Nickfromwales
    345
  1. x2 What about this bad boy? Complete with GCU too
  2. Cheers. First machine is #1 choice at the mo. But...... This is is on Gumtree at the moment. Sounds a lot for the money but how does it compare to the i7 chip? Ill buy you beer ? I promise.
  3. Beams straight onto the blocks / pads, and same for the blocks. You can get mesh tacked on if you want, for longer beams but not necessary in most cases.
  4. @Bitpipe Hugh, did Smiffy fit the same USB sockets for you ( not plug socket integrated but stand alone ones ) as he did for Greg? These had an integrated switch which only energised the transformer when an USB plug was fully inserted. Whats the general consensus with the vampire load on these cheap ones ( socket USB duos ) as I can't recall seeing one specifically mention if the transformer is constantly energised OR NOT? A house full of these may add up but I won't shit the bed over it that's for sure. Exactamundo squire. . The dustbin lids constantly disappear with ours, and it drives me nuts. I've promoted / fitted these on the last couple of kitchen fits and folk are raving over them. Less clutter and more convenience. Try to keep up old boy
  5. "During the war, Rodney"...........
  6. The screws aren't 12 o'clock to 6 o'clock
  7. ........."HEPWORTH!!!!" Top stuff. Go for the brass ones IMO.
  8. The good old days..... I can't talk though, my dad always followed technology and my brother and I always had the best of whatever was about at the time ( BBC A upgrade + Opus Challenger 3 in 1 Double sided Double density disc drive ) and a light pen ?. I put a board full of 256 EPROMs in it so my games were stored on memory which made me a god, even the computer teacher came to me for advice as I had the BBC a year or so before they got into the schools. The last machine I linked was the 2tb cheaper machine, so, according to Sir Chopsalot, the original one does come with DDR4 ram, whatever that is. . Gives me a knackered boiler any day. You build my PC and I'll tile your bath ?
  9. The only advice I can add, is to go for pine / other wood in the bathrooms, for just that side of the frame. Having even a bit of splashed water at the floor / architrave junction will result in what I have.......swollen first inch syndrome. Mine have already gone after just two years and a lesson learnt. They'll be coming off soon to be replaced with wood. Id also suggest that for kitchen / utility, you fully paint the underside before cutting and fitting as this will be a good way to guarantee that mopping etc won't cause similar issues.
  10. Ok, so grab the PC for now, and do a swap out when the GC comes along. . Cheers, and my boy has already confirmed most of what you've said.....he's a clever little bugger Hello new PC, goodbye wallet ???
  11. I'd rather hang on tbh and get further 'council' before parting with my moola. Fyi the graphics card and PSU are something I'm aware need to be added, but that was a birthday hit and this is the Xmas hit. . Will the big GC and 450w PSU fit in the zoostorm machine? Sorry if I'm missing the woods for the trees here but can you give me a yes or no for my sanitys sake ? If your sure it'll be better to make a machine from scratch then I'm 100% up for it. What's the BEST direction ?
  12. Can someone please translate From what I got, the zoostorm is only going to end up as a bloody donor pc ?!? The case is too small to upgrade / install the graphics card it seems. Now even more confused ( but thanks for the heads up ? ) so do I just buy all the 'separates' and make the damn thing from scratch? Clocks against me too ??
  13. Bump Anyone know if that graphics card ( or probably a bigger one ? ) wil go in this machine? Says a mini tower format or some other computing voodoo, I know not of this world. I'm assuming that it'll need the power supply upgrading, but I can do that when the graphics card goes in, can I not?
  14. Double up on the EPS and save the good stuff for elsewhere. It's not exactly going to be hot against cold under the bath . You could just drill a half inch hole in the side of the boxing in, after fitting the bath, and squirt a dozen cans of exp foam into the void .
  15. Ooo, they do a 1200 x 150mm too.
  16. cheers ?
  17. Was 1200 x 300 a typo ?
  18. The 1200x300 please. Haven't seen one.
  19. Use elbows . That way you won't be grazing the pipe on the concrete whilst trying to wrangle it in.
  20. Do you have a link? ?
  21. Please do ?
  22. I wouldn't fit these in the main rooms, but for storage / wardrobe space etc they're a good option. Masses of light, great dispersion and non-obtrusive ?
  23. I've seen similar 600x600's and they're great. They came naked / frameless and were supplied to drop directly into a modular suspended ceiling, with an optional frame for installing onto a regular ceiling. With LED it's usually a good idea to buy a sample and see what the light is like as they do vary and can be anywhere between yellow and blue tints.
  24. When you switch off the preheat tanks you then revert to the DHW performance of a straight 38kw combi . The boiler is a Vaillant 938 ( 38kw ) so not 35kw as mentioned. You wont get premium DHW performance without the preheat so consider the annoyance of anticipating when youll have to activate / deactivate it according to demand. Also best to remember that all these devices ( combis / uvc's / TS's / instant inline heaters ) are ALL fully cold mains dependant. E.g. Crap water pressure / flow in = crap performance, regardless, so make sure you design a system based on that as well as the devices ability to provide X litres per min DHW. Regarding the plumbers suggestion of two boilers.....utter tosh. I would SERIOUSLY reconsider moving forward with a plumber that so poorly understands your remit.
  25. Let's not get ahead of ourselves eh? ?
