Temp
Everything posted by Temp
This look interesting. Its a manifold allowing four masks on one ventilator. Original paper published in 2015 in anticipation of a pandemic. No idea if it makes medical sense. Can't find the .stl anywhere. https://file.scirp.org/Html/2-1750025_49209.htm#ref10
Thanks, the interesting stuff is in the comments at the bottom. Problems such as copyright, patents and the need for medical grade materials get mentioned. Several 3D printer farms have already offered to help. Link looks interesting... https://github.com/brentjackson/OpenRespirator/wiki
What’s the best and simplest security system
Temp replied to recoveringbuilder's topic in Networks, AV, Security & Automation
If you decide to install a fake alarm I suggest you don't buy a fake bell box as pretty sure crooks recognise the fakes. I'd buy a real bell box and just not bother to connect it up. -
I believe the RIng can be used without a subscription but you don't get recording. You only get live video. At least that's what I've heard. There are alternatives.. https://eternallyconfuzzled.com/video-doorbell-without-subscription -
I wondered if those of us with 3D printers could print ventilator parts? All I can find is a news story about a company in Italy that had printed some part for a hospital.
Somehow I missed the original post. Normally when you perform an operation on something you have to select the bodies to perform it on. Doesn't it let you select both bodies?
Isolation - what will you do?
Temp replied to Ferdinand's topic in General Self Build & DIY Discussion
Well you never know.. https://cornishstuff.com/2019/09/17/lithium/ "This week MetAmpere, the first company to drill lithium exploration holes in the UK, described their test results from Cornwall as “staggeringly good”. -
40mm too short: the story of my life - now what?
Temp replied to ToughButterCup's topic in Waste & Sewerage
Obviously you couldn't just bend the black bit upwards to raise it 45mm but would a 15 degree bend get nearer or is it too much? https://www.screwfix.com/p/floplast-single-socket-bend-15-110mm/69177?tc=IB6&ds_kid=92700020972856688&gclsrc=aw.ds&ds_rl=1241687&ds_rl=1245250&ds_rl=1249404&gclid=Cj0KCQjw6sHzBRCbARIsAF8FMpWokdAwAdUbePMS7aWxbcygv6Ii3EhMTpDNsX8-T5Mz9CcMwqs7G5IaAu1lEALw_wcB -
What accidents have you had while DIY'ing?!!
Temp replied to mike2016's topic in General Self Build & DIY Discussion
I've got mostly minor DIY scars. Worst was when I fell off a ladder. I landed on a wood floor and was lying there unscathed, happy I had missed my tool box and thinking I'd had a lucky escape... when the ladder fell on me. -
+1 We have a mixture but in some rooms we have 80mm PIR insulation and about 60mm screed with UFH. Wish we had more insulation. Our favourite rooms have 21mm engineered oak flooring on battens with PIR between and no screed. The top layer of PIR has foiled covered grooves for the pipes that spread the heat. A system like that would allow a greater depth of insulation.
Google found.. https://cableductuk.com/700series.html?gclid=Cj0KCQjwpLfzBRCRARIsAHuj6qUTH6BdbeW5nGHVzZkM3BUnj4kD9oj_oCCIZok8hdaCzextaqjpfcMaAvFBEALw_wcB
Battens worked for me but I wasn't putting the tray in a recess. I think straps might be the way to go as @Onoff suggested. Would an engine hoist work?
+1 Howmany air bricks are there? If you have several along that side of the house I doubt it would cause any problems if that one was blocked, perhaps by filling the "trench" with large decorative stones or a planter box.
Soil pipe assembly: bottom up, or top down?
That's what slip couplers are for :-) -
Exterior Beam and Block - OK to use pre-concreting
Temp replied to Adam2's topic in General Construction Issues
If you can't concrete it now how about a large thick tarp? Put some blocks on it to stop it blowing away. -
Well this was a long cup of coffee... It's common to try and exclude consequential loss but my understanding is it may only be enforceable with business customers unless the contract was specifically negotiated with you rather then being standard T&Cs. I believe you, being a "consumer customer", also have statutory rights under the Consumer Rights Act 2015 in that excluding consequential loss probably amounts to an unfair contract. https://www.citizensadvice.org.uk/consumer/somethings-gone-wrong-with-a-purchase/claim-compensation-if-an-item-or-product-causes-damage/ https://www.consumercouncil.org.uk/sites/default/files/2019-09/A_Guide_To_Consumer_Law_for_Businesses.PDF https://www.squirepattonboggs.com/~/media/files/insights/publications/2015/10/the-consumer-rights-act-how-does-it-impact-on-brand-owners/cra-article-for-consumer-brands-alert.pdf https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/450440/Unfair_Terms_Main_Guidance.pdf Reading on it appears they believe the exclusions of unforeseeable consequences would be ok but the exclusion of foreseeable ones would be unfair. If that gets raised I'd argue that the consequences of a leak were reasonably foreseeable by both parties! So looks like a pretty certain that a consequential loss exclusion is unfair when the buyer is a consumer. I'd get quotes for the repairs and send them a letter asking them to pay up before you do any work. Point out that clauses in contracts with consumers which use terms like "consequential loss" are considered unfair. I believe you have to give them the opportunity to fix it before you can get it done yourself by a third party and claim compensation. Give them a two week deadline to respond? You could probably also claim for your time locating the source of the leak but I think I would just point out that that by taking action to promptly identify the source of the leak, and removing sodden insulation yourself, you have minimised the possible damage and the cost to the rooflight company. I've also been reading something about the Alternative Dispute Resolution (ADR) Directive which provides an alternative to court action. I think TrustMark is an ADR provider. Perhaps find out if the rooflight co is a member and involve them?
- 48 comments
- 6
- roof
- rooflights
(and 2 more)
Bottom up. Ideally start from the sewer in the road (at least on paper so you know how high the rest bend at the bottom of the stack must be to get the correct falls all the way to the sewer). -
Loft conversion internal door requirements / spec
Temp replied to DC5's topic in Building Regulations
Oh bother, I didn't spot that bit. -
For the drainage stuff you may need to lift manholes in the road to find out how deep the sewers are. Then make a drawing working back to your house accounting for the fall in each length of pipe to calculate the invert level for each inspection chamber. For example if the sewer connection was 2m below reference level and the nearest IC on your plot was 40m away the bottom of the IC would be calculated as.. 1:80 fall over 40m = 0.5m so the IC would be set at 2m - 0.5m = 1.5m below reference (Thats not necessarily 1.5m below ground because the ground may slope). Repeat for each IC untill you get to the bottom of the stack.
I missed it but thought on the news it said businesses could defer rates for 3 months or something like that.
We have that set up. A Brittania dual fuel range with gas hob on a pair of 47kg cylinders, family of four. Works very well. One cylinder lasts 18 months at least. I was thinking of using smaller cylinders but someone here pointed out that they may not be able to deliver the gas flow rate required when multiple rings in use. Our cylinders are located about 40m (yes forty meters) from the cooker in a cabinet behind the garage. We used several lengths of plastic coated copper pipe designed for the purpose. I think the connections were gas compression fittings, pressure tested and then wrapped in Denso tape before being buried in the ground. Indoors we laid the pipe in the floor insulation (we have beam and block with insulation and UFH in screed in kitchen). We used one length of pipe indoors so no joints under floor screed. We only used a duct pipe through the foundations. To pressure test you turn off the valve at cooker end. Fit a regulator and cylinder in the cabinet. The regulator has a gauge on it. Open the gas valve on the cylinder to pressurise the pipe run then close it again. Pressure gauge should remain stable for at least 24 hours. Metal cabinets for gas cylinders are expensive for what they are. Ours is designed for 47kg cylinders but it's only just tall enough and has a fixed roof. It's a pain to wrestle the cylinder into place through the door and connect it up. See if you can find one with a hinged roof as well or at least plenty tall so you can get your arms in there. I've recently changed to much longer hoses (4ft) between regulator and cylinder so I can connect it up outside the cabinet then shove it into place. 47kg cylinders are heavy even on a sack trolley. Avoid steps between car parking and cabinet if possible. You can get them delivered but that might be more expensive. I've always collected mine but you need something to stop the cylinder rolling around and protection for the lip of the boot when dragging it in and out. Two man job really.
Retaining Wall building in wet conditions
Temp replied to DiyGuy's topic in Landscaping, Decking & Patios
+1 Even a 60mm diameter pipe would be better than nothing. When you have the second course built and its set up good, wait till he's gone to work, drop in the pipe and cover it up with gravel and soil. -
Google found underwater mortar but no idea how readily available it is... https://rotafix.co.uk/products/masonry-repairs/rotafix-underwater-applied-mortar/ Rotafix Under Water Mortar powder is a blend of special cement powders, high quality graded sand, and a unique combination of polymers and admixtures. The powder, when mixed with water, produces a mortar which is wash-out resistant and waterproof. The ready to use mortar powders are packaged in 25kg moisture proof durable bags and have a shelf life of 2 years. https://www.epoxyproducts.co.uk/Epoxy%20Mortar%20Underwater%20482015.pdf EPOXY MORTAR—UNDERWATER Is for use in exceptionally wet conditions and for underwater applications. For fixing slip bricks and reinstating structures exposed to heavy battering from sea, such as sea walls and jetties. For repairing submerged concrete. I'd do my best to eliminate the water and leave gaps in that first course so any can drain to your side rather than build up. -
I don't know about Scotland but in England a loft conversion can turn a two storey house into a three storey house and the rules for fire doors and fire resistance of walls is different for three storey houses. Sometimes the stair well on the ground floor has to be upgraded by doubling up plasterboard. Check with the BCO but if you only need FD30 doors then you can get some pretty nice looking cottage oak doors these days.. https://www.doorsandfloors.co.uk/woodland-oak-ledge-and-brace-fd30-fire-doors.html https://greentreedoors.co.uk/product/oak-mexicana-fd30-internal-fire-door/
