ETC
    9
Everything posted by ETC
  1. By putting the stairs where I have shown may minimise the amount of demolition you will need to do plus it should get you to the highest point of the roof for headroom upstairs - just a thought.
  2. Might be better with a DPC behind the outer leaf. Personally I’d have treated it in the same way an external door is - precast concrete threshold wrapped in DPC and then taken the DPM across and up the back face.
  3. ETC
    Hello All
    Very smart.
  4. No great tbh. Bit disjointed. You’ve got all the right bits but not necessarily in the right order. Give me a shout if you want me to take a look. Also what does it look like? Is there a bit of pitched roof and a bit of flat roof to the back? Strange kitchen layout - might need a bike to get from one end of the units to the other. Utility is too small. Little to no storage. Try putting furniture on the plan.
  5. Why don’t you pump the cavity/ Also how are you getting cover to the bottom of the mesh? Why have you got a DPC cavity tray?
  6. How do you rod the pipework?
  7. One or two depending on size into the loft. No ductwork - 10mm off the bottom of all doors.
  8. What do you want?
  9. Does it work? Is it vented? Can you rod it? Are pipes properly protected?
  10. Insulated plasterboard across the rafters.
  11. Whatever it is it will have needed a Building Control application - a quick phone call and you can find out what the craic is!
  12. Move the door!
  13. You’ll be pulling it up in a year.
  14. Don’t put a timber floor in. It will sweat like mad and the timber will rot unless you ventilate the floor. Do as Nick says - floor finish on VCL on insulation on DPM.
  15. From your FGL when the house is built. Sometimes combined with a maximum under build.
  16. Waste of money insulating the garage if it’s not heated. Insulate the wall between the garage and utility and the floor between the garage and any habitable (and heated) accommodation above. No heat = no insulation required.
  17. No need to insulate the wall. DPC shown in optimum location for damp penetration.
  18. Once stayed in a hotel/b&b in Canterbury - not a level floor in the whole building - was grand.
  19. Why don’t you just lift the boards and put firing pieces on? Simpler and cheaper.
