Nestor
Everything posted by Nestor
MVHR, OSB, windows and roofing starts.
Nestor commented on Nestor's blog entry in South Devon Self Build
@DavidFrancis Throughout the build I have used screws, the initial frame I used Timco waferheads then Goldscrews for everything else. -
@DavidFrancis I have enclosed a drawing of our wall build up. (Hand drawn) Lots of layers. I made the frame myself. Initial frame was 140mm, then fixed 70mm horizontals and finally 50mm verticals at 600 centres to fit the OSB. The GRP roof I fitted myself. Have done one before but still find the whole process a bit of a pain, no matter how organised with multiple buckets, tools, latex gloves, cut matting it is still a messy affair and the conditions have to be dry but the end result is watertight. EPDM is an alternative I will look at next time. Floor, Wall, Roof Build up Jan 2018..pdf -
6 month update. Started fitting ducting for the MVHR, my wall build is 3 layers, 140mm, 70mm and 50mm so the ducting fitted well (luck) within the walls. Just need to uncoil the 50m lengths and start dragging it through the build. Then I added the final 50mm timber and insulation before I started the OSB. It took about 2 months to fit about 150 boards, the vapour barrier, double sided tape, airtight tape, it was quite a challenge especially the vaulted ceilings. For the flat roof, fitted the Velux Rooflights then GRP, about 35sqm, 2 layers. Just need to be very organised and keep all tools and materials clean. I might put some Sedum on at a later date. Had some windows and doors delivered and fitted. Kastrup and Internorm. The whole experience disappointing so far. Most of the Kastrup need replacing due to roller marks on glass. Fitting below average. Finally the Tata SSR. Took me ages to set out but once the eaves and verge square it goes on well. 3 roofs to fit. Now half way through the second roof with 7 Velux which fitted well though very heavy, the soft wood frames very prone to damage if not protected. Working out how the EDW flashing kit works around the SSR takes a while, lots of measuring and cutting, creating upstands and folding but the end result is good. About to move the Kwikstage round again. Body struggling though. If anyone wants more detail do ask. Its all quite challenging but still satisfying.
@Cpd Yes I am doing the roof myself, in fact the whole build so far. The Tata does work well, 4.2m sheets just doable but fitting the ridge on the first roof was a challenge as the Sikaflex sealant goes everywhere you don't want it. The eaves and verge details work well. The extended cut is the top pan overlaying a shorter piece underneath which fits next to and then extends up, under and along the window flashing. Cutting the sheets with metal blade circular saw then up stands using folding tools. The Velux apron was not sticking very well possibly due to the intense heat at the moment so will revisit with sealant and possible fixings. Where possible I trimmed the aprons to fit tight underneath the seams. Very impressed with Velux, as long as you follow the instructions. My brother helped me lift the large windows in, 69Kg. 300sq m + to fit, quite the expert now. First roof below.
- 35 replies
- 3
- standing seam roof
- corrugated roof
(and 3 more)
@Cpd That is a really great job. Did you design the apertures to fit neatly within the corrugations and did you use the EDW flashing kit? I am fitting 7 Velux within a Tata Steel roof, quite challenging and takes a few windows to find the right solution but happy with the end result. It should not leak!
- 35 replies
- corrugated roof
(and 3 more)
GSHP vs ASHP magic spreadsheet?
Nestor replied to CADjockey's topic in Ground Source Heat Pumps (GSHP)
Does this temperature meet the legionella issue as you have disabled the immersion. Do you know how an ASHP can be used for cooling UFH, I am looking at the new, (quieter) Mitsubishi Ecodan PUHZ-W85VAA. Thanks. -
The Build - Timber frame erection
Nestor commented on Redoctober's blog entry in Our Journey North of the Border
Hi, looking great. Can you confirm that price of £7600.00 for TF is correct, down south you would struggle to have a large garage built for that. Enjoy the build. -
Our windows recently fitted. They fixed Compriband to the frame prior to install and then added foam after from the inside. Works well.
Thanks @A_L and @Alexphd1. Correct on the internal floor area. Have a lot of insulation, 3G windows and doors and MVHR. Its airtight. Just want to run a system which is efficient for a family of 4 for 90% of the time. Can someone tell me what a scroll vs inverter ashp is?
The heat loss is 11248 for heating and 4921 for HW. Total 16169kWh. Both suppliers had the SAP test. Over specification? @ragg987 Good point.
I have a couple of quotes to consider for our DHW / Heating solution. UFH and ST for both. 1. NIBE F2040-12 with 100 litre buffer and 500L UVC 2. Mitsubishi Ecodan W85 with 300L UVC, no buffer. Have read @Stones excellent blog about Ecodan. Can anyone share any other experiences of the above topic, Thanks all.
Great job, I did this at my Dad's home, flint stone walls. With the right discs its not difficult. Why the professionals did not bother just leaves you with inconvenience , no recommendation and continues the complaints about trades people.
Sorry for confusion. I used Exeter CCF. In the end they could only supply 2440x1220 at £8.40 a sheet. I have 600 centres so had to trim sheets to fit. 2400x1200 seemed very difficult to obtain and at a premium. You could try https://www.southern-timber.co.uk/ They have been very helpful.
OSB3 11mm 2400mm x 1200mm . £8.40 + vat a sheet. this was end of January. Includes delivery. https://www.ccfltd.co.uk/
Warm roof build up - Air cavity - Metal sheet.
Nestor replied to Nestor's topic in Roofing, Tiling & Slating
No, I would always use a roof ladder for access. Less contact with the surface the better. -
@Temp @ProDave Thanks for your replies. I have spoken to my BC and has said cavity is not necessary as its a warm roof. I would like a cavity so 25mm is fine, no counter battens needed. Tata want a solid deck of OSB, provide you with 40mm nails which go straight through the OSB and puncture breather membrane which does not work for me. -
Kastrup and Internorm windows and doors now fitted. Took about 12 weeks from initial deposit. Fitting and manufacture issues still not resolved 4 weeks later. Balance of payment outstanding until all issues sorted.
Ok, I have a warm roof, Pavatherm above the rafters. About to fit Tata Steel metal roof but not on OSB sheet but batten fixed vertically at intervals to support the pan. Do I have to have a 50mm ventilation cavity as its on batten not OSB which would not need a cavity for a warm roof. Is it necessary? Thanks all,
Is DCV an alternative to MVHR?
Nestor replied to Zoo's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I applaud your effort looking at alternative options, FYI I purchased BPC MVHR for 2.6K + vat. Includes 6 extract and 7 supply. 285 sqm building. Self installation. I have spent £400 on airtight tape!! -
Just want to add what a great job you have achieved doing the insulated foundations yourself with some ground workers. All for DIY.
Only mentioned because I bought 70 sheets in December as the price went up 30% in 6 months.....
Just checking the amount of celotex, they quoted for 101 sqm yet your ground floor is 145 sqm.
4 days! A year later and I have nearly finished the airtight OSB layer, next electrics and plumbing.
We did revise the drawing I sent you, the 150mm Celotex butts up against the DPM / blockwork. Does that make sense?
