Wet UFH how to retro fit an electrical heater element?
Nickfromwales replied to readiescards's topic in Underfloor Heating
You shouldn't be running around at all....it's massively overrated Havent you already got 2-port zone valve(s) fitted for the space heating and the uvc ? If so, just fit the Willis heater into the UFH return, at the manifold ( eg before any other parts of the system tee in / out of the UFH primary pipework ) and then tee the return back into the UFH flow via another 2-port ZV. That way the hot water created by the Willis heater travels the shortest distance and doesn't risk any nuisance tripping of the internal overheat stat as it'll never see the high flow temps of the boiler flow. The power to the immersion opens the Willis 2-port ZV and as the heating and hot water should be off at the controls ( by design, amended at the time of the Willis heater being installed so they don't have any conflict ) the UFH manifold pump will simply recirculate through the Willis, through the ZV, and back into the manifold blending valve. The casualty will be the stat in the Willis which will work a bit of overtime but their cheaper than shoplifting so not a real worry. I think the heating would consume what's being generated pretty much as it's being generated, or near as damnit, so a few quid for a Willis would be where I'd start the research. Buffer tank ( perhaps with DHW uplift coil ) would be my get out of jail card if the Willis wasn't conveying enough of the generated PV to space heating. Having DHW uplift in that buffer would give you oodles more DHW when space heating wasn't needed / significant. At this late stage I'd want the retrofit to be as least disruptive as I could make it, hence my first suggestion. I'd even just look at the ground floor and not the whole of house space heating as the ground floor slab should do most of the work anyhoo. ? -
YES!!! You only need one bag FFS -
House with full planning/ thinking of buying
Nickfromwales replied to Dyfed's topic in New House & Self Build Design
+1 -
Bringing a derelict UFH system into service.
Nickfromwales replied to daiking's topic in Underfloor Heating
The ufh would surpass the output of the feature radiators. They'd become ornamental tbh, or you'd likely overheat the space the rads and ufh share. I need to know what type of UFH manifold you bought. If its Wunda, and from back in the day, then it may be one like this, noting the curly capillary wire from a TRV type control knob that is hidden behind the black cable, rather than one like this which is a true thermostatic blending valve with the rotary control knob inbuilt into the TMV. -
A pic of the manifold please. Or a link to the exact one you have so I can look at options vs type etc
Dont shout, but have you considered just beefing the rads up? Connecting up the UFH is going to cost a bit and be quite disruptive. With no dedicated flow and return from the boiler to the UFH manifold location your options for control are also very limited. May be time to cut and run with just the few ££ of UFH pipe as the loss. Thoughts?
I may be up for selling mine. Has been a good gun, usual issues with cold gas but not a fault. Good used condition, and new batteries in the last year iirc or so. PM if interested.
Ok, so you have rads and ufh servicing the same space?
Pic from under the boiler plz. Do you intend to just run rads and UFH the same time always ? You'd be better off doing that TBH with a combi and no buffer. .
Glulams are depressingly light-weight
Nickfromwales replied to ToughButterCup's topic in Roofing, Tiling & Slating
Yup.- 13 replies
Don't you have 2 x 2-port valves already installed and a dedicated pair of flow and return pipes run to the manifold location ?
A one day job MAX.
Do you have the manifold there?
I think @Declan52 has used one that powers back up in the same state
What needs doing to the ufh to get it working?
When things go wrong - Concreting of UFH slab
Nickfromwales commented on oranjeboom's blog entry in Kentish RenoExtension
-Service temperatures: 40°C - 95°C. -Maximum working pressure: 10bar -Five-layer composite pipe. -Combines the benefits of both metal and plastic pipes. Sounds like you've just removed the protective outer layer. You'll need to check with the substance you use too, that its not going to dissolve the outer material of the pipe. @JSHarris territory there -
Pointless testing with warm water tbh. 6 bar is 4 times the working pressure of the UFH system so if that holds then anything the system can chuck at it will hold too. Just make 100% sure the system contains a 3 bar PRV on the primary side and away to go. I honestly think you'll do more harm than good cutting into that pipe. That magic gel doesn't specifically state that it sets solid, which is what you'll need for the pipe repair. The manufacturer may be able to tell you, but won't endorse its use for this scenario. Me personally, if it were my house, id just backfill with a pissy mix of strong concrete or even a self levelling compound first ( up to a depth of 50mm ) and then screed over the repair. Your only looking to stop any expansion of the pipe tbh, so a few tight turns of PVC tape, 3-4 max to ensure the aluminium NEVER gets into contact with the concrete / other and you'll be fine. Oh, and the guy who did your concreting is a penis. -
Should have added that this pipe will tolerate crazy pressure, and yours will only ever see <3 bar max, 1.5 bar nominal which is nowt. -
I wouldn't cut that pipe tbh. Is it Pex-al-pex? The grey shadow you can see is probably the aluminium layer, so the only bit compromised is the outer sheath. Id buy an external cable resin kit and pour a mould around the affected area to fortify where the sheath is damaged. You could even just back fill that whole trench with the resin, which imo would be infinitely better than cutting and jointing the pipe. FYI ive cut, joint and buried ufh couplers and elbows before with zero fail rate. The recommendation to have the joint exposed is just that, a recommendation. . In your instance I would, if your going to cut out the damaged section, just cut enough to be on clean pipe, and use two 90o bends with a straight bit of pipe between them. -
Ok. You know what your doing now ???
Number of times your current soil pipe has needed digging up and / or maintaining ? . Solid floor for me if it were my own build. Why not 250mm of insulation and 100mm of reinforced concrete over the top of that with the UFH pipes in in? A floating floor needs cross ventilation so is inherently flawed IMO. Go 25mm sacrificial EPS over sand blinding, then DPC, then 125mm EPS at the bottom and then 100mm or 120mm PIR atop. Excellenté!
Damn he's good lol. The only thing I'd add is that there may be a conflict of supplies in the internal switch if that's got the existing lighting feed in it, and then you take the outside live into it too. @Onoff / @ProDave, any issue with the two feeds sharing the same switch plate ? If not, then if the existing internal switch is a single or double, it can be bumped up to a double or triple ( 2 gang or 3 gang ) rather than make a new cut out for an additional switch to add the extra gang. Getting from the blue square to the green square can be done by fishing the cable down the cavity. Push some slack back on the cable, into the cavity, to get a drip loop.
Yes, and kinda. Youll need one cable that powers the lights, live neutral and earth. From any junction you then create your switching circuit. Live to the 2-way switch Common terminal and L1 ofcthe switch goes to the lights as the "switched live" feed. From that switch you then need a 3-core and earth as a 'strapper' between that switch and the second switch. I'll add the configuration later but that's what you need to know for cables .
Should have circular knock outs on side / top / bottom etc specifically for a 20mm Swa gland .
Beware going to a light switch to get a feed as normally they won't have a neutral in there . Open it up and double check first. Didn't you say you have an external power supply ? If so use that for the feed, and if you want to be flash, do as @Onoff suggested and run a 3-core and earth ( 4-core 1.5mm2 SWA ) to the nearest internal light switch. Then you can switch it on / off from inside or out. Give the cable tobthe bricky and explain where you need it to / from? If he's half intelligent of course .
