Nickfromwales
    346
  1. I’ll post some links when I get to narrow down a supplier with stock!! Photonic Universe is one contender. Prices are just a google search tbh. Just as the cells are at the end of their life because of the excessive cycling to get TO those figures……..,
  2. Words of wisdom.
  3. If you’ve put screws in, then prob not much coverage left to put scrim and skim atop the screw heads. With screws into ply, I doubt you need to go any further 👌
  4. Factor in the date the batteries will expire That throws it further off again. Im just about to pull the trigger on an 11,000w Iconica hybrid inverter ( 2x5500w strings ) and will then bolt on 9.6kw of AGM batteries and run for a year, with a view to adding probably the same again in battery size.
  5. Sounds like the air hadn’t been bled out of the upstairs heating properly? Turn all the rads off except the one nearest the heat source, bleed that rad and top up the pressure, then see if that rad gets warm / hot.
  6. £400 a day for spraying and washing their hands of all the ACTUAL work would have been a piss-take tbh. Good for you getting your hands dirty
  7. Yup, as long as it has a copper overflow and copper ( metal ) connected pipework. This bit is confusing me. Gravity primary's normally convey heated primary water to a coil in a DHW cylinder, been that way since I was knee-high to a grasshopper. How many tanks are in the attic? Are these both fibreglass? One for the CH circuit of the Rayburn, and a second exclusively servicing DHW? How many connections ( and where ) on the copper DHW cylinder atm? Need to understand this a bit better, but tbh mostly out of curiosity if things are to be changed around anyhoo. A 'circuit' will be a victim of circumstance, so no generic yes/no there If a circuit has UFH and stainless / copper parts the corrosion issue is miniscule, if rads are present the issue is increased, albeit still manageable with inhibitors etc. If folk are bathing in DHW from a primatic cylinder you cannot treat the primary water so must upscale on design / diligence, but if your DHW and the CH primary water re two completely separate bodies of water ( suggested by the 'plural' reference to the header tanks ) then there are options for chemically treating the water to better manage condition. A magnetic filter would be an obvious friend to introduce here, but it would need cleaning out regularly for the first year. You don't really want to introduce a sealed and pressurised setup here, IMHO, as the folks will have to monitor / top up / make sure they don't over-pressurise etc etc, aka ball-ache. F&E = simple life / minimum routine maintenance. If the F&E tanks remain in the attic ( which they very likely will have to ) then you're fine to stay on gravity, so one less problem. Upstairs heating stays on that too so, so happy days. So; Bathing still to be off electric showers? Ergo stored DHW will be for washing hands / dishes etc only? Seems madness to me, especially if 'religious' Rayburn usage is on the cards for the foreseeable? Remember that occupancy by anyone deemed infirm requires thermostatic control for anti-scald, so regular electric showers 'should' be changed, for both safety and comfort, ( if being retained ). What will happen the the second heat exchanger connections? The ones doing DHW via the steel tank? Te Rayburn is a 4-pipe setup atm yes?
  8. +1 to Torbecks, plus they fill silently.
  9. That has markers where you cut it shorter Just have it so it slightly stands off the cistern wall, but it’s there to offer opposing force when the float rises so is a functional part.
  10. Things are further relaxed in a “single compartment dwelling” eg where there is an open plan hall / stairs / landing as a fire upstairs is assumed to be already downstairs and vice-versa. 2 storey, no need. Only on garage as already said.
  11. OK. Firstly, only use copper for the primary pipework whatever you do!! No other product is rated for boiling water / steam. That's why the gravity tanks should be galvanised steel, as plastic tanks melt and shower occupants with scalding water. People have been killed by this happening where they got scalded to death in their beds when the tanks just folded in and dropped on them. It's a very serious issue. These two bodies of water should not be meeting? The heated primary water should be going through a coil? Is this a failed / failing primatic hot water cylinder? Buy lots in the summer, as the cost of this system conversion will not be cheap!! Simple to achieve tbh, but the Rayburn will need to a) keep the galv header tank, or b) be garnished with a retrofitted cold mains fed quench valve ( which cools the solid fuel device with mains water ) but that may not be suitable / compliant for an existing device. Also being mindful that your cold mains is power-dependant, so adds another degree of complexity!! I'd just keep the header tanks tbh, renewing them to be sure of longevity / suitability / reliability etc. The ground floor cylinder could then just be a gravity thermal store, stainless steel to combat corrosion issues as best as possible, and a very simple device where all bodies of primary water are shared, eg your hybrid setup would simply converge there. Where is the current cylinder? In this 630mm wide location or elsewhere? If there is a second cylinder location available, I would go; Rayburn > TS TS > Space heating Oil > Space heating ( ignoring TS when Rayburn is not in operation ) future-proofs against old age / sick days etc. Oil > DHW UVC ( when Rayburn not in operation ) "" ditto TS > DHW UVC ( when Rayburn is in operation ) doubles up thermal storage capacity to maximise 'stored' heat, eg DHW still ( residually / theoretically ) available early morning before lighting Rayburn This house will never run off a heat pump. Flush that idea from here please!?! Doable Nope, not for heating anyways. Prob need the keep a CWS from the borehole for reliability. It's an attic, just leave it alone / utilise it to your advantage ( benefit ) imo. Not for the primary heating from solid fuel, copper best for the backbone here afaic. Nope. That means added maintenance for the old-folk, topping up, checking pressures, etc. Will also promote introducing leaks where weak spots currently reside. Poops on my idea for a dual-cylinder arrangement. If this is for the parents to grow old with, consider the en-suite / bedroom arrangement for downstairs maybe? Electric showers are shart on a good day, also not thermostatic unless you upgrade? Mixer showers off the TS or UVC would be far superior, plus pointless having PV diversion if it's going into a dead end whilst grid electricity is chewed up in parallel?? OK. Lets start there
  12. They're graveyard quiet when built, and the roof ( 400mm with MBC ) is even more so. PIR based frames tend to be quite acoustically transparent, brick and block so / so, cellulose wins hands down. Seriously unimpressed with PIR ( SIPS esque ) roof designs, way too noisy for my liking.
  13. Do you mean the MVHR will service the rooms in the roof space, eg you will have habitable spaces up there? Infrequently visited spaces will all need full building regs compliance, eg the guarantee of airflow to manage CO2ppm / humidity etc, which is not a "choice". Not all spaces in an airtight house need to be serviced directly by MVHR duct placement, as a house with MVHR running 24/7/365 will already be inherently 'dry'. What is your target airtightness score, eg to know MVHR ( certainly the heat recovery element ) will be of any useful functionality. If the design airflow raters are less than the residual natural infiltration rates then MVHR becomes a questionable choice. You should be aiming at a score of <1ACH if wanting to maximise the return on the investment.
  14. Do you really want to have to heat a tank that size to over 60oC all summer just to get DHW? Any cooler would need a monster of a heat exchanger for decent DHW flow rates / temps?
  15. Mermaid specified Everbuild Stixall Crystal Clear ( which is basically CT1 in a different tube from the smell of it ) for a 4x bathroom install I did where the clients went with Mermaid panels ( same 'glue' specified for both thin PVC and the Formica laminated wood alike ). Same product used to bed the bottom of the panels into / onto the shower / bath / floors etc, and PLEASE do not use the ghastly base trim they recommend, as it's a huge trap for water / grot etc and is completely unnecessary AFAIC. Also a horrible detail where it needs to stop short eg at the end of a fixed bath or shower tray.
  16. "you can now manage without either of them"
  17. More than one near miss for sure lol
  18. That's a good job tbh, so defo worth the screws in that instance. Small head screws like No.3.5's leave more coverage for the skim over the screw head so be mindful not to use pan-head etc that's all as you dont want more skim on than the depth of the lip of the fitting ( which is what you're supposed to skim to ).
  19. Don't make me ring your wife........
  20. Whether SA or UVC, you defo do NOT want to be taking space heating from the point you show it entering "valve". Who's specified this? Also, having a SA means running at very high temps to get a speedy reheat of the DHW.......which PCM is the current flavour? 58?
  21. Crack The FCUK On Simples
  22. Sounds perfectly reasonable Just pay the man, he's got kids to feed !!! PS, as a BH Buddy favour, i'll come over and do the CAT6 for £9k, that's a saving of a thousand pounds Seriously....how do these people get any work? That's crazy money for this build....
