ETC
Everything posted by ETC
What’s the difference between FGL and FFL? My advice would be to separate the radon barrier from the DPM and have the radon barrier below the slab - makes life easy for putting in the DPM which should go above the slab. DPC in the inner leaf at slab level. DPC in the outer leaf at 150mm above FGL.
Er…..I think the gas barrier, DPC and DPM positions are critical…..so I’m told…..
Post your architect’s and SE drawings.
PWA Can you build anything over a neighbour's property ?
ETC replied to Spinny's topic in Party Wall & Property Legal Issues
Hire a solicitor. -
Draw what you have built to-date and post it here. The details do not look practical to build.
If BC have approved the drawings and the locations of the houses relative to one another what’s the problem?
Escape windows can be lockable - not a great idea in my opinion but acceptable in ADB. Approved Document B vol 1 2019 edition inc 2020, 2022 and 2025 amendments and forthcoming 2026 and 2029 changes
Starting a business helping Self-Builders, advice?
ETC replied to LDNRennovation's topic in Surveyors & Architects
Can you post some of your work that you have already completed for Forum members? - as an architect I would be very interested to see your work. Thanks. ETC. -
Used to do that with worn listed building step treads…..just turn them over…hey presto new step.
Surface water flow attenuation problem.
ETC replied to G and J's topic in Rainwater, Guttering & SuDS
I think I’d swop the WC and the sink over in the cloakroom. -
Grand. 50mm air gap (or as near as possible) needed between the insulation and underlay. There are some underlays which say you don’t need ventilation but they do have some caveats.
Which way is this drawn? If the rafters are shown on a slope you will need continuous ventilation from the low to high end. Plus 50mm gap is normal.
How would you update the front of this bungalow?
ETC replied to LDNRennovation's topic in New House & Self Build Design
How much do you want to spend? -
Where will the toilet roll holder be?
I would always advocate full insulation below any gutter. Your detail shows a potential thermal bridge.
Speak to Kingspan or Trocal for a detail although I would assume that you would want to place your insulation above the deck and firing pieces.
Will the thermal loss be any greater than through the adjoining window?
Garden Room - 'substantially non-combustable'
ETC replied to having a go's topic in Garages & Workshops
Build a 100mm thick block wall either inside or outside the building.................then build whatever you want!- 8 replies
- building regulations
- garden room
(and 2 more)
...................Or.................put plywood over the joists and then tapered firing pieces from front to back.
Fire protection of steels
ETC replied to Post and beam's topic in General Self Build & DIY Discussion
I do believe that the steelwork should be fire protected within a domestic floor where it supports an element of structure above - in this case a cavity wall. I don't think your BCO is correct if he/she is saying that simply enclosing the beams in the floor will give the fire protection. -
I presume there is a roof not a floor above this? -
Planning Approved - Feedback on proposed layout
ETC replied to Owain1602's topic in New House & Self Build Design
Search the Register This might help. -
If it’s within 1m it needs to be substantially non-combustible material. Timber frame on its own with metal cladding won’t give you the FR you need. The rules for FR for a building within 1m require the wall between you and your neighbour to have 1HRFR and that needs to be from BOTH SIDES. More than 1m away and the FR is required from INSIDE only.- 8 replies
- garden room
(and 2 more)
