Roger440
    7
Everything posted by Roger440
  1. Hmmm, theres a few issues here. First off,, supply and demand will, ultimately always drive the cost.To believe otherwise is dreaming. The current thinking is to increase supply. Leaving aside how succesful this has been so far, even if you built a million houses a year, sure, in theory cost would come down, but no-one talks about the demand side. "IF" it became more affordable to live and work here, even more people would come. Which would just increase demand and push things back up. The equilbrium is where it is now. Its not going to change significantly any time soon. Only the British economy going into significant contraction is going to do that. At a more practical level, agree with those saying mass production is the ONLY way to get a decent cost reduction in construction part of the house. But why oh why, does everyone who proposes to do this make "weird" looking houses. People dont want weird looking houses. They want traditional. Planners want traditional. So why not give them that. Im sure a factory assembled house that LOOKED like a normal house cant fail to be successful. Last but not least, and again identified above, foundations. I cant believe we still dig tenches and fill them with concrete. There are lots of other types, such as the raft i built for my garage. But taking this approach to the next level, why do we need foundations at all? OK, sounds mad, but seriously, why? Surely, a level surface with type 1 etc, just as you would lay for a raft/slab is a stable surface? What the concrete actually for? If you were building a factory house, why not just make the base a steel frame (stainless maybe) and secure with some ground anchors, or on rock, just bolt it down? Ok, laugh if you like, but surely it can be done, from a technical standpoint? Sure, there would be some regulatory issues to overcome. Concretes expensive, messy and costly. Level ground, dump a load of stone, compact, install house. Not going to work everywhere, accepted. And as stated above, to me, screw piles make a LOT of sense. Minimal actual ground works. Reasons why this cant be done welcomed. Just doing some "blue sky"
  2. Got one of these. Great bit of kit. Has done everything asked of it so far. Only issue is, its quite heavy, but im a bit soft! Spend too much of my time these days on my backside!
  3. Are you sure about that? Welcome by the way
  4. Hmmm, My phone and laptop came with Chargers. So i use them. As does my wife. Still not getting it. Did see them in the screwfix catalogue when i was there. Somewhat bemused then too.
  5. I have not once in my life felt the need to have a socket with a USB port. Nor do i understand why you would. Maybe im just backwards?
  6. Nice job My guys screwed down every third ridge for what its worth.
  7. Great advice Was going to post the same question, but no need, its all here. Will see how it goes next weekend.
  8. When i was looking at bi-folds, i took agood look at the seals on various one at one of the shows at the NEC. Frankly, most of them were rubbish. In many cases just stuck on strips. Only one i looked at had "proper" seals with moulded corners etc. I.e, one piece. With a decent amount of "give". Why is it that most windows, dg etc have such poor sealing that takes no account of time, movement, shrinkage etc. They really ought to look to cars for novel sealing arrangements that work for a very long time. The hours ive wasted trying get dg units to be draught free at 3 different houses. All just crap.
  9. That would drive me nuts. My garage had them all delivered cut to length, so no joins. Longest was 6.5m if i recall.
  10. My life is too short for that. 80 hours a week running your own buisness at work leaves little time to clutter up my mind with things that will make my angry. I bought another house instead! Problem fixed.
  11. Thanks Pete. Hadn't thought of that! Of course my real issue is finding someone who can actually sort it out!
  12. Hi Pete. Found that. I think i get it now. I see no evidence inside or outside of any such thing. Given that its pre 1850 ish, maybe thats not a surprise? I fee a chimney stack rebuild coming on.............................
  13. Humour me please Dave, what is a "soaker"?
  14. There is some lead flashing, but only on 3 sides! That got picked up on the survey. But thats the opposite side to the worst of he damp. I understand the flue is open, but given its an old chimney, and its subsequently had a wood burner installed, does that not mean there is a modern flue up the inside of the old chimney? Leaving the original chimney open to the elements? Should that not be capped off?
  15. In my upstairs bedroom at the new gaff, the wall, next to the chimney is clearly damp. So i went up into the roof space today to have a look round. The chimey itself where it comes through the roof is damp to touch. I did this while it was raining and there is nothing to see. Its just very damp. As i know bugger all about chimeys, does any one know of a decent chap who might be able to asses whats going on? Im in north bucks. There is a wood burner in the living room below, but there is nothing visible from the ground on the top of the chimney. Clearly it needs some lead work doing properly, which may, or may not be part or all of the issue, but what stops the water going down the chimey?
  16. They claim its 40mm insulated, but a good portion of it had nothing but fresh air between the inner and outer layers. Like a big rectangle in the area below the window. the clue was that at night the light was faintly visible. And on a cold morning you could see by how the condensation formed which part was insulated and which wasn't. Despite repeated attempts, they bascially ignored me!
  17. I used the Ryterna option. Apart from the insulation not really being as quoted, the rest of it was pretty good.
  18. Bizarrely, he rang me today. Yes, he is quite happy to do domestic work. He has just been doing a barn conversion. It is as you say, quick and easy. I left my steel frame exposed on 3 sides and boxed in / covered on the 4th. Then, as you say you can add more insulation.In fact, i wonder if you really need foundations, but thats for another thread i really ought to start! I have given up on building a house as its just to complicated (not the actual building part) and expensive round here. So i'll stick to building garages. But yes, sort of ex garage. I do still own that house, but its now rented out. New house has no garage, so need to start all over again Still, its a nice house. Could do a thread on that if there was interest in such a thing. Its certainly no new build though......................
  19. He is a customer and wanted something i had that he couldn't otherwise get, so not a normal arrangement. I dont think he had ever done a "retail" job before! Probably wishes he hadn't either. There was only one 90 degree corner in the whole building, so was "unusual" to say the least. It also took a long time as i usually came second, but then i signed up for that so have no complaints in that department. I can ask him if you want. Briefly, what do you need and whereabouts are you?
  20. The guy who did it builds steel building, warehouses and the like. The cladding was just off the shelf insulated cladding.
  21. Indeed. You saw my one didn't you? Steel framed, steel clad and 5 times more thermally efficent than my house. Shame ive moved..............................
  22. I think, as already suggested, building control will be the main issue. At a practical level, i dont get why its not used more either. So simple, and if built like my garage gets over all the problems of the floor wall thermal bridging issues really easily. As for fixing plaster board etc, i glued it up with adhesive foam. Simples
  23. Had one of those on my garage at my old place.I understand exactly what yu have done. Looks like i will be doing the same as you. Thanks for the info Although probably at odds with some, for me, what ever i do, it just has to work with no intervention. Having to fiddle with a phone to turn a light on is not happening here. Just wish i understood the heating system i got with the house. All very modern, but currently beyond my comprehension........................... One for another thread.
  24. This is EXACTLY what i want to do. And doing the 2 devices in series is how i imagined i would do it. I was just trying to find a single unit to make life easy. But im not sure there is such a thing. Which i find remarkable. Ive no requirement for PIR.
