Mike
Everything posted by Mike
Thanks for your comments and suggestions! I've gone with the smokers, and have found enough space to squeeze in a Zehnder filterbox that can take a carbon filter in addition to a regular pre-filter, if needed.
- 9 replies
- mvhr
- carbon filter
If the ducts are the right size you might be able to upgrade, rather than starting from scratch. I'm adding a filter box to mine so that I can add a carbon filter if needed, in addition to a regular G4 air filter to remove the dust.
More of a lightwell than a courtyard and, as it's in a historic area, it would need planning permission as a modification to the 'external appearance' - unlikely, even if I could get it approved by the copropriété AGM.
Congratulations - that's impressive in the French system! I'm installing MVHR in an 1840s apartment, also in France, so it certainly can be done. My renovation is projected to score a C for energy use & A for CO2 emissions. In the absence of anywhere to install any renewables, that's the highest I can score.
Can't fix, won't fix...what's the alternative
Mike replied to Thorfun's topic in Doors & Door Frames
Yes, it does. -
Planning application during divorce proceedings.
Mike replied to albert's topic in Planning Permission
Unless I've missed a change, the situation is that anyone can apply for planning on any land, whether they own it or not, no consent required. So yes. -
Hardie say that Hardie® Backer must be tanked with a suitable waterproofing system prior to tiling, so yes, if it's going to get seriously wet. I'd guess that STS would say similar. Note that although the board may be unaffected by water, if it becomes permanently damp then the moisture may reach other materials behind / below it that may be less water-tolerant. Tanking systems usually provide recommendations on this. However if the polished concrete is the finish outside the tray area, there's probably not much you can do with that part other than screen it from the water. The two main types are liquid tanking and waterproof film. If everything is in concrete & masonry where movement isn't likely, any type from a reputable brand should be fine. It gets trickier if movement may occur. In my case I have UFCH so there's a perimeter expansion strip along the junction between the floor and the wall that could move a little. Schluter, have a detail for that - as may other waterproof film systems. No, I'm already installing 2 ceiling light circuits + an illuminated mirror, so an single illuminated niche wouldn't really be a worthwhile feature. Yes, with instructions and easy - create the correctly sized hole and screw it through the flanges to the studwork, with optional adhesive. No specific instructions for masonry, but I'd just fix it with adhesive. Schluter are certainly very fussy particular about what to use and how to do everything, but they generally have a good reputation. In principle you could mix and match, but it's probably not worth spending the time looking at what is and isn't compatible.
No, generally you adopt those that are necessary or beneficial depending on a variety of factors. In particular worth knowing about these: BBA certificates - optional, but the definitive guide to when and how a particular material or system should be used for it to perform as intended, and a step up from 'manufacturer's recommendations' as they're independently evaluated. If there's a problem later, deviations could provide grounds for legal action - for example by you against the installer, particularly if you had incorporated certificate compliance into your contracts. Originally set up by the Government, now non-profit but with Government links. NHBC - optional - provide an alternative to the Building Regs Approved Documents based on their experience, plus their consumer warranty. Their standards are a useful resource and normally easy to follow. Originally set up by the housebuilding industry and encouraged by Government, now independent of both. Passivhaus Institute - the optional gold standard for designing and producing a low energy building. Until they came along, deigning such buildings was pretty unscientific and the results variable. An independent institute founded after scientific research and experimentation that originated at Lund University. MCS - Required if you want the associated financial benefits. Government sponsored.
It has a 13mm flange that's been recessed to sit flush with the surface of the plasterboard. The tanking system will then run over the flange to make it watertight. In a solid wall you could chip back the plaster to recess it similarly, or you could form the tanking into the recess as long as it's properly lapped all round. In the past I've just created a recess, then rendered / boarded and tiled it. This time it will be sitting below a rain shower getting very wet, so needs to be full water proof and I chose pre-formed for ease. BTW, slope the tiles a little to avoid water pooling at the back.
OK, here's my attempt at a simple explanation: Temperature is a measure of the average speed of vibration (kinetic energy) of the atoms within a material. Heat is transferred by atoms / molecules bouncing off each other. However there is no guarantee that any one atom / molecule will encounter another - if it doesn't no heat will be transmitted between them. The amount of heat transmitted will depend on the density of the material (the denser it is, the more the atoms / molecules are packed together, so the higher the probability is that one atom / molecule will encounter another to bounce off) and the thickness (as thickness increases, the heat has to be transferred through an increasingly long chain of atom / molecule bounces). To turn that into numbers, if the probability of one atom bouncing off another is 90%, the probability of that second atom bouncing off a third is 90% of 90% = 81%, and the probability of the third bouncing off a fourth is 81% x 90% = 72.9%; as the number of bumps increases the heat transferred goes down.
Should I have a storm lightning conductor fitted?
Mike replied to readiescards's topic in Electrics - Other
Yes, this :) It's a rule of thumb. If you are in a town with many other buildings of similar height on all sides, the chances of yours being hit goes down. -
Worth mentioning that in France, where lightning strikes are more common in some areas, there are also requirements and recommendations to fit a surge protector in the consumer unit. For single phase they take up 2 modules (see, for example Legrand 092766). They have a replaceable cartridge that shorts the live to earth if there's a major surge. In low risk zones (which would apply to the UK) a protector would be: Required if your home has a lightning conductor Recommended if your home is within 50m of a building that has a lightning conductor Recommended to evaluate the risk elsewhere on a case-by-case basis In the last case, risk factors include if you are supplied by overhead wires, have an alarm system, electric access controls, use electronic medical devices, use expensive electronic devices (e.g. computers, Hi-Fi, white goods), etc. -
Actually, the closest higher point than my house is 47m away from my house. I guess I can barely scrape by with that. Note that it's a ball, not a straight line or a plane. -
Direct Line had >200 claims for lightning damage in June 2016, 15 times higher than normal. So presumably around 13 in a normal June, for Direct Line. In 2016 Direct Line reportedly had 6.3% of the home insurance market. So, pro-rata, very roughly 240 home insurance claims nationally in a 'normal' June, and around 3,600 claims in June 2016. -
Form memory, if you could roll an imaginary 50m radius ball above your home, and other structures or landscape features would prevent the ball from touching it, lightning protection isn't required. If the ball could touch it, it's recommended. From your description, it sounds like it would be advised. -
But don't connect to an ASHP, as the temps required are not a good match. It may or may not be, depending on the heat output required. Which is why I said it might be possible.
I'd agree - there are independently certified MVHR units in the Passivhaus database that recover over 90%. Their testing regime is rigorous and often more reliable than manufacturer's figures (Heat Space & Light have an article explaining why these can be misleading). Although the Passivhaus 'Efficiency Ratio' is generally a better guide than the heat recover rate, as it also takes into account electricity consumption. This. There are even (rare) whole-house warm air heating systems, but they'd need separate ducting from the MVHR system to avoid the problem mentioned by @JohnMo. However, depending on the heat load, an MVHR-compatible scheme might be possible using in-duct post-heaters. Typically only 1 is used after the MVHR unit (or maybe one one per floor), but depending on the ducting scheme more could be used - even one before every ceiling outlet - provided the duct air stays below 50°C (from memory) to avoid the burning smell mentioned above. Zehnder produce a 4kW hydronic one (ref 472901857), for example, that could connect to wet central heating. Personally, I'd probably install UFCH instead.
It looks like they're installed through opposite externals walls? If so I'd be looking to change that, to have them both on the same elevation. Otherwise you effectively have a wind-tunnel, where the wind can create a substantial pressure differential between vents, making it difficult / impossible for the MVHR unit to properly control the airflow.
Yes, it can certainly be done, but you'll need a structural engineer / truss company for the design.
I normally align shower controls (and light switches) with the door handles.
When can you move into a new build?
Mike replied to Norbert's topic in General Self Build & DIY Discussion
For a single domestic house, I don't recall any restriction - so whenever you / your partner / your builder will let you. However you do have to start paying Council Tax from that date, and you may want to check your insurance policy. -
Proctor Roofshield has a BBA Certificate and is advertised as such. That stands independently from any terms & conditions. The certificate states that the fabric meets BS EN 13859-1 : 2014 Class W1 (a 200mm static water column) - which is the top rating (Class W2 being somewhat less good). But that is a test of the fabric, not the nail holes, which you note are the points of leakage - so presumably the fabric itself is performing OK? If you really think not and the company aren't adequately cooperating, then I guess your options include getting a sample independently tested and/or or seeking advice from Trading Standards.
