Yes I will take some when I get to site in the next couple of days.
Two thoughts - Given your locale I might go and look at boat equipment with some brighter LEDS assiking you are going for a low voltage (24V ish) then they will have complete systems. On the other hand you could install a mains based system that steps down to cage a battery and is then inverted back up from the battery to run some 240V stuff.
Help me find a dual rate electricity meter.
MikeSharp01 replied to ProDave's topic in Boffin's Corner
I would go another way and buy a couple of small energy monitors and then turn the clamp sensors on/off with the rate switch relay. -
Two things jump out at me really. First is the sitting room / WC ratio / layout. I would push the wall across and squeeze the WC and its anti room to make the sitting room a bit bigger a small WC could still be accessible to a disabled user and you will appreciate the space in the sitting room also here you have the WC on the opposite side of the room to that in the ensuite above it so making the foul pipe run more complex than it needs to be. Secondly I am not clear what the 1m gap behind the bed in the master bedroom is for.
Welcome to THE forum for self builders.
You couldn't wish for a more lovely site, although the water table will be quite high! Something a bit 'striking' will go in there well.
On the main question: We had almost the same set of possible 'designers' one RIBA - full architect and one passive house experienced RICS member designer. In the end the costs were very similar but we went for the Architect because we felt we would get a better design going that way because the RICS guy, wonderful portfolio, tended to be a bit restrained in their thinking. This may have been because we wanted a passive level house and the RICS had all the experience wile the Architect had very little which meant the RICS team would tend to start from Passive while the Architect went for design and then worked towards passive.
Welcome to THE forum for self builders, can you give us a hint as to where you are. Sounds like you are beside a Canal somewhere.
Exactly our experiance as well.
- 10 replies
- planning
- building control
(and 2 more)
I did a load of work on some 60mm thick oak treads for a friend they were green oak and I used the cnc machine I have access to so as to put pockets in the bottom and drill fixing holes. It worked out very well once he had put them all up and he dud expect some splitting to make them more rustic.
Hang on, I can see how this might happen, suppose the blockage above you has always been there but not apparent - always somewhat restricted. Now however there is a blockage below you that used to be open to the atmosphere so flow, once past this new failure point, sucks the traps above it. IS there a delay before the gurgling starts.
Nick - trying to work out how the problem might be below POCSTER but drew a blank is there a root to this?
Work canopy for our flat roof: wiggle wire
MikeSharp01 replied to ToughButterCup's topic in General Construction Issues
You can find it here: http://www.northernpolytunnels.co.uk/w-wire-wiggle-wire-polythene-fixing-system.html -
Interesting conundrum in as much as getting the architect aboard is a sound idea but you need time to do that. Before your do have a read of what @caliwag, an architect himself, has to say on that score, get your mind round the constraints you want to put on them and the nature of your solution both of which will affect the choice of architect. So it maybe that getting a survey will add value by giving you time if you see what I mean. On the other hand and as Tyke2 says having an architect aboard has all the advantages of their knowledge but get your ducks lined up in terms of what you think you want - mood boards etc before you appoint. If its the same as the neighbours then probably an architectural technologist is a better bet than a full architect, cheaper and they more do what you want, which is constrained by what you can think of, rather than give more what you need by interpreting your thinking as a design for you.
Welcome & lucky you are to be living in North Devon! Probably not after we had paid all the claims for Ethically Relative advice!? PS We used screw piles to strengthen the foundations of a single story building we built on the top of. Much easier than digging out and backfilling with concrete.
They look good but you probably need a lot more noted detail / specification for the BC people. EG specification of timbers (C16 / C24) - spacings, RSJs etc. We (English - rules apply here) had to provide all the structural calculations for ours and a set of section details showing how the flashing, DMP, DPC, drain runs etc worked. As you have a PC I would get a copy of DRAFTSIGHT (Its free) and learn to drive it as it makes editing drawings so much easier - right first time is very hard on paper unless you have a lifetime of experience to support you.
Would the unit allow you to run the UFH from it assuming no other demands although the reversible cooling question then arises - assuming the unit has this feature and you could pump hot air out of the exhaust it might contend but in both modes power is likely to be a problem - have I got that right? We are going through the usual mill of deciding how to tackle the DHW side of things and had ruled out ASHP for DHW because of the infrastructure you need, losses associated and the availability of gas on site. ASHP for UFH looks like the chosen route. However we now find ourselves between a combi boiler just for DHW & maybe emergency UFH and one of the many SUNAMP systems - so am looking forward to hearing the @JSHarris verdict on the latest incarnation.
As @JSHarris says but I have, in the past, squeezed the metal tab to close up the hole a bit before re-threading as this often helps if the hole is striped of its thread, twisting the tab can also help although it gets to be a bit more of a bodge!
Does self building improve health?
MikeSharp01 replied to epsilonGreedy's topic in General Self Build & DIY Discussion
Yes - it does seem a bit odd that @recoveringacademic feels that this is the result of (or could be rooted from) ethical relativism, although I think I can see how I am not sure that Ethical Relativism is well understood and in this context might well have created an unlucky outcome. The problem is what I think of as the lack of 'grey scale' understanding that it embodies. The infinite grey scale, it seems to me, gets forgotten in as much as people neglect the clear fact, as I see it - ooops, that ethical relativism on any issue is an analog rather than digital signal - IE is has continuous change and is therefore not a step function. So this means that any two people even with the same, exactly, socialisation (By which I mean inclusive background) will still be able to identify differences between their outlooks. So where you draw the line becomes a very, very, fine thing. Hence our friend from Norway may well only be a scintilla away from the next person in the group but the line has been drawn there - I am not at clear why! PS great topic for a lunch time seminar - back to the sole plate.... -
Retrofit underfloor heating recommendations?
MikeSharp01 replied to ThePoplars's topic in Underfloor Heating
Think it will still only be electric that is available, water based systems are two thick to get in much under 50mm but you might get down to 40mm at a push. How are things up on Teesside? Our son did his industrial placement in Redcar (great TV that is making just now - mighty Redcar), and we spent several breaks visiting him getting to know the countryside and the industrial landscape along the Tees - very much off our beaten track until then. -
Obtaining restrictive covenant insurance
MikeSharp01 replied to Moonshine's topic in Party Wall & Property Legal Issues
Although I may have misunderstood I cannot see this being vastly costly as you do intend to stay within the confines of the restriction - don't you then the risk is one of interpretation, and if you are not then you won't get insurance cheaply as the risk is bound to crystalise . Under which circumstances I would fess up to the 'relevant party' so they are not surprised and negotiate change. -
We went round the neighbours with the draft plans before submission and got their feedback, we also tried to be good neighbours, joining the residents association, paying the fee, and joining the work parties - its a private road so upkeep falls the residents. We need not have worried perhaps as essentially they were happy to see the dilapidated bungalow go and we had no objections. We are still working at being good neighbours having paid for the footpath adjacent to our property to be resurfaced and keeping on with the working parties. They all seem happy - the only problem came when we had a bonfire to burn all the vegetation which we had heaped up - the garden had been neglected entirely for 10 years, one neighbour did complain about that so I put it out immediately and light it up again once she went out.
Welcome to THE forum, look forward to hearing more about it.
Welcome to THE forum for all things self build - anybody who can make what is essentially a creamy liquid stick to a ceiling gets my respect!
Our AFT foundation L section pieces came already rendered so we didnt have that problem, although to be fair, when I ordered it I was expecting to render it. My plan was to stick the Marley thrutone cememt tiles that the whole house is covered with on the outside as much quicker than render. I have done this with polyurathane glue (5 minute) on the garden room and it works.
