scottishjohn
Logix ICF: Build anything slower!
scottishjohn replied to willbish's topic in Insulated Concrete Formwork (ICF)
maybe this should be a word of caution to all and to send the supplier a letter which states that if delivery more than 4 weeks late it will viewed as a breach of contract and you require a full refund . they will be the ones stating the delivery time not you and it is not unreasonable for them to get it right within 4weeks of due date If they have a problem with that then change you choice of blocks it is up to them to give you a realistic delivery time when they want some money . if they want up front payment there is no trust involved in the deal --,so it should be a simple contract issue quite sure they are some legal eagles out there who have seen such supply contracts in the past -
GSHP likely to be better choice...
scottishjohn replied to Digmixfill's topic in Air Source Heat Pumps (ASHP)
gshp will give same cop all year round --even in really cold weather,ASHP could be done to near 1-1 in very cold weather --that's the difference and some will also support that they give better COP than ashp all the time but without a lake to dump your coil in --never going to be better than ASHP in uk climate. 10 k difference between air +ground -- will be more than that in some cases -if ithas to be bore hole and not trenches I was quoted 13k just to drill the bore hole +no warranty that i wouldn,t need another one -but if done when drill rig was still there it would save 3k all depends on the ground you have -
and what were the temps on the solar thermal on those days ? do you have that info? WSW may work ok for pv --but thermal tubes definately need to be closer to south if possible flat plate may work ok when not direct to the sun ,but again they are no where near as good in our latitude as evac tubes if both were facing right way ,yes you can swivel the tubes in the frame to get better direction ,but only so much or they will be shading each other you say you have 120 tubes --what size storage tank? cos I could boil my 300 litre tank with 40 tubes quite often in summer if i wanted to and that was with a morning tank temp at bottom --using it for ufh --of 20c and top tank temp of 30c. and getting a decent temp drop on return to panels
to get best from solar thermal you will need more than one tank ,if you are wanting more than just DHW with different temp levels for the tanks -so you can always store the heat you are getting eg if main tank has a target of 80c -then days when you not getting 80c -it goes nowhere , so you need to have dif target temp levels for the tanks also if using for ufh a way to send it directly to the floor in winter when temps from panels will be low and your tank temps have depleted I am working on this for my new house ,but price of tanks is always going to be the killer when doing a cost comparison to a ASHP but I think you will be talking about 2 or 3 tanks with a total of 8-10,000 litres,(could be too much with near passiv house, maybe 5000 litre ), I think to get get all year round supply and 3 or 4 x30 tube panels I could be wrong --more work needed yet I would like to do it that way --but doubt costs will stack up by the time you have built concrete tanks in the foundations /plant room
my old petrol station flat roof self seeded sedum on its own -must be lots of seeds in the wind it took about 15 years though to get a good covering
yep -feel your roof on an overcast day --still gets warm maybe if more questions -you should start another thread before we get in bother
no problemo
nothing but copper in solar thermal and compression fittings simple extra temp switch which by pass the controller for emergency sorts that if copper then stagnation is not a problem -my problem was i was continuing to circulate --so foam insulation melted and dripped off the piping and thats 170-180c to do that power cut would not be a problem cos anount of water that would be hot would son drop intemp before it got to sunamp --very little volume in panel
as said above cost of GSHP is far too high in Uk we do not get the very low temps like canada where an ASHP would not work due to being -20 for long periods only time i would consider a GSHP is if i had a lake i could throw a big loop in --then the costs for installation change dramatically and make it the right choice -
thats part of your solar controllers job you set max tank temp and also max panel temp --the temp of water leaving the panel . it turns off if too high or you can divert to to a heat dump -like an old radiator somewhere --I like that system better as you do not get high stagnation temps in the panel which will damage panel over time if a regular occurrence. It is unlikely if you have matched panel size with storage tank-- that was my mistake on old system 300litre tank and 2x20 evac tubes--good day you got boiling tank by lunch time even though it the same tank had an UFH coil in it add to that the system was supplied with a PLASTIC air separator --which when temp sensor went faulty some years on it melted then panel temp got that high that it melted foam insulation from the copper pipes . partially my fault trying to get max from it so did not have high temp cut offs set ,but who would spec a solar thermal with anything plastic in it !! but it shows how much heat you can get if tank is not big enough for panels you have one 20-30 evac tube panel is plenty for a 300 litre dhw tank better to have too much and dump it ,than be struggling on a winters day for heat
I know of no car maker that warranties the EV components for 200k 6years or 60 k is most i have seen --that whilst not saying how long they will last tells you how long the maker expects them to be definately trouble free and last time i asked a new battery pack for one car was 6k--thats a shit load of fuel -and all test i have seen say fast charging shortens battery life- I will hold my judgement on Ev cars for sometime yet
His numerous explanations of the system and how it is not doing what the first units did has convinced me , and that@s not easy !! He has not convinced meto go PV +sunamp though .LOL ,that there is a problem with later units and needs to be addressed is obvious and he seems to have used sound experimentation to find this out as to how good the units are in reality in either old or new form could be open to a biased opinion of those that have spent the cash ,but the problem I believe is real If I want to heat from the sun ,then I will be staying with solar thermal for that ,as i have done for last 20 years
Jeremy is spot on with his views on this unit and I applaud him for being so dogged chasing them about the problems we are being told continually to save energy and be more efficient with its usage the ability to use ALL of the excess PV is an imperative towards this goal , especially as now there is no FIT tarfiff worth having to make people go down the PV way 5 -7 years to pay back was one thing now it is much longer ,then some people are just not going to take it up .
bahco are good make
yes the ratchet on cheap tools is always crap if you lean on it best value for money i think is bergen tools --not expensive but good quality + can be used daily -plenty of internet sellers at good prices as well
If i was asked to suggest cheap set for all round use then you want one that goes from 8mm -to 22m 3/8 drive only that will cover most things add to that a set of comb spanners that cover same range and you got a good start I bought some of these a while ago - www.ebay.co.uk/itm/Metric-extra-long-ratchet-spanner-double-ended-8mm-19mm-socket-adapters-AT540/123024120058?_trkparms=aid%3D333200%26algo%3DCOMP.MBE%26ao%3D1%26asc%3D56580%26meid%3D5960d59333af403dbf09b610ad5d2bf9%26pid%3D100008%26rk%3D1%26rkt%3D12%26sd%3D141594486824%26itm%3D123024120058&_trksid=p2047675.c100008.m2219 -i call them my old mans spanners --very long so you can get a good swing without being very strong- you use ring end to crack the bolt then swop ends feeling my age sometimes with some jobs --they have 15mm +18mm which are getting very common --a lot of sets miss these out -
well --yes it is cheap and cheerful universal tools usually fit everything poorly --but your not a mechanic -so light use could be ok down side will be for smaller bolts outside size of the socket unit could get in the way .# but your not guddling in confined spaces of an engine probably. put it this way a single 13mm comb spanner from snap -on is £40 . not that i use them --you can loose an expensive one just as easy as a cheap one I use cheap spanners -and except that maybe in a couple of years they could be worn --and no one steals cheap ones screw drivers +pliers /side cutters + mole grips --yes i spend a bit more on them
Vertical Tongue & Groove Timber Cladding Detail
scottishjohn replied to ultramods's topic in General Construction Issues
what stops the bugs and wasps making home behind the cladding? should there not be some sort of screen at bottom of cladding ,which could also act as drip rail? sure someone will comment -
SUDS whats that then ? like above i thought it was something to do with the washing machine or soap powder Sewage Underground Drainge System ?
- 10 replies
- suds engineer
- suds
(and 3 more)
If you can afford the difference I would go for the K7 i,ve got both the k4 and replaced it with a k7 --the extra pressure makes cleaning quicker and you can turn it down if your doing delicate things even with the 180 bar there are some types of algae that need working at to remove from the patio I also bought the sand blasting attachment -which was great for removing severe rust marking on chimney breast+ paint off railings etc --but do mask up windows if using near any or they will get marked also the drain cleaning attachment very good --it self propels itself down the drain
I think you need to start with BT --but then you could change later I think BT/open reach have to allow others to use the phone lines could be wrong --ask for quote from anther provider if you already have a phone line
friend of mine had same sort of problem he fitted a slot drain,plastic type with removable lids , all round the outside of house and that cured it
what you need is a good contact in the under world someone who will give him a limp if he don,t pay up that would better way to spend the money .LOL
