Yes we have a datum based upon a survey nail in a sunken brick with two fixed back sights all set by our surveyor I think we do know the AOD of the brick but it us not used anywhere and our PP gives the FFL of the ground floor as 500mm above the datum and everything is linked back to that as the architects 0 datum. Looks like Ian has sorted his issue out, thanks to ANON - this is exactly the sort of thing this place can faciliate so all praise to them, but I was not sure how his AOD heights link back to his planning permission or if some other datum, in the way ours does, defines the heights. Given the drawings it looks like it is the OS so all should be well.
- 39 replies
- rim joist
- wall plate
(and 8 more)
Wood Burning Stoves to be banned in London
MikeSharp01 replied to Triassic's topic in Housing Politics
Wood burners are not a problem here, in the verdant grassland around the Kentish M25 in between the M20 and the M26 the animals like it better than diesel smoke and noise! I chop down a tree every year, log it and let it season before stuffing it up the chimney using simple combustion, perhaps I should stop. I worry however that my contribution will make little difference as this article points out that possibly the worlds 15 largest ships create more sulphur pollution than ALL the worlds cars put together and although it was a thought experiment by Prof Corbett they looked at it on more or less yesterday and found it to be a good one. -
Perhaps an alternative would be a thermostat on the incoming pipe which switched off the ASHP if the flow temp gets too high.
- 39 replies
- under floor heating
- ufh
Makita and Coffee Lovers Combined
MikeSharp01 replied to Barney12's topic in General Self Build & DIY Discussion
I was speculating as to the appropriate SI units for rate of tiling. My investigations have found two units - as opposed to the more normal case of just the one unified unit. Also more curiously in this case the only difference is in the scale of the time divisor. So (sorry bad grammar Jack) in the normal world the unit is m2/hr while in an anomalous corner of the south east (not far from here) the unit is m2/aeon. This gives us tremendous insight into the curious disturbances in the self build fabric which occasionally manifests itself in achingly slow progress but is yet perfectly aligned with an official measure of getting things done. -
Me to! but if a standard OS datum I wonder how it was transfered to the site and why it is so prominent on the drawing. One might expect a single datum zero on the site tracked back to OS datum this way it just feels confusing and you need a vastly long tape to measure heights.
- 39 replies
- rim joist
- wall plate
(and 8 more)
Do you not only get 30 days free so better hurry up and get those questions asked.
- 47 replies
Sorry, just the drawing value, no sums done.
- 39 replies
- rim joist
- wall plate
(and 8 more)
@recoveringacademic TOC is top of concrete and the value is the 27.255 height from your drawing. I assume the 27.255 dimension is to the bottom of the piles because if it is from some other survey datum point it may be worth verifying it so you can be sure everything is correct in relation to the datum if it is not the bottom of the piles.
- 39 replies
- rim joist
- wall plate
(and 8 more)
Should read 30.255 and 30M is a long way down. They must be working from some fixed datum a long way away unless its the bottom of the piles, it was piled I think. The other thing to check is how the current unfinished floor on the ground actually compares to that TOC value if it was a planning condition.
- 39 replies
- rim joist
- wall plate
(and 8 more)
I would worry that those screws should be securing things! Could they be like the screws left over when you have disassembled and then reassembled something. Although I am reminded of a story told by a 90 year old friend of mine. He used to sell cars to the Americans who were over here after WW2 and he would go to the factory and collect them. On his way to delivering them he would stop and lift all the carpets. Removed the dozens of nuts, bolts and washers left over from assembly that were rolling about in the floor pan and replace the carpets. The cars were quieter and pretty soon he had a world class selection of nuts and bolts.
The FFL needs to be checked with the architect as they may have the FFL as the top of floor finishes (wood / carpet/ tiles/ screed) or the top of the sub floor onto which the finishes go. If the former then you need to also add in the thickness of the floor finishes.
- 39 replies
- rim joist
- wall plate
(and 8 more)
Thanks chaps (assume Chaps) yes I suppose what I wanted to do was save cost if I reduce the PV I could stay above 100 but only, it looks like, if can squeeze down the MVHR as the fabric is pretty much at its limit already. Maybe I could improve air tightness a little, used the PH standard for the preliminary calc, I would expect to do better than that anyway but cannot find the equation linking air tightness and SAP points anywhere.
Our provisional BC SAP came through at 101 A (6Kw of PV or 107 with the full 8Kw) which makes me very happy. However the assessor told me I could have got two more points if I didn't have the MVHR because of the energy it uses. Can't live without MVHR so was wondering what the collective experience was with SAP and MVHR, can I get a better MVHR (Unit so far in the frame is: Airflow Adroit DV145) what, I wonder, is the conversion from energy use to points (Banded / Algebraic / ?) because I am not sure I will get a much lower figure.
Sad - depressing and distressing for you and the family. Have you any pics of the frames. Might help stimulate ideas.
Starting to think about MVHR
MikeSharp01 replied to MikeGrahamT21's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yes I have rusty hinges on my barn doors no wind will blow them shut. -
Plaster is, as I understand it, a good air tight layer. -
Screws driving us screwy
MikeSharp01 replied to ToughButterCup's topic in General Self Build & DIY Discussion
Its all about the amount of torque they expect you to apply, it has a standard - there are only 5 sizes, and the design should reduce the cam out potential, against Phillips head for instance, at normal torques. Most of the screws I have brought recently actually came with a free driver bit of the correct size!- 29 replies
SH 1 T you mean they are different - its OK though cos I must be a proper tradesman.- 29 replies
No easy way I have ever come across. Do you have a multitool? If so you can probably cut the wood away from around the screw head and then grip the head with a pair of mole grips such as these. You can then twist them out. One thing to remember about these screws, well most of them, is that the are hard and can be snapped off - they don't like bending, by accident or perhaps for you, on purpose.- 29 replies
I guess they had no stake in getting them out so didn't worry about putting them in such that they could be extracted. That is quite a nice selection you have there though. Some are wood (L-R) 2,3,& 4, some for concrete 1 one for roofing material 5 and I cannot identify 6 but i must be a high torque application as it uses a torx head drive like the first. Plus, it looks like you have rested them on a very neat tea cloth ( dish / towel).- 29 replies
MVHR visible ducting
MikeSharp01 replied to graeme m's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Thanks, will try that and see what happens.
