Everything posted by Construction Channel
Better type of expanding foam
Construction Channel replied to Russell griffiths's topic in Building Materials
After quite a bit of testing I think I like this one the best. At least I haven't found it goes brittle at all. It has a very good and flexible skin to it, sticks well and has very small bubbles. -
Hidden Door: anyone made one, installed one?
Construction Channel replied to ToughButterCup's topic in Doors & Door Frames
I'm fairly sure you will beat me to it but I am hoping to do a similar thing. Plan so far is to have it work similar to a van side door. E.g go in first then across. It will have a top and mid rail on the wall and ceiling and if I'm feeling really flamboyant it may get a brass track embedded in the floor. Otherwise it will just run on the tiles until It "needs" a track on the floor. Further plans involve soft closers at either end, possibly actuators to make it automatic but I'm still trying to work out a manual override system so I can't get locked in, and it would be really nice if I could actually use the fob and locking mechanism off a van sliding door so I could lock it off the fob but that may not be part of the first prototype. Hth Ed- 21 replies
- hidden door
- building regs
Fixing joists to the wallplate
Construction Channel replied to ToughButterCup's topic in General Construction Issues
Just to be different I fit all the hangers first, with an off cut to make sure the bottom is in the right place. Issue with this method is the timbers all have to be the same size to avoid the floor undulating. But unless you use a thicknesses on every one, one side is going to suffer, technically should be the ceiling iirc but you can’t have everything. Other than that my only advice would be to use 40mm twist nails. They’re over spec but you won’t hit your fingers as much with them. -
Quick check, please..... wallplate
No, if anyone asks just say it’s to stop it sucking damp through the wall. Or expansion. Just make it sound convincing -
First time DIY: how many of us?
Construction Channel replied to ToughButterCup's topic in General Self Build & DIY Discussion
I feel very left out of this. Just because it’s a busmans holiday doesn’t make it any easier. ? -
What do home buyers want?
Construction Channel replied to Dreadnaught's topic in New House & Self Build Design
Supposedly broadband speed and schools are top priority at the moment, not that you can design them into a house but might influence location. Personally I recon it would be the stairs and worktops that sell houses. Possibly doors also. Howdens oak dordoigns seem to be all we fit recently. -
Should be fine. Usually they just phone your home branch to check what discount you get. Why are you planning to go to different branches?
Pumping....it up hill
Construction Channel replied to Construction Channel's topic in Waste & Sewerage
All very interesting I’ll give them a ring on Monday. I’m now intrigued weather I’ll be better off buying a 2800lt tank for £600 giving myself plenty of leeway and then just getting a pump system separately. Ill see see what they say as the size of the hole is almost irrelevant to me -
Thanks for the advice, and more importantly numbers. I’ll do some more searching and see what the most cost effective solution is. -
Tbh it wouldn’t be me that’s putting any of those things down there. But what I want to avoid is having to replace or unclog the pump because someone has accidentally. A friend had a saniflow years ago and constantly had problems, I want to visit that tank and pump as few times as possible so a “deal with anything pump” is what I’m looking for. Weather or not it has to deal with anything other than the standard depends how good faye is at following the rules. -
Any reccomendation on litreage? -
I need advice on what to buy to pump sewerage up hill. We installed a new bio disc/ clargester at the parents house a few years ago which we made big enough to take my new house as well, so installing my own sewage treatment plant seems a bit of a waste. Problem is the inlet to their plant is above my drains by about a meter or so. So I need to pump my sewage up hill. The last thing I want is to have restrictions on what I can put down my toilet (lady products) like a saniflow. Nor do I want to have to replace the pump anytime soon as that will be a foul job. I have heard stories of pumps that can shoot a full sized nappy out of a 2” pipe which is the kind of thing I’m looking for but how would I go about searching for that? had anyone already got or installed such a system? i have briefly searched eBay and this seems promising but it all seems a bit cheap and non descriptive to be any good. Any help appreciated. Tia Ed https://www.ebay.co.uk/itm/112675960892
I’m fairly sure it’s Threshold
I don’t disagree that they’re useful. Iv got quite a few of them about. But they’re not as good as the real thing at any task.
It depends how much your drill bits cost. Even if you have a nice set of hss g bits I still wouldn’t be spending £150 on a sharpener. £50 maybe as a new set will cost you double that, the multi bits are ok at most tasks but imho they’re not very good at any of them.
Plastic bullnose window cills - any one got them?
Construction Channel replied to readiescards's topic in General Joinery
Lol, but yes I agree they’re rubbish and no need for them, go for wood. You have plenty of frame to play with so it won’t look out of place. You could rout out some of the back to make it thinner if you wanted but don’t go too thin else it will warp. IMHO plastic inside is a big no no. Also im still here just been a bit quite. Too much to do and not enough time. I’ll update you all soon.......ish -
Which sealant for this job, please?
Construction Channel replied to ToughButterCup's topic in Flat Roofs
I would have said it’s gutter seal or similar. Loads of movement and sticky as hell. Everbuild ROOF Roof And Gutter Sealant, Black, 310 ml https://www.amazon.co.uk/dp/B003OVCCU8/ref=cm_sw_r_cp_api_rUhTBbMVYM3YY -
There wuz I Digging this 'ole .....
Construction Channel replied to ToughButterCup's topic in Waste & Sewerage
[...] a bit late now, but at that kind of depth, she really should have had your harness on attached to your digger, at least when we were digging deep footings thats what we did, its easier to pull someone out than try to dig around them in a hurry........ i assume it all went well though? -
UFH pipes in the walls, not floor? Silly idea?
Construction Channel replied to Dreadnaught's topic in Underfloor Heating
There is also potential for a lot of air locks, especially if you went up and down between the studs.
