Nickfromwales
    346
  1. I think @Temp's point is a valid one. Stainless clips are easily sought, and as Peter says, there are correct and incorrect types. This isn't at you terry, this is about ensuring you and jan have a safe and reliable installation, hence you posting it accordingly for comment / approval. . Is the pipe sleeved where it goes through the wall ? Apologies if you've already answered that.
  2. I assumed this would have been eliminated ?. Good point ? When the combi was fitted, did they fit new rad valves to BOTH sides of EVERY rad? How many radiators?
  3. Sentinel Leak Sealer is what you want. . Very good stuff and works lightning fast. Dose and run the heating for an hour as hot as you can get it, then after the leak is cured, drain and top up the inhibitor.
  4. Use this for sloppy joints. Sorry for the late heads up
  5. Hi @A_L. Thanks for the input . Can you give us a brief in the 'introduce yourself' section please ? . Many thanks ?.
  6. I think they'll be more than happy to just leave you the tails sticking out for you to connect up as and when. One less thing to distract them from the important stuff .
  7. Yup. Scratch it up with 40 grit and use the proper solvent weld cleaner before the actual weld. Clean is the rule.
  8. Brick. .
  9. Can you easily get a duct in now? Change of £300 notes isn't to be sniffed at. It's certainly worth a second, or third thought. Btw, it's a lot more than running 2 pipes . Blow off, condensate, cold fill and associated cabling. You can only future-proof so much mate. Maybe toss a coin and let the queen decide. ? ??
  10. ?. That looks awful familiar ?? Patent pending me thinks lol. Manifold plumbing has a good few advantages. One which I found most useful is to be able to purge and set to work each individual run without having to pressurise the whole installation at once, like you have to do with series ( regular ) plumbing. Very handy indeed for those who mostly work alone for the finer jobs, like myself. Keep at it! Looking good so far ??
  11. +1 I know a lot of boys who are GSR'd and do fires and cookers without the relvant tickets. This can't be done on your vanilla GSR and you have to either do your fires and cookers at the same time, or go back later and do it as a bolt-on. NOTE : Always ask to see your GSR'd fitters card. On the reverse is all the different types of equipment / classes of what their entitled / qualified to work on or install. .
  12. NOPE. If you aren't up to speed with regs, equipment and it's installation criteria, YOU DONT TOUCH IT. Ignorance or lack of experience is nonsense. A GSR fitter will have to specifically and separately sit the LPG section of his / her qualifications so they'll have ZERO gap in their knowledge. That is renewed every 5 years so, sorry J, that's not a reason at all.
  13. When I become the worlds most proficient plumber, I'll be too farked to pick up a spanner. Ah, well. ? Cheers !!
  14. That's the joy of having time on your hands . For me, working on price, things get fitted once. That plywood was all in before soldering, so with the correct blow lamp and a burn mat there's no reason to risk property or roast the surrounding material. ( And, the whole arrangement can be removed with a screwdriver and a spanner, as just out of shot is the isolation / bypass arrangement for the softener, complete with compression fitting. ). @jamiehamy The arrangement is exactly how you described it. The only thing I'd change if I had that job again ( that was my fist true PH installation btw ) would be to feed the secondary TMV straight off the TS. The reason for that would be less dead water to get rid of before getting hot flow to the basin manifold ( furthest right ) plus it would convection pre-heat so would always stay warm / hot. The next one will be perfect. The one after that even better. And the one after that even more betterer. Continue above reasoning until death. ??
  15. PS I'm happy about the ECV btw, just good practice would have seen a secondary ECV and a test nipple immediately afterwards. Theres gas fitters, and there's gas fitters.
  16. Ok, terry, I can see your frustration. BUT your fitters horse and cart are very much arse backwards. You cannot make a gas installation live and walk away with a list of essential items not done. End of chat. Saying that you'll need to fit chains at "some stage in the future" when you go for a completion cert is total and utter bollocks. HE MUST LEAVE THAT INSTALLATION SAFE, WITHOUT EXCEPTION. He has NOT done that. You cannot make a gas installation live and set it to work unless it's 100% complete, and 100% compliant. Fwiw, I think you should shut it off, disconnect the bottle and get matey boy back to do the chains. ( and no, it's not your job to do it after he facks off with your £100, it's HIS job to do on the day he commissions the gas burning appliance. He should have charged you the extra and done it. Simple. ) Regarding the test point. Is there one, or is there not? The whole point of a dedicated test nipple is that you COMPLETE the installation and can test WITHOUT further interruption to the supply or pipework. E.g. Testing, by removing the gas feed to get an open end to fit his manometer too, means he had to re-make that connection AFTER testing. That's wrong. You should test the full installation with all equipment and controls connected, and you should be able to do so WITHOUT having to reconnect a part / joint as how do you know that's sound? Yes, you can leak spray it, like you would the test nipple on a domestic meter, but that's on a fitting designed and accepted as an appropriate means to do so. This does stink of 5 minute hero TBH, but it's a fact that it shouldn't be on right now without the stability chains.
  17. Daves right. I just saw this and scrolled back through to the pics. Not great. Internal plumbing seems fine, but outside is clearly below standard. As far as regs, the PROPER domestic valve would have the isolation. It would also have the right fitting to go to copper, thus negating the jubilee clip 'connection'. I don't even like to see that when using my BBQ ?. A stability chain around the neck / upper section of the bottle is a no-brainer, and as said, a requirement. Again, not great. Not sure who gets this bullet, but when the pipe comes out of the wall and turns sideways, it needs more than one clip to stop any stress getting to the soldered bend. Should any weight or accidental force be applied to the end of the copper pipe the single clip would form a pivot point and transmit the force to the bend.
  18. What's the big hoo-ha about then? So what if someone boosts their utter dogshit signal so they can actually use their phone at home? I got fed up and rang EE to tell them I was leaving to go to vadaphone, due to not being able to maintain a conversation in my house. They told me they would do me a 'one-off favour' and supply me with a 3G booster that plugs into my wifi, plus I could also turn on wifi calling on my phone ( but not the wife's as she had, at the time, a 2nd hand phone which they wouldn't entertain ) and I was super lucky and privileged because they usually charge £100 for them. I said that the £100 was irrelevant as if they asked me for £100, so I could use my phones at home, they could stick their contracts up their arse. A day later a little gadget arrived, plugged it in and never looked back. 4-5 bars of 3G throughout the house 24/7 now.
  19. Only gripe I had with flexi MDF was getting a fixing in it as screws just blast through it and you get very little purchase. I ended up using my air stapler in the end but it was a curved bath for a display in a bathroom showroom so didn't really have to 'work'. I wouldn't use 'bendy' MDF in a customers house TBH.
  20. Did this to get a BFO extractor in below pozi-joists. 9mm PB wetted both sides 5 mins before fitting. Internal radius done in 4 pieces. This was in the ensuite upstairs. Formed with 4x2" and double boarded with 4mm ply. I soaked the ply ( dripping wet ) for a couple of hours and then rolled the 2 sheets up then ratchet strapped them overnight to dry. Straps came off and they retained about 50% of the curve so happy days. The PB was special order 6mm and that was wetted both sides and left to stand up against the wall, getting further wetted by brush where I wanted the radius, throughout the day. Just wet it and push against it, leave for an hour and repeat. The weight of the board pushes down and helps. Prop the top of the PB with a dead man ( timber T piece ) so it can't fall over . Easier to do than most think. ?
