Everything posted by Roger440
If it were me, if any of its outside the interior envelope, id prime it with this :http://www.rust.co.uk/custom-421-rust-proofing-body-primer/c32736/ When i did my steels, I painted them with automotive direct gloss 2 pack. Sprayed. But over etch primer as it was all inside. But you could do it with a roller, which will be close in terms of finish, but will require 3-4 coats as its quite runny. The end result will be tough, resist rust, and if you spray it look really good. Dont spray 2 pack without the right gear though!
Rust Removal Adventures: Electrolysis, Acid etc
Roger440 replied to Onoff's topic in Tools & Equipment
Knock the weights off. Or they wont be there when you take the wheel out. Plus they will contaminate your tank. -
Down here you cant use a soakaway. Discharge to water course OR drainage field. Not that most BCO's actually realise i will add!
- 25 replies
Not wishing to make matters worse, but if this is a new build, you must apply for planing as well now (since 2015). As far as i can tell this is because they will no longer permit a new sewage treatment installation if a sewer is available within 50 meters. If you are replacing a failed septic, thats a different story. However, be aware that a lot of your area is a protected groundwater area, so, you cant as i understand it, install a new sewage treatment plant without specific EA apprval. Im not far away from you and have researched this to death. Firtunately, i just need to replace what i have and am outside the problem area, and certainly no sewage main withing 50 meters!
- 25 replies
A stretchy garage design to tolerate ground heave.
Roger440 replied to epsilonGreedy's topic in General Construction Issues
What Jeremy suggested. If its an Oak frame jobbie, 6 piles of some sort, then do the floor in block paving. Worst that can happen is the paving moves a bit in the long term. Which can easily be re-levelled. As Jeremy also suggested, we seem to regard trench foundations as the answer to everything, which from an engineering perspective makes no sense to me. We dont even put steel re-inforcement in most of them! -
In my case there is a covenant on both properties which makes the owners of both properties responsible for the system. The plant is in my garden, and uses my power, but if i turned it off, what does that achieve. I then wont be able to live there. Im struggling to understand the issue?
Ok, i get that. But why not just foam it in? Once you trim it back flush with the top of your insulation, maybe even stick some foil over it surely that as good as it gets?
As i spent the weekend trying to sort out downlights (not fire rated in the downstairs kitchen signed off by the BCO!) im struggling to understand why you didn't just use the downlight you have (the enlite one). Why the hood, sealant etc, as the downlight meets the regs does it not. Is it just SOLELY for the reasons stated i your last sentence?
Bought enough cheap tools in my life!
Interesting!
Hmmmm............................................................... No!
So we are down to Fein, makita, bosch or Dewalt. Question now is battery or mains. I love battery tools for the lack of a lead, but my experience of battery stuff isn't that good, i suspect becuase the use of any individual tol tends to be occasional. I might not use something for a year!
Thanks chaps, i'll take a look at these tommorow.
I have reached the point i need to buy a multi tool, as this is, clearly, an ommision from my range of man tools. Question is, which one to buy. Any thoughts and experiences on what works or doesn't much appreciated.
Given your proximity to me, you will need more than 4 phones. If you find anyone who turns up and does a half decent job, let me know!!!
- 56 replies
- communication
- trades
Ive got one similar to this. On a small area like the one we are talking about, this will be pretty quick. Like Nick said, protect the vunerable stuff.
Why not indeed? Frankly, its amazing we a still messing around with plaster for stuff like this in the 21st century. But progress is slow in the building game.
Should I make building control and for what application?
Roger440 replied to legepe's topic in Building Regulations
If its got a slate DPC, then thats different. From what you said, i thought it simply didn't have one - like my place. You might well be OK. I still think injection is a waste of time. No one can expain how this will fully penetrate a brick and make it water proof..................................... -
But that has a DPC. Your refurb doesn't. -
I think experience over at the other forum would suggest most BCO's wouldn't even know or care. They are only concerned with compliance with the regs. That is there job afterall. And subsequent problems are yours. I certainly wouldn't be relying on the BCO for that sort of guidance. I dont speak from experience of doing it, only from needing to "undo" exactly this type of work to rectify issues that its created. Ive yet to start in earnest, but im pretty clear what i need to do. Spend a few hours on there, then actually look at old properties and the damage caused by modern and inappropiate building work. -
Dont fit a concrete floor! Limecrete and foam glass dpm might work though. Its what im doing in the 200 year old part of my house. No idea what the BCO will say though................... You should probably go here for a bit of reading, even if it gets a bit scary. http://www.periodproperty.co.uk/forum/ucp.php?mode=login Thing is, its really hard to know what the effect will be if you concrete it. Might be fine, but might not be. -
Will need new gas boiler: Recommendations?
Roger440 replied to richi's topic in Boilers & Hot Water Tanks
This thread is like groundhog day.................................. Do what Nick says! -
That would be a complete waste of time! Doesn't work. Cant work. But, your thoughts behind it are valid. If it has no DPC, installing a concrete floor with a dpm, "may" depending on moisture levels, give you a damp problem in the walls as instead of evaporating in the floor void, it will creep up the walls. How old is the house? -
Just an "extensive" repair! But ts still a repair if it goes back the same. Otherwise, where does it stop? If you had one rotton joist to do, still notifiable? -
Ive used it, but used the heavy duty stuff. Looked at the regular stuff at a nieghbours and decided it was to feeble to be useful.
