Temp
    43
Everything posted by Temp
  1. Apparently lumber is falling again.. https://fortune.com/2021/06/16/lumber-prices-falling-2021-chart-update-price-of-lumber-going-down-wood-costs/ 20% down from peak.
  2. Google found some info from the NHBC written in 2011.. http://nhbccampaigns.co.uk/landingpages/techzone/previous_versions/2010/Part5/section1/sitework.htm Main points..
  3. Soil is fine on the outside. In the inside it depends how you are doing the floor. If its going to be a concrete slab then hardcore. If its a suspended floor then soil is OK. Some of us on sloping sites or clay soil have dropped perforated pipe into the space and covered with gravel to make a French drain.
  4. Welcome. I think sprinklers are mandatory in all new houses in Wales so they must be pretty sorted/mainstream now.
  5. I expect you meant under the insulation. The vapour barrier should be on the warm side of insulation. As I recall the 50mm gap is to allow roofing membrane to drape 25mm between rafters and still leave a 25mm ventilated gap (eg when there are no sarking boards to support the membrane). So my guess is 25mm would be ok if the BCO allows it. The main problem with ventilation is usually at the eaves and ridge. Builders tend to forget and just mortar on ridge tiles. Later when there is a problem you are faced with fitting tile vents one per rafter bay as the rafters stop lateral air flow. Typical suggested ventilation schemes for different roofs are something like this. Yours would be the one top right. Note that the dimensions are per meter. eg at the eaves (marked B) you need the equivalent of a 25mm wide slot the whole length of the eaves. If using round vents you need enough to provide 25,000 square mm of free area per meter. If you were to fit this type of common round soffit vent .. https://mytradeproducts.com/products/manthorpe-circular-soffit-5-colours-g700?variant=37765056233625&currency=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=CjwKCAjwq7aGBhADEiwA6uGZp6QEf45bAAjO8jSqSrNeEZ7XuVKpoEqsHIx7wO44fffOpy19cZL1BRoCwkgQAvD_BwE ..it has only 2150mm² free area per vent. Meaning you need ELEVEN per meter !! You probably cant fit that many in a single line as the rafters get in the way. You need two staggered rows. That's a lot of vent holes to drill. Not so bad at the ridge where you need 5mm gap or 5000 mm² per meter each side.
  6. A single stud should have no problem carrying the weight. The only issue I see is that if someone knocks the rad sideways the bracket might dig into the plasterboard unless its a decent area. I believe wires are meant to be at least 50mm deep in the wall so I'd use screws that penetrate the wall around 40mm. So 40mm plus the thickness of the bracket. See what others say.
  7. Oil boilers aren't a great match for UFH unless you can add a buffer tank of some sort. Oil boilers don't modulate their burner, instead they turn the burner on and off to maintain the required flow temperature. This is a bit like driving a car in stop start traffic. So you might find the burner cycles on and off a lot if only one UFH loop is calling for heat. We fitted a thermal store which acts as a buffer. The store supplies the hot water for both the UFH and DHW. When the temperature in the store falls the boiler fires up and in our case runs flat out until the store is back up to temperature. The down side is that a thermal store can leak a lot of heat if not well insulated and some leave a bit to be desired in that respect. This was our first oil boiler so not sure how big aa problem the cycling issue is.
  8. Could just concrete it but might have to remove some of the hardcore first. India stone if thats acceptable.
  9. Perhaps look at oak veneered mdf? I mean for internal use.
  10. Perhaps look at Saxon TCT blades. Not the best but cheap enough that you can buy more than one with different number of teeth. I'd look for something around 40 teeth. The overall diameter and the hole diameter need to match your saw. Personally I'd use a table saw for this rather than a hand held circular saw. Its difficult or rather time consuming clamping narrow boards so they can be cut down the middle with a hand held. Not enough (any) board sticks out of the side so the saw can't go past the clamp. If you have a lot to do perhaps look on YouTube for ways to turn a hand held saw into a table saw?
  11. Difference between a warm and cold roof construction (not to be confused with a warm/cold loft).... * Cold roof - the insulation is between and under the rafters. This means there are structural elements on the cold side of the insulation (eg the top of the rafters). * Warm roof - the insulation is above the rafters. This means the structural elements are on the warm side of the insulation. The vast majority of houses built now and in the past are of the cold roof type. The risk with a cold roof is that water vapour created by people in the house can escape through the insulation and condense on the cold part of the rafters or other structural elements. There are two main ways of preventing this, both are aided by a vapour barrier on the warm side of the insulation.. * Vapour permeable: If sarking boards and the roof membrane are vapour permeable then you only need to ventilate the void between the tiles and the roof membrane. * Vapour impermeable: if any sarking boards or roof membrane are not vapour permeable then you need a 50mm ventilated void below the impermeable layer. So the question you need to answer is : Are your sarking boards and roof membrane sufficiently vapour permeable that you can avoid needing a 50mm ventilated void below? My understanding is that narrow sarking boards with 3-5m gaps are considered permeable but large sheets of OSB with no gaps might not be. Discuss with your BCO or Architect.
  12. This is what they are doing.. https://www.burges-salmon.com/news-and-insight/legal-updates/planning-and-compulsory-purchase/update-on-agricultural-occupancy-conditions/ MARKET TESTING It is possible to remove an agricultural occupancy condition though the applicant will first need to demonstrate certain things. This includes adducing evidence that the property has been marketed for sale or rent, at a substantially reduced price, to agricultural workers in the area for a significant period of time. In April 2019 the Planning Inspectorate emphasised that evidence of a robust marketing exercise is essential when applying to remove a condition. This related to an application to remove an agricultural occupancy condition at Sutton Springs Trout Fishery Grounds. The Inspector found that there had been sufficient marketing of the property as it had been consistently publicised online, included in various publications and promoted in mail campaigns. The agricultural occupancy condition was therefore successfully removed. This decision is illustrative of what level of marketing is acceptable and adds to the tips provided by the Upper Tribunal in the case of Rasbridge, Re Cefn Betingau Farm in 2012. The Tribunal found the applicants' market testing exercise was not sufficiently rigorous and suggested that the applicant should have: offered to rent the property in order to establish if there was rental value to the land; advertised the property in the specialist farming press; and made adjustments to reflect general market movements.
  13. Now you remind me we did have a problem with the flush pipe on our Geberit cistern. The rubber seal degraded and the whole joint became loose and leaked but I think they have changed the design now..
  14. Not seen that wording before. I suspect it means they are waiting for you to resolve issues they have raised? Or it could mean they believe the issues have been resolved?
  15. Would be interesting to see what the small print on the warranty says. In my limited experience ... Geberit Fames will easily last 10 years. I've had flush valves fail after 4 years. The chrome plating on the flush plate buttons can also wear through in 4 years.
  16. I wonder if its worth trying solvents like acetone. Eg clear solvents that evaporate totally. Perhaps test on scrap wood first.
  17. +1 It won't move with the ply on it. The alternative would be to cut wedges to match and fix to the edges ?
  18. Not seen one but only £6.. https://www.haspod.com/documents/method-statements/building-demolition-template?gclid=CjwKCAjwn6GGBhADEiwAruUcKs-oVmVP-XzXB9maGAdc56O6ThCLnpfS8HJkM1g9SjrpGKoNwuryhxoCwJ8QAvD_BwE
  19. I very much doubt having a thinner screed will make any difference to the UFH. What pipe spacing did you go for? On a renovation Id recommend a close spacing as they can need more heat than a new build.
  20. Thinnest I've ever seen recommended was 40mm but that was with an UFH system that meant the 40mm was all above the pipes. Screed can crack where two rooms meet at a doorway. This is due to the screed in each room shrinking towards its own centre eg pulling apart at the door way. So that crack might not be due to the thickness but 30mm isn't enough. What's going on top? Tiles - risky. Carpet - who knows. Engineered wood flooring - probably ok if thick enough (eg >18mm).
  21. Restrictive covenants and overage clauses are normally only problem if the lender thinks they affect the value of the property to the point where the LTV is unacceptable or possibly the wording means they see the potential for legal problems. In which case I think you should be concerned about this for the same reasons. Executors have a duty to look after the interests of beneficiaries so if the wording is affecting the value of the assets negatively they have the powers to change things.
  22. He's only shown one SVP in each room but you should consider if that's the best approach. Its' not a bad starting point if you dont yet know the room layout. These days floor insulation and screed is quite thick but you might want to check there is enough depth to accommodate a shower tray trap and the fall to the stack without having to raise the shower tray up on a plinth. Perhaps you dont mind a plinth or perhaps you want wet rooms? Sometimes you end up needing the connection into the stack very low down or even in the slab. You wouldnt be the first person to have to chip out concrete from around the stack to get the connection low enough for the shower. Consider making some room layouts to work out how far the shower trap would be from the stack. Then make cross sectional drawings showing the shower tray/trap, pipe fall, and branch connection into the stack to work out if its going to be an issue. An SVC in the corner and a WC pan with a horizontal P-trap outlet is easier overall than using a WC pan with a vertical S-trap outlet. With the former everything is above slab but you have pipes to hide. With the latter you need a connection coming up vertically through the floor but this needs to be just the right distance from the wall and makes layout changes later. There are many ways to skin that cat. Some people have no problem with boxing, some hide the pipe in cabinets, some build false walls, some hide the cistern as well as the pipe. Some use wall mounted pans. What @Nickfromwalessaid. The middle ones can be short stub stacks with AAV. Only other comments i have is that he shows the red drain running under the house. Is there any reason why it can't be run along outside the footprint ?
  23. I think i would speak to the vendor and try and persuade them not to impose the overage or at least change the wording to make it more standard. They appear to be devaluing the property by making it hard to get a mortgage. A paddock came with our plot. Its got a very simple/standard overage clause on the paddock part only. Wasn't raised as a problem by anyone.
  24. "Planning Consultants" in Yellow pages worked for us 13 years ago. Just ring up a few and ask if they can handle a (possibly) urgent CLUED.
