JanetE
Everything posted by JanetE
  1. We applied for the mortgage after splitting the plots and the mortgage was for the original house. They were aware, I think, that we already owned the land for the new house but it was not relevant really as we owned the old house outright and that was what the mortgage was offered on.
  2. @Tony99We did exactly what you are planning with the difference that there was no shared drive. This enabled us to divide the plot and register them separately before applying for our mortgage to fund the new build. So the obvious complication is the shared drive! You would really need to consult a solicitor IMO. We arranged a mortgage with the Monmouthshire BS for a 10 year term. It was a perfect match for us, fixed rate for the first 3 years, no early redemption fee, repayment only and they were quite happy that we were using the funds to build a new house on our own land. The move into the new house coincided with the end if the third year. So worth trying them.
  3. @nod we submitted our VAT claim on the 1st March. They wrote querying the delay from our moving in, on the 19th December 2017 and issuing of the completion certificate at the end of February this year. We wrote back gave them a long spiel about how Terry had been ill for much of 2018 (all true and verifiable) and let them have invoices for work subsequent to our moving in which were zero rated but a requirement of our planning conditions. They passed our claim and returned all invoices on the 28th June, bar the Wickes one of course.
  4. Be aware that if you want the ASHP insulated pipe to go under your raft foundation you will be hard pressed to fit this in the 110mm pipe. We had a hell of a job getting the pipework through, partly because we used a 90° bend as opposed to a slow bend to exit into the service room and also because the ASHP insulated pipe is not very flexible. We ended up having to fit two long flexible connectors to get it round the last bend and also we had to strip off the outer flexi casing and a layer of insulation to get it through the duct.
  5. Thieves nowadays use drones for looking around and working out ways to nick equipment. There is a thread on the theft of wooden fencing which was posted on recently which is worth a look. "Site Security revisited"
  6. Thanks all for your recommendations. I think we'll go with the Karcher K4 and also get the patio attachment.
  7. We need a pressure washer to clean the drive and very occasionally the car! I was looking at the Karcher K4 which looks pretty good. Anyone got any recommendations?
  8. Having lived in our MBC house with underfloor heating for just over a year I personally would never choose to go back to radiators. Nothing compares to the comfort and utility of underfloor heating and I am sure you will regret it if you decide to go down the conventional route. It was a no brainer as far as we concerned to get them to lay the pipes before the pour and if I recall correctly it was more than a half days job for the three guys as the pipes have to be cable tied to the rebar. I am sure it is also the cheapest and most convenient way to heat your house. Worth every penny.
  9. I think in this case maybe some camouflage netting would have hidden this from a flyover with a drone, as this seemed to me the way that the thieves recced out his store.
  10. Exactly the same for us, we were weathertight the day MBC finished our build. Absolutely no cracking of the plasterboard anywhere in the house. We boarded and plastered about six months after the frame went up. I suspect that if your frame does get wet is just a matter of waiting long enough for it to dry out before plastering.
  11. We have a timber frame house build to passive standards by the same company that @JSHarris used which is MBC. Like you are planning, we are not passive certified. They laid the foundation installed the ufh heating pipes at the same time and supplied and erected the timber frame, and guaranteed air tightness. The house passed on the first test. We decided to go to a company that would do the whole package as the interface between different contractors is often a major stumbling block. We did visit a few different timber frame company builds before opting for them, and realised that the fewer contractors involved the less chance of problems. Which you will find from the experiences of some of the members on this forum. We have nothing but praise for the quality of their work and have now been living in the house for a year. It is such a comfortable space, no draughts and always pleasantly warm all through the winter and not too hot in the summer. If you have a look at @TerryE 's blog you will see some more information. This forum is an amazing source of very useful information. Good luck with the build.
  12. @JSHarris can you possibly send me the link for the flow restrictors that are suitable. I'm having difficulty finding the correct parts. Thank you.
  13. I think restrictor washers are probably the best solution for us. The mains pressure here is good, about 3bar. Tbh the kitchen taps are far too forceful without any kind of restriction. Thanks for all the advice.
  14. Why am I having such a problem finding a flow restrictor to fit the end of my kitchen taps to keep the Building Inspector happy? I'm looking for a female m22 with a reasonable flow rate of 8/9 lpm. All of the insert only ones that I can find seem to be too deep to replace in the existing tap end and so I am forced to replace the whole end. Also they all seem to come in shiny chrome and our mixers are brushed steel and also don't seem to give a flow rate!! Any suggestions please!!
  15. We have the same slab as @JSHarris all done by MBC. We are on clay and before the slab was laid the area was basically a lake as the water table is high. We were advised by the MBC engineer to lay a land drain 1m out around the area of the slab which we did in advance of laying the slab as you can see from the attached picture. This has done the trick as we have no problem at all now.
  16. Just to clarify, the fan drew cold air in from outside at a low level. The was also a vent high up to aid ventilation.
  17. I thought mice could live on insulation (sorry @joe90) We had one living in our mattress once, long time ago in the old house?. Only noticed it because of the odd smell and the fact it was getting a bit saggy (I'm sure it was living on the foam/cotton filling) Lifted up the mattress and there was this hole that was between the wooden slats of the base. Moved the mattress slightly so the hole was covered by a slat and put a piece of paper under. Lifted it the next day and found scratch marks on the paper. That was it! Taped up the hole, carried the mattress outside and did a clog dance on it. Terry suggested we cut open the mattress to make sure the mouse was dead but I drew the line at that. Just had to get a new mattress after that.
  18. JanetE
    Gas sign off
    That's a shame, I've always previously had gas cookers and was reluctant to go electric in the new house. So compromised with an induction hob and was amazed at how good they are, as instantaneous as gas but far, far easier to keep clean and look so much nicer too. I would never consider going back to gas now.
  19. I've just bought our Kinetic filters from https://filtermate.co.uk very reasonable.
  20. We have one of these fitted to our MVHR and absolutely no problems. As you can see it can be fitted horizontally or vertically. https://www.screwfix.com/p/osma-waste-valve-white-x/1819k
  21. I was researching this when we were building and was horrified at how expensive this type of light was, in the end I found these; https://www.ledkia.com/uk/buy-apliques-b/464-randy-led-step-light-with-a-white-finish.html Which now we have them installed I love, they give off enough light that we hardly ever need to have the main ones on.
  22. We are on pretty impermeable clay and we dug out the trench for the land drain in readiness for the MBC slab. As @dogman says, 1m out all the way round the house. The MBC guys then laid down the impermeable membrane then the land drain and filled with fine gravel. Then Iaid out the hardcore etc in preparation for laying the slab. We now have no problem with standing water around the house. Prior to the slab going down there was always a mini lake which was a great attraction to all the local birds.
  23. Well we've spent the weekend fitting the ASHP pipe according to @JSHarrisrecommendation (thanks Jeremy, great help as always). Bought the pre insulated pipe that @Barney12 recommended. Stripped off the outer corrugated protection for the part that enters the access pipe. Luckily there was a double layer of insulation and we only needed to remove the first layer. Then connected the 1.5m flexis. Wrapped them in insulation and then wrapped the stripped back section and the insulated flexis in polythene and duck tape. The pipe fed in pretty easily once we got some rope tied around the corrugated section about two meters back and used it to give us a grip on the pipe and enable us to push it in. We can now just get the paving guys to bury the pre insulated pipe to the approximate position for the ASHP.
  24. Yes and it's not a swept bend either! Terry thought maybe we could leave the insulation off that end of the pipe. I assume we would use the 22mm hep20 stuff with some kind of insulation taped around it. We could finally fill the 110mm pipe as it comes into the house with expanding foam. The pipe will be under the insulated slab by then anyway.
  25. Just resurrecting this thread as we need to future proof in case we decide to install an ASHP. At the moment the Willis heater is doing a pretty good job of keeping us warm, but we may need some cooling in the summer and that will call for an ASHP. The electrical supply is not a problem but it is the pipe runs that we need a bit more information about. We are just about to have the paving done outside and need to sort the access. The ASHP will need to be installed outside against the shed. The access for the pipe runs go under the slab, this is simply some 110mm soil pipe coming into a 90° bend straight into the utility room. This is probably going to cause us a bit of grief. We didn't do our homework on this when the slab was installed and now need to work around this issue so any advice would be welcome.
