MikeSharp01
    16
  1. Welcome to the Forum. Sounds exciting. . Loads of people on here have used MBC so you will get bags of support and info. We are building an architect designed passive house and we looked at MBC but could not quite get what we wanted from their construction method. Soooo many others will be along shortly. Looking forward to hearing more.
  2. I am not allow household porcelain on site (its all Emma Bridgewater) I have £1 mugs from Lidl - but lots of them so when one gets dirty I just pile it up and have a wash up at the end of the week - oh hang on have I reacted to the first part of of this post and missed the contextual confirmation at the end.... Anyway I have some stuff that eats concrete but not mugs so if I get any splashes I can clean it off...
  3. Now there is a word to conjure with - what could it mean - why would anybody use such a word, first known in the 15th century, as in beatification to describe a blissful smile - oh now I get it.
  4. 800mm (80cm) are the widest of those shown in my study, I don't have any of the wider ones.
  5. What is going to force the bottom few cm out? Only water coming from behind, air might do it but not sure how much air you can move with the circulation pump and running it dry is probably a big no no. Best thing is to cut the pipe and install a drain cock at the lowest point. PS I suppose you might such it out of you have a wet vacuum cleaner. PS crossed in time with @ProDave
  6. Not sure anybody would want to buy my study - here is a corner, best I can get without a fisheye lens, of what I think of / know is a typical academics (Retired in my case) study. Looking at it you can tell a lot about me from the books, although as there are 2.5 other walls so you would need the whole thing to get a complete picture.
  7. Yes, as I said I was not sure I understood this at the outset - when he did the test in the Garden room I mentioned that I did not understand why it was so low, he said that is can vary and repeated the test but the max reading was 0.27 the electric board people gave Ze (They called it Earth Loop Impedance) at the PME junction box as 0.1 Ohm so maybe the 0.3 at the distribution panel (350mm of 16mm2 earth tail away from the PME earth) was out because 4.1 and 0.1 can get to 0.25 I suspect even down 45m of 16mm2 cable.
  8. Ikea - Billy, everybody's favourite book case. Available in oak we had loads of them for the several thousand books we own and they are, well 12 of them, all behind and beside me lining the walls of my study - I stacked them two high in here and have a ladder to access the top ones - its 4.6 Meters to the ceiling! Needless to say they are bolted to the walls.
  9. Ok its all done, installed and connected. Just thought I would update with a few pics and the test results. The panel as finally complete, rewired to remove all vestiges of single insulation as suggested by @ProDave with split Henly blocks and using the piranha nuts as suggested by @JSHarris and others. All the earths are connected together here both the PME supplied earth and the rod earth I installed. The gland, lower left is screwed into the top of the piranha nut and allows me to shrink wrap (still to be shrunk ) the three cores of the SWA feeding the Garden room and maintain the double insulation, inside the gland, while allowing them to split out. Installed - the earth rod for the utilities centre (This will eventually be inside the building once it gets its frame and cladding): The rather fetching main meter cabinet with the new meter (reading 000000) installed and connected to our main isolator: Interesting to report the readings: Ze for the earth rod was 4.1 Ohm, while Zs was 0.3 Ohms, prospective Fault current 811A and Sort Circuit current of 1324A Down at the Garden room CU (without the local earth rod connected, still to run the cable) the figures were: Ze 0.25 Ohms (Not sure I understood this immediately but think I do now - why is it so much lower than the 4.5 Ohms of the earth rod down the 45m of cable at the utilities centre) Zs 0.37 Prospective fault 693A and short circuit of 928 I am told these reasonable to good!
  10. Ours is pea shingle, so not realy blinding I guess but to keep things flat I laid a 50mm strip, the thickness desired, of timber around the periphery of garden room slab, got that mm flat and used it to tamp the pea shingle to then tried to avoid walking on it!
  11. Your better off buying one i paid £120 emptied twice in the last ten month due another on Friday £30 a time i bought a 25 lite of toilet solution and added some each week and hosed out the muddy boot prints each week probably sell it for the same as I paid when we have finished +1 although I pay £50 for a service last one was yesterday but before that was - June I think - very thorough and professional.
  12. Many thanks for the offer but he tells me he has the gear and will run the tests on Friday.
  13. How can starting soon ever actually result in starting? "Tomorrow and tomorrow creeps in this petty pace" In writing these few, now famous, words it is well known that the bard was having a bathroom installed - one of the first in England, as it was known at the time, by an infamous mate with whom he was having an Onoff relationship because the pace was lente and the confabulartio between them, in the form of sonnets sent by post horses, helpful, exciting, inspiring and supportive just grew and grew.... but, inter alia, no bathroom was forthcoming. Mox, Mox.
  14. Use an IR beam set at hight above cats/ other animals it detects people as well as cars.
  15. Ah - the brother in law. Ok will await his test.
  16. Is THIS the perfect test device for my new earth rod driven in today? It's the trip device in the old house. Although it has a weakness, it basically protects nothing much, the trip is based on leakage to the earth wire and the test button does not work of you remove the earth and behave very carefully. I connected it to the new earth rod and it works perfectly so the new rod must be working at a basic level. No certificate though! Won't UKPN have a test device I can blag a test from / with?
  17. Yes - luckily we are on clay, I will drive the rods tomorrow in readiness for Friday.
  18. Makes perfect sense but I am now a little more confused than I was when I started this topic - drawing the threads together: @ProDave said: "There is nothing wrong with you connecting your own earth rod to the main earth terminal to supliment a PME earth" Also the consensus appears to be that the local earth rod required for Caravans, metal cased plant etc is just to protect the 'local' users from a Neutral fault on the DNO network as it ensures that there is an earth connection beyond the DNO network in which the fault can occur. @JSHarris said - in terms: that the the RCD that protects his Commando socket will trip if there is an in-balance in the L / N beyond the device and I think he implied that this would happen even if the earth were not connected as it is one of the 'any arrangement's and makes sense because the earth is not part of the in-balance. So it seems to me that: In drawing up the 'regs' diagram for a site supply the powers that be have erred on the side of safety by drawing a break between the incoming DNO earth and the site supply earth, connection via an earth rod, so as to ensure that an earth rod is provided and not ignored because 'the (PME) TN-C-S earth did the job'. If it looks like double bubble someone will cut back and use the TN-C-S earth thus rendering the thing dangerous. Any earth rods you have can be connected together across the 'property'. This means that: In our case we have the garden room, about 45m from the electric incomer and fed with a 3 core cable (16mm2). The Garden room also has a local earth rod which I will now be connecting to the earth cable exported down the garden - it was going to be isolated TT as Jeremy's workshop. For the GR the exported erath becomes the backup earth, protected from a rising voltage by the other local earth rod at the utilities centre end. Our earth rod local to the utilities centre, where the incomer is, will be connected to the earth connection provided by the DNO, assuming they supply one. That way I will have three earth connections any one of which should keep the place safe if the RCDs are out of the loop (pardon the pun).
  19. I guess this is the reason the earth is separated in the regs but is it the confusion over 'site' as in caravan 'site' or building 'site'. I have no caravan, it is all fixed buildings but it is a building site although one building - the garden room, is in place. For caravans, neatly insulated from ground by rubber tyres, I also guess the DNO don't want to be responsible for how far their earth can get above ground potential depending upon distance to a good earth in their system. Does that make sense?
  20. Thanks chaps - Looks like all will be well. I have asked for a PME supply and the surveyor for UKPN was OK with that so I assume they will give me that. Roll on Friday!
  21. The electric company (UKPN) are due to come and move our meter and install a new supply on Friday. I am installing a local earth rod - not quite sure why though, see image below. As things stand we have an overhead supply from a pole on our land. It is a TT supply to the old house, we have an earth rod providing the earth local to the old meter position. The other houses on the pole seem to have an earth provided by rather poorly connected earth rod at the base of the pole. When they come on Friday I think I am expecting them to provide a PME (TN-C-S) supply, just like our neighbours, which uses the earth rod at the base of our pole. Are they allowed to give new properties (this is a knock down and start again project) TT supplies? Given the regs I have decided to provide a commando socket to power up stuff outside (it is not designated as a site supply), although might be used on the site if it power cannot be derived from the garden room external sockets (which itself will be supplied by the distribution panel). The earth rods, ours and the UKPN one will be within 2m of one another. My question / puzzlement / what am I missing is / are: Given the proximity and cable run between the the two earth rods why should the two earths NOT be connected together in the distribution panel. I did doodle a resistor network to try and get my head around this and am not sure I can see an issue - but it maybe just circumstances.
  22. Hi and welcome to THE forum. Love the design, no gutters and jet black - just like ours. Looking forward to hearing more. +1 on what is with the bunk room....
  23. Yes will PM you with his details, he is based in Mid Kent.
  24. Whow that must be some data hungry kitchen island, may be the fridge is actually a super computer in disguise, or the chef likes to watch half a dozen 4K streams at once while the hob needs to download all the data coming back from the Hubble telescope in real time.
  25. Yes but it has been a bit of a pain as manipulating them is tough, I have converted all the main drawings into 2D for the build but keep the 3D for reference. The interoperability standards for drawings are a complete pain, I was so frustrated by a 1mm difference between the Architect and the SE - which came down to decimal places rounding error, so once you have it in a form you can manipulate I would stick with that. On the extension you can let the SE build on your drawings their concern won't be the details that you a3re concerned about they will just do the loadings and, as you say, beam work. Just brief them to keep it simple and give you some lee way on lengths of columns if the floor build up might change. One thing that caught us, and the architect, out and required a reworking was the bases of columns extending beyond the walls in which the columns were built.
