Mike
Everything posted by Mike
Opinions on this MVHR/AC combo
Mike replied to yuumei's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Take a look at the Zehnder ComfoCool, which can be bolted on to the MVHR unit. -
It would be possible to put the loops in the floor and blank them off. But if you were to connect them, then the entire garage would have to meet normal Building Regs thermal insulation standards, including air pressure testing, to be legal. That would involve fitting a very expensive insulated and weather-sealed garage door. I wouldn't want to park a car on a 50mm screed over insulation. I'd want a minimum of 100mm reinforced concrete.
Not sure what @Thorfun used, but I've recently bought (not yet fitted) a mix of Faro Hyde and Fresh frameless, under the impression that the latter wasn't orientable. Turns out they are too, it's just not mentioned on the spec sheet. Both can be set, pre-plastering, for a 1 to 20mm plaster depth (though with different adjustment mechanisms). There are some visual & build differences, including: Fresh is a bit larger with a 90mm cut-out, comes with a GU10 bulb connector, a twist-off bulb retaining ring, and a max rating of '8W LED' (though the web page, only, says max 50W) Hyde is smaller but with a larger 104mm cut-out, comes without a bulb connector, has a pull-off bulb retaining ring, and a max rating of '8W LED' As they're going in distinct places I'll be keeping both, but otherwise I'd have standardised on the Fresh and sent back the Hyde. I'll be fitting them with Tridonic modules as suggested by @Carrerahill in this thread from a while back.
Yes, I have - it's the only solution that will filter out the urban pollution on the supply air too, as well as pushing the EPC rating up from D to mid-way up the C band (in France, so UK housing policy is off the hook this time), which is much more important over here than it is currently in the UK. The only outstanding decision is which way round to put the terminals.
- 9 replies
- mvhr
- carbon filter
No, it's a historic building so there's no possibility of adding external pipes, unfortunately. I'm stuck with what I've got!
- 9 replies
- mvhr
- carbon filter
I'm also a vinegar user. Just don't leave it on too long / frequently as it can eventually affect the chrome.
While I do use downlighters, but am not keen on using them in rows for general illumination - though I know many do. Though for a regular grid of downlighters, I do commend your restraint on the quantity selected which, subject to beam angle, could create some variation in light and shade. But it's not the way I'd do it. Personally I'd first be thinking of choosing lighting to suit the particular uses of the space - so lighting above the dining table and the kitchen island, to the sides of the sofas for reading / watching TV, and additional task lighting over the kitchen worktops. That could be a mixture of pendants, floor / table lamps and spots, for example. Then I'd be looking at highlighting any particular architectural features (including plinth lighting), or where any paintings or other features may go. Finally I'd be considering whether or not there are any particular gaps that may need additional illumination. Ideally, have at least 3 different layers of illumination, with dimmers on at least the principle layer. Other factors to consider are beam angles, light temperature and the colour rending index of the bulbs.
A question for the non-smokers. My upcoming MVHR install, in an apartment, has only two possible places where the outside air intake can go: Within 1m of an external landing, where people sometimes smoke - and the smoke will sometimes get draw into the inlet. This option would have a short intake pipe, but a significantly longer exhaust (x 4). Within 1.5m of the top of a neighbouring SVP - and the smell from that will also sometimes be drawn into the inlet (not so often, but for longer). This would reverse the pipes - a short intake and a much longer exhaust. Due to space restrictions, the exhaust can only go in the other location to the intake, so I have to decide between a choice of smell-source vs exhaust pipe length. The pipes will be well insulated, but can only run through the ceiling space. In theory either smell should be eliminated by the carbon filter that I'll be installing, and if so I have a preference. But has anyone got experience of how well either smell gets filtered in practice?
- 9 replies
- mvhr
- carbon filter
You wouldn't generally fit a vapour barrier ever. However there's a difference between a vapour barrier (stops moisture vapour movement), a vapour control layer (allows moisture vapour to move through it in a controlled way - a.k.a. a 'breathable' membrane), and an air barrier (stops air moving through it). Thinking has changed over recent decades and now, in most circumstances, the advice is generally to include an air barrier - to stop the movement of air - but not to stop the transfer of moisture vapour (to allow any moisture within the structure an escape route). In some circumstances that may involve fitting a vapour control membrane. In this case I'd just cut the PIR board a little loose and foam it in place using a flexible breathable (moisture-permiable) foam such as Ilbruck FM330. Or choose an alternative insulation. And a vapour-perimable emulsion paint; if you use a standard vinyl one then the wall is only going to breath towards the outside.
Perhaps by using a car with swappable batteries. Or, in an urban area like Bristol, by joining a car share scheme, rather than owning a car.
That's already happening in France. For over a year it's been illegal to start to rent most properties rated below below E, and illegal to increase the rents of those already let. As a result, the value of poorly insulated property is falling, and more properties are being sold because the current owner doesn't want to upgrade. Between September 2019 & October 2020, the number of properties rated E, F or G going to market went up by 10% to 74% depending on the region. And G rated properties sold for between 5% and 15% less, depending on the region. Unlike the UK, various loans and tax-breaks are on offer to help landlords upgrade (though not for DIY upgrades), and there are now buy-upgrade-rent investors taking advantage of the lower prices and the financial incentives.
It's been a well-known problem for decades. Only use them if you have to.
Not sure how affordable or available it is, but there is at least one company that produces an insulating plaster/render that incorporates polystyrene granules - Vimark Thermointonaco. It could be useful if/when you need to re-render the outside. In Europe I've come across one or two similar products incorporating aerogel, but not in the UK.
I've done the same in the past & agree - it is a good solution. And, at least with some water companies, a larger ongoing standing charge.
That would be my choice too.
If you're no more than 2 floors high, a 75mm vent is fine under English building regs.
Angle Grinder - Wattage, Button/Trigger, and Recommendations?
Mike replied to Oxbow16's topic in Tools & Equipment
I've got a cordless 125mm Dewalt 1000W machine, which lasts a good time on a 5Ah battery. Would buy it again if it packed up. -
25mm is good and, at least in some areas, note that your standing charge will be higher if you select a larger diameter.
Four choices - take it down to ceiling level, fill with expanded glass or polystyrene beads (but not with vermiculate, which is hygroscopic), and make it airtight. - leave it just below roof level, fill to ceiling level as above, seal it airtight at ceiling level and in the room, add an airbrick above ceiling level to ventilate the remaining part in the roof space - if it's on an external wall and you anticipate it getting damp from rain, etc., fill as above but don't seal it - demolish it entirely, as Conor suggests. My strong preference.
Alan poses some good questions. I suspect that to properly fix it could mean stripping the entire roof to remove the load and straighten out the rafters (I guess that they're out of alignment too?) before replacing or reinforcing the purlin. But I agree that a SE report would be very helpful.
It's possible in principle, if the services in the highway are out of the way, but isn't compatible with all soil conditions. It's not going to like stony ground, for example. Even if you think you know the soil, you may come across a heap of covered-over builder's rubble / old foundations / other obstruction, so have a back-up plan.
Which shelf brackets for fixing directly in MF?
Mike replied to Dreadnaught's topic in General Construction Issues
Either that, or use a high-strength plasterboard - I'm currently using GypsoLignum. If you have only plasterboard, then I've found Fischer DuoTec nylon toggles to be good. -
I've been installing exactly that in France today, using Knauf's Easy Click (various ways of fixing it, here's one). There are multiple companies that produce the plastic stand-offs in Europe, including Siniat, but I've not seen them in the UK.
