Temp
Everything posted by Temp
Combi, Storage Combi or electric shower?
Temp replied to Rachieble's topic in Boilers & Hot Water Tanks
OK some figures... 8kW is about 35A 10kW is about 45A So 4 of those would be way over 100A single phase that many houses are limited to. In fact I think many houses only have an 80A fuse in their nominally 100A supply. I'd like to see the figures for a house with ASHP, Electric Shower and Car charger. Personally I like a better shower/ better flow rate than an 8kW can produce. -
RED (Renewable energy devices) ASHP Brand?
Temp replied to ashthekid's topic in Air Source Heat Pumps (ASHP)
Not me but found Facebook page with links to a few installs but I guess they could be sponsored.. https://www.facebook.com/ultimateheatpump/ Main thing that would concern me with any supplier is the availability of someone to fix it if/when it needs repairs or just tuning up. -
RSPB advice seems to suggest clearing it in February.. https://www.rspb.org.uk/birds-and-wildlife/advice/gardening-for-wildlife/plants-for-wildlife/garden-hedges/hedge-law/
CIL Exemption?
Temp replied to ag1976's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
A normal residential garage would be considered part of her home/garden. -
CIL Exemption?
If all of the land you are buying from your mum is part of her home/garden ("Principle Private Residence" in HMRC speak) then there shouldn't be any CGT for either of you. If some of the land you are buying from her isn't really part of her home/garden (eg it's a paddock or agricultural or similar) then their might be CGT to pay. This would/should be calculated on the value of the land not what you pay for it. The value could include any "development value" that is its value based on its development potential. If you pay a lot below its market value then it's possible HMRC might see the difference as a gift. That could make it subject to IHT if your mother died within 7 years. I'm not an accountant - this is just my understanding of the CGT and IHT tax position. I've mentioned VAT above. -
CIL Exemption?
Not quite sure I follow that. Bear in mind that a new build is only zero rated for VAT if all existing buildings on the site are demolished. In some cases this can make it worth demolishing and rebuilding existing buildings. Great for the Environment eh? -
Search youtube for "overboarding ceiling" or similar. Several vids on how it should be done/look.
CIL Exemption?
Liability for the CIL only kicks in when you start implementing your planning permission. Until then the liability can be transferred to a new owner. So it's not really an issue. The important thing is to get planning permission and then formally apply for the self build exemption using the correct forms and get it granted BEFORE starting ANY work on site. Note that the planners may tell you either verbally or in writing that it will be exempt BUT you must still formally claim the exemption or you loose it. Is the land part of your mother's garden? If not then you should buy the land BEFORE applying for planning permission. Otherwise HMRC may go after your mother for Capital Gains Tax on the full value with planning permission. Her garden is exempt from CGT but other land such as a paddock would not be. -
Is the cavity ventilated? If so the new wall is effectively going to be.. Plasterboard. Batten PIR Single Block Leaf Try that in the online calculators?
- 4 replies
- u value
- insulation
It's common to dot and dab plasterboard to walls but ive not seen it done on ceilings. Some place recommend dots of acrylic adhesive and screws for ceilings but again never seen it done with just adhesive. Can't find any youtube vids.
Gyprock recommend a method that uses dabs of adhesive and screws.... skip to 4:05... https://youtu.be/P8fFsnZVEL8
8s thus new plasterboard going on top of old plasterboard or is it being fixed directly to the underside of joists?
Think some clarification is needed. Its fine/recommended to put a VCL on the warm side of a cold roof construction. The VCL stops water vapour getting to the cold side and ventilation removes it if it does. Belt and braces. +1 to hybrid roofs. A VCL may help reduce the risk of interstitial condensation but should not be relied on as are rarely perfect. If you design a warm roof properly you can put some insulation between the rafters but you should not put so much that it becomes a hybrid roof. See my previous post.
No. Think about it this way... Let's say the temperature inside and outside are constant so a temperaturs gradient exist between the two. With a warm roof (insulation above rafters) the rafters will be on the warm side - so there is no risk of condensation on them. With a cold roof (insulation below reafters) the rafters are cold but they can be well ventilated - so there is no risk of condensation on them. If you add insulation between or below rafter in a warm roof you effectively "move" the rafters towards the cold side without providing the ventilation. This risks consensation foirming on them. You can add some insulation between the rafters but I believe its limited to 1/3rd of the total and you should get a condensation risk analysis done. Insulation manufacturers will sometimes do these for you if you send them a proposed sketch ausing their insulation.
@suffolkselfbuild Normally the CIL calculation deducts the floor area of existing buildings so on a conversion with no new building I don't think there is anything to pay. The proviso is that the building must have been in lawful use for 6 months beforehand. So not a retrospective application. There is something funny with the way the 100sqm rule is applied if there 8s a mix of conversion and new. I believe if you did a 300sqm conversion AND a 99 sqm new building then the area used for the test to see if the CIL applies is 300+99= 399sqm. Then since that is over 100sqm the CIL has to be calculated. Its calculated on 399-300=99sqm.
Is it too late to appeal as I'd be surprised if that's a valid planning reason for rejection. Eg I'm sure they can't reject based on what you "might do" only what you have said you will do in the planning application.
VAT on garden fencing
Temp replied to LSB's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
List here might be useful... https://www.gov.uk/guidance/goods-and-services-you-can-claim-for-under-the-vat-diy-scheme -
They should charge you 5% VAT on both labour and materials and you reclaim it at the end of the build with everything else. Best ask them to requote at 5% before they start work. I assume its a conversion, not mixed use, and not a house that's been empty for 2 or 10 years. If they have a problem refer to VAT708 para 7.1.1 (which states 5% on conversions) and 11.2 (VAT rate on goods incorporated should be at same rate as labour). It may help to give them a "certificate" which is basically a letter you write confirming that the work is 5% rated because its the conversion of a non residential building to a residential building. Include site address znd any planning reference number. I think officially they are only needed for work on charity buildings but they have been known to convince unsure tradesmen. Think there is/was a template in VAT708. -
Looks good to me. Think I would use 25 x 50mm counter battens.
LPA Missed Deadline on Non-Material Amendment
Temp replied to harry_angel's topic in Planning Permission
I would take that last line as a hint they are likely to approve it. No guarantee mind.- 17 replies
- 2
- planning
- planning permission
https://nottenergy.com/resources/energy-cost-comparison/ Scroll down and see the table and column.. "Pence per kWh (after boiler efficiency)" Electricity 22p/KWh LPG 11p/KWh So switching to pure electric could double your running costs. However for a temporary or short term installation you need to consider capital costs as well. Note this is for LPG in a tank not cylinders which are probably more expensive.
Sorry the editor won't let me insert an end Quote tag to fix the problem above.
