Nickfromwales
    345
  1. I had it happen to me on a basement flat conversion, where I used a dense (kind of thermal) underlay in a room where the floor had no DPM at all (as I found out later) and it was literally soaking wet. I had to use SLC and a liquid (paint on) DPM to resolve that, but you should be seeing no such issues in a new build! Final test would be a core drill to sample a section of your floor to check the layers.
  2. He loves it more than you do lol
  3. 64 million dollar question, without further investigation, sorry! You'd need to lift a section of flooring and get your hooter on to the underlay to see what's creating the niff. If it is the underlay, then you'll need a membrane on the slab, then EPS underlay, then the floor back down.
  4. Yes, cement board can go over it if you want to render 👍. Use a combination of tile adhesive (cementitious) and screw fixings to install both of these two layers.
  5. As above. It should be consuming moisture not emitting it, but the question is of how good a job has been done installing the DPM.
  6. Post a link to the one you can get for £80, as there are different heights and variants. I’ve been fitting Geberit for nearly 25 years, with not so much as a murmur. Fantastic quality and unmatched longevity. Recently installed some Roca ones, very difficult to work on to access internal gubbings 👎
  7. If its just rainwater, with no stench, then just drop the downpipe so its below grade and fit it into a rubber bung in a 110mm bend.
  8. You either need a pump to ‘suck’ through a traditional TMV, or to get an ESBE motorised mixer to run off the heat pump. You never see the TMV after a pump, as it needs the recirculating water to function / reference the temp of the water in the loops. If you're having a TMV for Justin, you'll need to leave the manifold as-is.
  9. It’s the underlay for sure. You need to swap it out for the EPS, and put that over a light membrane. It’s absorbing moisture and sweating.
  10. As above. Contact CVC directly and mention my name and the forum and they'll look after you. 👍
  11. Adding a cold mains accumulator will make a huge difference, for stabilising what you have. Or…. …this. Having small bore pipework between the stopcock and the UVC control group is very impactful on performance, but so many plumbers ignore this; probably some just don't realise it is of such importance. Adding an accumulator can be quick and simple, if you have space for one, and guarantees results. I’ve fitted loads over the last 20+ years and always had great results. Beefing up the control group from 22 - 28mm won’t do much tbh, and I've had lots of UVC’s on 22mm that will do 2 showers simultaneously, where the property has a very good incoming cold mains, so I also doubt that is worth the investment. As always these things are hard to comment on without being able to see the system and survey it properly.
  12. Was it foil with a spongy backing, used to insulate sometimes?
  13. 🤦‍♂️🤔🤦‍♂️🤦‍♂️🤦‍♂️
  14. If you put a 110mm elbow on your roof, I'll come down there and multi-tool it back off. Just "NO!". It'll be fugly as feck.
  15. You could use 2 layers of CF200x50mm thick, either side, bridging both internal and external blocks, which would also close the cavity whilst giving you something solid to fix into. Way overkill but if you want a good standard then that's easy and robust (but not cheap). Other option is to close with masonry, but that would need to be tied / toothed in to the existing blockwork to survive.
  16. I never fit lesser than 92mm. Always great results tbh. The Brink 600 out-performs the Z'r and is less money Just fitted one, last week, and about to fit a 2x 600 install in a weeks time.
  17. How thick (or thin) is this going to be?
  18. Did you put a membrane down under the flooring? Sounds like the floor is sweating.
  19. Room by room is a bit pointless, imo, as the house will just do all it can to equalise the temps throughout. Add MVHR in to the mix and it becomes even less important.
  20. Wishful thinking I’m afraid. Water based ‘gloss’ is very good, apply one coat AM, and another PM, and you’re pretty much done. Are you painting before fitting, or are they all fitted already?
  21. Yes. The levelling is shit, and their management of your expectations equally shit. If I am going to fail to get a floor perfect, for whatever reason(s), I tell the client before hand so they know what to expect; that allows opportunity to explore options, and for a compromise to be agreed. You can't just have depressions that bad on a new floor, and rectifying it is relatively easy; just add spot-filling with compound over primer and then block the floor to remove the steps where the 'waves' of leveller are apparent. Using a dimpled roller is great for general levelling, but if you're rectifying areas then you don't roller it as you don't want the leveller to migrate from the area you want to improve. Talk to them in the morning and completely lay your cards on the table, and ask these questions and get the answers directly, as all you're doing here is venting and not resolving, as we're not laying your floor.
  22. I paid a guy to come and lag it all for me, and he worked mostly in light commercial etc so it’s default there. Not really necessary but the phenolic stuff comes foiled as standard. Not much need in a domestic (but satisfies OCD), and the grey EPS stuff is no better or worse than the neoprene, same values etc, so if you’re inside the heated and airtight envelope then the insulation is mostly relevant if cooling.
  23. Listen to the advice of the new contractors as they will then be liable for longevity etc. If you ignore them then you’d be blamed for any failures. Short cuts take 3 times longer and are always 3 times the cost. Remove the U/S sub base and get it all replaced with type 1, and install ACO drains to manage storm water.
