Temp
Everything posted by Temp
Zinsser on the ceiling, especially over shower.
I had similar problem. They are up 9% last I looked today. Bad news is everything else still trashed. Been a very expensive week.
Our builders comprised the builder himself, and two others. One of these I guess you could call site foreman and the other primarily worked wood but both could do just about anything, for example they dug the foundations and tiled the roof together. Other trades were contracted as required (eg plastering, electrics). The builder would normally be on site first and last thing. eg to open and lock up. In the evening he did a bit of a walk around putting stuff away and discussing what had been done and what was planned for the next day. One of the most important jobs was ensuring that they had everything they needed for the next days work. If they needed anything then either the builder or the foreman would go to the builders merchants on the way home or on the way in. Basically he went to great lengths to ensure nobody had an excuse not to work or go off site during the day. Reason I mention all this is if you want to keep updated on your project figure out how yours works and perhaps arrange to be there for the walk around, help him secure stuff etc.
Go visit the site they are currently working on. It's common for builders to line up the next job way early. If you visit you can see if they stand any chance of coming to you soon.
Some oil company shares are down 50%. One is paying a 25% dividend already declared!
Another CIL question
Temp replied to Torchia's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Which form are you referring to? The application for OPP? I don't think that's an issue but would not hurt to get it confirmed from the council. I believe you would... 1) Submit an application for Full Planning Permission 2) wait for it to be granted. 3) Follow the procedure detailed near the top of form 7 to the letter to claim the exemption. https://www.planningportal.co.uk/info/200136/policy_and_legislation/70/community_infrastructure_levy/5 That usually means forms 2, 7(part 1), 6, 7(part 2). Keep copies of all forms and letters. Send everything recorded delivery. Ask for reciepts ! One form lost in the post and you can accidentally loose the exemption. Get any pre-commencement planning conditions formally discharged in writing before submitting form 6. Do not start any work on site before the commencement date on form 6 or before they acknowledge reciept of form 6 in writing. Remember you must submit 7(part 2) and live in the house for 3 years after completion. There is also a time limit for the VAT reclaim. You might also consider life insurance to cover the CIL. I'm not kidding. I recall someone posted awhile back saying their husband had died during construction and the council said if the wife didn't live in the house she would loose the exemption and be liable for the cil. I can't remember how that turned out but council's appear to be looking for any excuse to cancel your exemption. One person lost it by sending the commencement notification by email.- 1 reply
After inspecting cause perhaps a job for Zinsser primer sealer stain killer?
As I understand it MR16 and GU10 are only standards for the electrical socket (eg the bit the light bulb pins fit into). Those can be fixed or floating in the light fitting. The dimensions of the bulb itself isn't part of the MR16 or GU10 standards. Halogen bulbs are mostly a standard size but CFL and LED can still vary a mm or two. I've come home with GU10 LED bulbs only to discover they don't fit my down lights. https://www.wholesaleledlights.co.uk/blog/2012/04/does-the-size-of-my-gu10-led-bulbs-matter/
Suggestion: panel-heater by front door for comfort
Temp replied to Dreadnaught's topic in Other Heating Systems
If the scanning actuators fail does it burn a hole through you?- 8 replies
- heating
- front door
I think this pipework should be simpler, but I can't see how yet.
Temp replied to dnb's topic in Waste & Sewerage
All I would do is move the final IC to the left and use the 46 degree connections on it to eliminate the 45 degree bends you have in the pipe runs. I might also put IC where you have 90 degree bends on the final runs. -
A creditable attempt to pour all my money into a hole in the ground...
Temp commented on dnb's blog entry in Building in a woodland on the Isle of Wight
Apparently according to the BBC today February's weather was all down to a "north Atlantic oscillation" channelling storms and cold fronts in our direction. They said it was set to continue for awhile. I tried to cut our paddock today but ran over a dog toy some walker had abandoned and caused £60 worth of broken belts and shear pins on the mower. Last time that belt broke it took most of a day to fix as well. -
Hopefully I'll never need it. I'm on the mailing list of people that have commented on local plans in the past so they notify me of all policies out for public consultation. They invariably ignore all comments but it forces them to at least write a reply. Today I noticed it's not a requirement for a householder application so not needed for extensions.
If the solicitor is doing a good job they will have contacted the utility companies to get maps and find out if any cables or pipes run across the property. They can take 4-8 weeks to respond. Perhaps ask for a copy of the maps as they could be useful later? or perhaps don't ask if you think she hasn't sent for them yet! PS: We once had someone knock on the door looking to buy our house which was on the market. Four weeks later we completed and moved out.
The main issue with GU10 in my experience is that when one or two fail you discover that make and model are no longer made or no longer identical. The other issue is that I much prefer wide beam angle bulbs >90 degrees and most companies seem to be moving to narrower angles like 36 degrees. In my opinion this makes them too spotty and not uniform enough. If that trend continues flat panels will be a better bet for many applications if not already.
I'm thinking handles for shopping baskets and trolleys are going to be a risk for virus spread. Ditto petrol pump handles. Not yet but if this thing really gets going in the UK.
- 16 replies
- corona virus
- health and safety
Crazy thought but would a crane make sense? Eg to lift skips over neighbors property?
I agree with Russell. It would take too long picking up dirt with the shovel. I reckon much quicker to get the digger to load it/them and you could probably fill them better as well. Is there no way to make it wider even temporarily? The thing I hired was more like a Thwaites 1 ton dumper... http://www.thwaitesdumpers.co.uk/PDFLibrary/Sales lit UK/201 - 1 Tonne Hi-Tip - UK.pdf
Our council is consulting on new Planning Application validation check lists. I see that for all Full Planning Applications.. "where there is a potential adverse impact upon the current levels of sunlight/daylight of adjoining properties and/or of future occupiers of the proposed development" ...you must provide a "Sunlight Indicator Test". They provide a link to this page at the BRE and a £55 book... https://www.bregroup.com/services/testing/indoor-environment-testing/natural-light/ I think a significant percentage of new houses/self builds have some potential to impact "current levels of sunlight/daylight of adjoining properties". In the past Planning Officers would assess an application and request more information, reports or studies. Now it seems you have to do one for even minor adverse impacts that do not come close to affecting someones right to light. Searching the BRE website for "Sunlight Indicator Test" finds no matches. Google isn't much more helpful. Anyone know if this is a simple exercise that you can complete yourself or a massive bill from a consultant?
Certainly think he has double counted labour. When we built our house we had a similar crew, site foreman and two others. Those two others wern't the same two every day but we rarely had more than three people on site on average. For example I bet those two labourers will be the same two that take up the patio. Likewise when excavating the site foreman acted as banksman/lookout. I suspect this is how he hides his profit. He's given what looks like a detailed breakdown but where is his profit :-) Im sure he's not aiming to break even. Some things he's charging hire for I suspect he owns. How many builders don't have a site van and WC? Ours had his own telehandler. Ok so you don't get them free, I would expect him to charge for wear and tear rather than full rental value? £550 to install two padstones? Only 100mm PIR in the roof? Get other quotes. Don't show them this one.
92.5 degree bend : the half? Really? Honestly?
Temp replied to ToughButterCup's topic in Waste & Sewerage
I couldn't immediately think where you would do that? I mean if you have a pipe run that descends vertically, then goes horizontally (with a fall), then descends vertically again you need two 92.5 degree bends not one of each. Perhaps if you were going around three sides of a building? -
Can you go bigger? Those may carry 1000kg weight but the volume capacity is typically 250-400L depending on model and if the soil is level or heaped. If you really have 100m^3 to move that would be 200-400 trips.
Using a touring caravan as a site brew room and more
Temp replied to Olly P's topic in General Self Build & DIY Discussion
Our builder provided a shed like building as a site van. Just a table in it and a porta loo round the back. No chairs, no heating etc When I commented that it wasn't very luxurious he said it was deliberate, didn't want people getting too comfortable in it or no work would get done when he's off site. -
Welcome to the forum.
Stacks don't have to be 110mm.... The approved document has a table that specifies the Stack Diameter required for different Flow rates. The minimum size in the table is 50mm as I recall. The top ventilated part has even less flow (none!) so presumably can be 50mm.
And I recommend buying enough to make up a small sample panel first before buying loads.
