Russell griffiths
    65
  1. Yesterday we moved into our place, started in 2018 still not 100% finished in 2026, I estimated it would take me 2 years, 🤣🤣 thanks for all the advice from fellow buildhubbers. What we bought, what we have now.
  2. Just be aware lead should not be longer than 1.5m, I’ve seen lads run a roll of lead from top to bottom of a valley, as it’s long and thin it looks like the obvious thing to do, but expansion kills it.
  3. Top pic in my previous post was after washing the floor ready to prime it for tiling. middle pic was the day after it was laid.
  4. I remember why the softwood option was cheaper I left large gaps between each board so used a load less boards not saying how big that’s up to you to decide. all fitted with 90mm galv ringshanks nails my labour was free, it took a bloody age. I researched this forever and found that a lot of EU countries used big gaps, and they have been installing this stuff longer than us.
  5. I priced up ply versus sorft wood 100x25 the ply was a lot dearer. but this was in 2020.
  6. I wouldn’t consider osb under the sheets, pull out strength of an 18mm screw is not great. 25mm sarking boards for me.
  7. Go and see the neighbours rip the hedge out and re plant a new one, by the time the house is built it will be 4 feet high and nice and lush.
  8. Cash flow if a contractor supplies a service and materials it’s zero vat if you buy the materials you pay the vat and claim it back, this could be a long time before you get it back.
  9. Depends what door you have, we have a mat well simply because a lot of the modern low threshold doors are very low to the finished floor, so you physically can’t put a mat on top of the floor or the door won’t open. also with the low doors they tend to trap small stones and scratch the floor, the mat wel allows the stones to fall lower allowing the door to open.
  10. How much is the huge fee from the planning consultant our was about £4000 and she worked with us for 18 months getting the plans passed. your not mixing up all the survey fees and other documents with her cost are you. the rest of the fees took it up to £16,000, but the actual planning consultant I felt was very good value.
  11. The cement faced foam core boards can be skimmed, but you use a specific primer. definitely not pva.
  12. What do you want to know the brass stop cock is the incoming main, it’s got the couple of turns in the pipe so the tap is easier to reach instead of it being above the cylinder, as that cylinder is probably 1500high. the white bit of hep pipe is the temporary pipe because the water softener isn’t there. This allows the house to have water while the softener was removed so we could get to do the pipe work above it without dropping solder all over the new softener.
  13. I have a Carlos fandango bearing puller, oil filled mega pressure one. it’s still easier with a cold chisel and lump hammer. get a chunk of 16-20mm round or square steel, put it in the vice and bend the top 40mm at an angle you can get that down the centre of the bush and use it like a drift.
  14. Join a Facebook group called 8 ton and below loads of info on there regarding anything digger related.
  15. First thing to do is put some safety glasses on. they are extremely hard and can shatter. I would look at some YouTube videos I did mine at the bucket end. you can do it a few ways, make up a puller/ pusher tool buy using some threaded rod 16mm you will need some old sockets from a socket set or buy some cheap Chinese rubbish from Amazon, get a socket the exact or just smaller than the bush add on a small extension bar, place on face of bush and whack the f##k out of it. After 3-4 whacks you will see it move. if it’s a two piece bush so one either side with a gap in the middle you can get a foot long cold chisel and put it through one bush and up against the other bush. Again whack the be Jesus out of it. it’s not a delicate operation. all sockets and extension bar will be buggered at the end so don’t borrow your mates best snap on set. 🤣🤣 SO YOU BOUGHT A DIGGER THEN. you kept that quiet. have fun.
  16. The problem I’ve seen in these situations isn’t having sufficient bearing of the concrete lintel onto brickwork below, it’s the condition and location of the lintel onto small pieces of badly secured brickwork. cutting a hole up through a wall could end up with the lintel sitting on a small cut piece of brick instead of a full brick. removal of the plaster is needed as is proper placement of the opening or removing any small slithers of brick and replacing with full or half bricks minimum.
  17. Some of our building regs are bloody ridiculous
  18. It looks like there is all little melted bits of lead that have dripped onto the roof covering surely molten lead should not drip on to a rubber roof, or am I being OTT
  19. Minimum bearing for a concrete lintel is 150 each end I believe.
  20. Has been said above patination oil vertical joins are there for expansion but, that is a shit job, the creases should not be there, and why the flipping hell has he done it over the roof membrane without covering it. im not impressed with it to be honest.
  21. How about a build hub local support network I’ve met a local lad building similar to me, we meet up once a month and drink tea and walk around his build, as I’m a couple of years in front of him I’ve been able to point out some things that worked well and some that didn’t. we have all been able to exchange some left over materials and also lend / borrow some tools. since meeting a couple of years ago we have also been out to the pub a couple of times with the wives. it’s handy to find someone in a similar situation who feels the pain you might be going through. I know it helped his wife to come to ours as she could see that there is actually light at the end of the tunnel, even if it’s just a distant glimmer. im in Cirencester if anybody wants a coffee or wants me to pop in and offer encouragement.
  22. I would look at a multi tool blade that is longer than standard with a tungsten edge to it go under the cill and plunge in for the full depth then cut out the mastic under the window. good luck.
  23. The way your describing is fairly serious as though you think there’s some gunk in there, if you stop loops 1-11 does the flow gauge on 12 not start to move. having the whole system going through 1 loop should really whoosh it around. or have you done that.
  24. My windows by norrsken spin right around I’m not sure if that’s exactly what you want, but I’ve been nothing but impressed with them since fitting 4 years ago.
