Mr Punter
    27
  1. Yes it is legal for them to request this and it is pretty good value. I would just agree to this in writing. Sewer requisition is very expensive. We had a neighbour that wanted to connect into a sewer on our land. We refused as it may have hindered future development for us. In the end they had to excavate in the road for 80 metres and connect further down.
  2. I love it. Is the whole thing raised off the ground?
  3. From the picture I thought it was pre patinated zinc.
  4. I use a cordless recip saw to modify. You can round off any sharp bits of the cut with a lump hammer.
  5. That is a great looking house. The cladding looks looks an expensive mix. Are you pleased with the Trespa?
  6. I have some Ideal Combi windows. The sound attenuation seems very good. I think the glass does most of the job. Triple glazed.
  7. I don't want to say I told you so...
  8. I am applying for a consent this week where the LA are due to introduce CIL October 5th. Does anyone have Robert Jenrick's mobile as I may need to give him a bell in case the LA look like they will not decide in time?
  9. And your next door neighbour? Forget Leicester, time to lock down Cornwall. Are you sure you are not an asymptomatic super-spreader?
  10. Are we seriously thinking that having a door butting onto the steps is OK in any way? Surely top of steps opening out would be better. If the door is not a building control requirement you can do what you like. At least with the steps you seem to have lots of going. You may be able to take a bit off the front of the bottom step so a new additional step would not protrude into the room so much.
  11. It looks like the lining will go in there fine. Some decent screws and foam and it won't budge. You could even have a deeper lining if you want. That way you can get a few more fixings in.
  12. I meant opening inwards in the photo you posted - in to the existing room. Assuming you have some steps going down into the new bit, I don't know how it would work having a door opening that way.
  13. Plasterboard is neat enough. Also more fire resistant.
  14. If you have right of access over the land this will normally be inherited by the other plot(s) you create. Clear this with your lawyers before submitting your planning application. The boundary issue and the location and ownership of the fence is a separate issue from the access rights and should remain so. Boundary disputes can be acrimonious and expensive to resolve.
  15. That was indeed a lot of trusses. A fair size house. It will look a better fit once the scaffolding is down. Was this a replacement dwelling plot?
  16. Looks like the door will need to open inwards. You could have a bifold style if you need to save room and it will be open most of the time.
  17. Hardwood kitchen worktop might work for your treads.
  18. Ask them to look again. The A393 is fairly hefty. Maybe it could be beefed up locally if required.
  19. For a small bedroom this is £450. It looks a pain to install. New floor coverings and decoration also may be tricky and there are loads of connections. I would also be concerned about ongoing product support / supply and any room alterations. For the money I would have UFH or have a top range rad for £100 and spend the £350 elsewhere. The only application I would consider this for is on the ground floor of my house on the flood plain. At the moment I have MDF skirt and normal rads but in the event of a flood I would consider changing to this. It may be an avenue worth exploring for the suppliers. I am not sure if they sell the skirting without the pipe - for small WCs and the like?
  20. I think you are best asking the engineer. Try not to damage any surfaces that will remain.
  21. Is it the case that you have a ventilated loft and holes in the ceiling? You can often just seal over these for the test. The test result should be something between 1 and 20. You should be able to achieve 5. It is for air permeability and is in m³ / (h.m²) @ 50 Pa.
  22. Thanks Damon. That may work well. Do they count in SAP? Do you have a suggested make? What rooms do they go in?
  23. As it stands, with gas heating, the heating cost for the 1 bed flat will be about £100 per year. Water heating is about £80. There is a limit to what can be sensibly improved by adding insulation. I could put some heat recovery ventilation but it would need to be small and idiot proof to run.
  24. Agreed. With gas boiler I would only have PV if the SAP says so.
  25. It just seems that anything other than the gas combis equals potential issues. The large cylinder would need to be sited somewhere. The flats will have their own water meters. I need the option to sell individual flats, or I lose a lot of investment value. As it is a flat roof there is no way that adding PV will be lower than waterproofing. If I have to go the PV route I will probably do as you suggested earlier and put it into the largest flat.
