Treatment plants have low level VP's so I don't see the problem tbh. Challenge the BCO I just did and saved the customer about £10k .
Thin structural flooring boards needed.
Nickfromwales replied to ProDave's topic in General Flooring
Why not infill between the 'joists' with battens and 18mm ply, finished flush. Then put a 12mm V grooved engineered floor down. Bingo. -
PMSL. ? -
Ok, that's your lot ?? Just getting my yellow cards ready .
Black Friday Bargains
Nickfromwales replied to Ferdinand's topic in General Self Build & DIY Discussion
I WAS supposed to 'inherit' my boys laptop, but it met with an untimely death as my boy was, most likely, swinging a fist at it when getting shot or overtaken during gameplay. ?. I love kids, but couldn't eat a whole one.- 76 replies
- black friday
- amazon
After an hour of my boy going on and on about the PC he wanted, I remember he knew it'd need an upgraded graphics card. Iirc it was something along these lines- 76 replies
- black friday
- amazon
So no need to worry about the 3tb being HDD then on the Argos kiddy?- 76 replies
- black friday
- amazon
So the 3tb for general use and keep the SSD for less frequently accessed 'important' stuff?- 76 replies
- black friday
- amazon
I've got a 500gb SSD from my boys dead laptop. Don't know if that'll go direct in the tower or need a case and go external?- 76 replies
- black friday
- amazon
- 76 replies
- black friday
- amazon
Spec / cost please ? ?- 76 replies
- black friday
- amazon
Any thoughts on this PC ? ?? Needs a good graphics card, as it's for my boy ( gaming etc ) but with i7 and 3Tb sounds a good price. Ta.- 76 replies
- black friday
- amazon
Quote from the link, "The ecoTEC plus 938 is a 38kW high efficiency storage combination boiler which has been designed especially for larger homes which have a higher hot water demand."
Good luck with your nighttime reading ?
SAP should go against its lowest kw output ( e.g. when fully modulating). Is that the case? If so, iirc, the Vaillant will go down to 9kw.
Have you seen the Vaillant 938 ? It's a hi-flow heat store Combi and as long as you have VERY good cold mains, or have taken measures to provide it, you'll get two adequate, or one blasting shower out of that with ease.
For sustained use I'd recommend going for a soft grip handle to absorb a bit of the impact. Like dave I bought a bright neon green bugger so it's harder to lose, just seem to lose everything else now ?
Oh, and put the trim at the wall / reveal junction so the flag is on the wall NOT the reveal. That'll gain you an extra 2mm -
Use sika to bond the tiles on the reveal so you just end up with the thickness of the tile against the window. The sika can be fag paper thin and still hold like a chav with a winning scratch card. -
That's mighty close to the glazing bead, have you checked it for a tile + adhesive? -
Floating or Fully Bonded floor over UFH
Nickfromwales replied to Stones's topic in Wood & Laminate Flooring
In a low energy home with high levels of insulation under the slab, I'd really not worry one bit about heat transfer / losses caused by the lack of contact caused by the underlay. The only point I'd raise is if you have this wood in some areas and not in others. The areas where the floating wood is laid may benefit from a very slightly higher flow temp but that may then overheat other areas ( particularly important when all zones are controlled by one stat, eg a single flow temp per zone ). Have you zoned the heating ? Is the wood throughout ? -
They being skimmed or tiled? -
Rubber flooring looks good, and will make it easy to clean up whilst giving increased longevity to the subfloor. . Do you have the link / how much per roll ( £ p/m2 ) please ?
