the latest chart topper. Confused as usual. I might send it to my structural engineer to look at, it’s just another £100 to add to his bill I would like to avoid. -
Gluelam connectors
Funny story about the local engineered timber company i walk in and talk to a bloke for half an hour, total tit didn’t like him at all so I thank him and move on thinking I won’t ever go back there. A month passes and I go to have a chat with a company a little bit further afield, as I walk in their office, guess who’s grinning at me from over his computer screen, yep mr arse hole. So it just dawned on me I can now go back to the first company as he doesn’t work there any more. ?? -
Gluelam connectors
Don’t worry it’s all in my head in a big jumbled heap, I have designed these connectors a dozen times at 2.30 in the morning as I lay awake wondering how mad I must be to be doing this again, and thinking of my next project before this one even has a roof on. -
Gluelam connectors
This is on show in the main living room, so all sanded and varnished up. -
Roof loading
Looking at @mvincentd post with his roof loadings if I give a run down of my roof buildup can anybody point me in the right direction as to the loading we should allow for in the design. Hope that makes sense. From the top down. Raised seam steel roof sheets 18mm osb 50x50batten 220x69 I joists 75mm service batten 19mm softwood ceiling i have left out vcl and roof membrane and insulation, also mvhr ducting in the service void. Any thoughts anybody. -
Gluelam connectors
I haven’t got building control sign off on this bit yet they have allowed me to submit a phased submission so I basically submit some drawings they approve them, I build it, I submit the next bit, they approve that bit and so on it sort of happened like this as I was keen to start work in the summer and didn’t have them all finished. Who was your supplier @joe90 -
Gluelam connectors
I’m actually thinking of making them myself, but being rather busy I thought a nice stainless bracket would be nice. Achitect wording was GLUELAM CONNECTION BY OTHERS. i cant believe the local company who have absolutely hundreds of gluelam on the shelf don’t actually have any connection details. -
Art noon, i have a fairly substantial gluelam beam going in the house to hold the roof up, this beam has 2 joins and 2 posts under the joins, has anybody found any good suppliers of joining plates i need to join the beams end to end with a post underneath the joins. The local gluelam supplier is less than helpful cheers russ.
Hi I have had a couple of different opinions what sort of slump did you specify with your icf pour. Two opinions one was 100mm the other 80mm. Any thoughts people. Cheers russ.
@Nickfromwales I would stop now, while you still have some credibility left. ???
I thought @D Walter was talking about a roof, do you need to go to such lengths for soundproofing of a floor
Not if it’s a roof, no services up there. All on the inside of the airtight layer in a service void.
Evening all i have had a couple of roof designs done by timber i joist companies, now both companies have specified that they have designed with these roof loads in mind. 0.8kn/m live load 0.6kn/m dead load do these loads look fairly standard, I spoke with one company and said I wanted the best they could offer and was willing to pay more to close the joist spacing up to provide a :better roof: two blokes looked at me like I was a nutter and said it far exceeded any spec needed and to stop worrying as it was all well inside deflection criteria. Anybody know what sort of load was specific to their roof for your information my roof is mono pitch at 15 degrees.
Have you bought them yet? i changed my easy joists to i joist to make insulation easier.
My knees need a ladder
Russell griffiths replied to ToughButterCup's topic in Project & Site Management
Confused by MDPE mains water pipe price variation.
Russell griffiths replied to epsilonGreedy's topic in General Plumbing
All I would add is buy good fittings plasson is my preferred supplier, thanks to @PeterW I think -
Yep step ladder dont buy a crap diy version solid yellow fibreglass version, should spend at least £80 to get a good pair. -
Cutting Holes for Windows and Doors
Russell griffiths replied to Big Neil's topic in Insulated Concrete Formwork (ICF)
Only if you have money to burn. When you come to a window you cut a block, the off cut goes in the next row, if you cut it out after you will end up with lots of random sized pieces with no where to put them. Have you been to see any icf builds? Go and have a look, an hour on somebody’s site will answer a lot of questions we are in Gloucestershire and up at first floor level if your interested.
